Question about Apple iPod nano
Charger how can i find the i pod charger ??
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 68 Answers
You have to buy the dock connector USB cable sounds like you dont have one??
Posted on Nov 04, 2012
    Scholar:
  • 120 Answers
Oh, well an iPod cannot live without a computer. The dock connector/data transfer cable is a charger itself. It will charge from the computer itself, and will transfer data also when connected and charging.
You can use a separately sold USB Wall Adapter from Apple to charge the iPod from a wall socket. The adapter has a slot to insert the USB Cable and it charges.
Posted on Dec 17, 2008
3 Suggested Answers
BearWeb
  • 357 Answers
SOURCE: my i pod touch won't turn on unless i put an
This problem is most probably caused by a faulty battery, if the battery is old it could be caused by that or if the battery was left uncharged for a long period of time.
You can purchase a new battery by following this link: Google Search, you can do the replacement yourself by following this link which will take you to a tutorial of how to disassemble your iPod Touch: Click Here
Thank you for using FixYa! Have a nice day and please remembe to rate this solution.
Kind regards,
BearWeb
Posted on Mar 07, 2010
SOURCE: Piece of charger stuck in I-pod
I took a pin (the type that comes with clothing) bent a tiny hook on the tip then inserted it, rotated and pulled the piece out. Worked like a charm. You need a thin pin.
Posted on Jan 28, 2011
REPLACEMENT CHARGER MAKITA DHP 456 18V 4.0AH LITHIUM-ION
Here is the charger. it is priced pretty good. I have seen it at other places for over $100.00 https://www.factoryauthorizedoutlet.com/makita-7-2v-18v-pod-style-and-stick-style-3-hr-charger-model-dc1804
Oct 21, 2016 | Makita Drills
How do you charge an i-pod
You will need to purchase a charger, but you can use the charger USB end into computer
Sep 22, 2014 | Apple iPod Audio Players & Recorders
I need a power charger for a veco 12 pod 450 amp 12 volt jump start system .
The smart thing to do is, after using it for a jump start, leave it connected for 5 minutes and it is charged again... otherwise a normal 12 V charger will do on the clamps that go to the box... I use a 12V Stanley 25 amps when needed. But most of the time I keep it connected for 5 minutes and do not worry about it.
Jun 23, 2014 | JUMP START SYSTEM
I have a Makita with 2 PA14 batteries and a DC1414F charger. When I turn the charger one the green light flashes once but no other lights show at all when I'm trying to charge my 2 batteries. Neither...
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Aug 08, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
My apple ipod touch will not charge. Nothing will come across the screen. not even a view if the battery. I've had it charging hooked to the USB cable to my computer for at least 30 minutes and still...
it might be that the charging space that makes the i pod charge is faulty due to always removing and fixing the charger in the charging space.The charging space might have been damaged or the voltage of the light i your area fluctuates and might have affected the charger too.
Check the charger with another i pod to confirm if is the charger or the charging space that needs to be replaced.
Take care.
Mar 15, 2010 | Apple iPod touch
My i-pod touch screen is frozen. I can not shut
Let it die on its own. Then plug it into your charger and let it completely recharge, Unplug from wall charger, and see if comes back on. You may have to restore it before using it again.
Feb 01, 2010 | Apple iPod touch
I AM LOOKING FOR CHARGER FOR TYPE 6347D BATTERY IS 1822 18v 2.0 Ah ..... I WANNA BUY IT FROM EBAY BUT DON´T KNOW WCHICH TYPE CHARGER IS SUITABLE FOR THAT.... WILL I GET A GOOD ADVICE FROM ANYONE? PLS
The charger you need is Makita charger DC1801. If you do a search for "DC1801" on ebay you will find heaps of those chargers on there!
The DC1801 charger will charge the 6347D 18v 2Ah Makita NiCad pod-style battery.
Jun 18, 2009 | Makita BHR200SAE Cordless Rotary Hammer
8300 will not charge
My charge port is broken out of my 8300. I bought an extra battery and an external charger off of eBay for a little of nothing. You can also by a pod that will charge your Blackberry. The two gold tabs on the back of your device beneath the battery is an external charger connection for a desktop pod.
Oct 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Just take it to a consumer elctronics or electronics repair shop
Nov 09, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Wont start
I would like to help with your problem, but I will need some more information. What type of iPod do you have, and what type of charger is a 'mains' charger?
Nov 05, 2007 | Apple iPod MP3 Player
Apple iPod nano Logo
82 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
