Question about Kenmore 63942 Dryer
My kenmore dryer has stop working it made a little noise then cut off i think it the fuse . but trying to locate it.
  • Kenmore Master
  • 8,220 Answers
The fuse mounts on the backside on the blower housing. A small white part with one screw holding it on the blower. 2 small wire connect to it.my kenmore dryer has stop - fb7d0ce.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 18, 2008
Kenmore Dryer fuse keeps blowing
Blower housing most likely stopped up with lint. This located behind front panel, lower section.
Sep 23, 2017 | Kenmore Dryers
Kenmore Model 1.10 60902990 Dryer Problem
Try it with out connecting to your vent and see if it still trips,other wise your vent is still clogged. Also should be good air pushing out the disconnected vent, if not maybe blower wheel clogged.
Another thing is how hot is it getting.Maybe the operating thermostat is getting to hot and never stopping the heat when its supposed to.
Nov 07, 2013 | Kenmore Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
Kenmore Dryer light comes on but control panel not operating
Your thermal-fuse is located on the back side of the bulkhead upper right hand cornerb68bc9a.jpg
Electrolux family of dryers newer models Dryer Service manual
I have repair photos and more HERE
Jun 15, 2010 | Dryers
No heat
The thermal fuse is located on the blower housing while the thermal cut-off is located on the heater housing. If the dryer is electric, runs but doesn't heat, the thermal fuse is not the problem; otherwise the dryer will not run because the thermal fuse is wired in series with the motor and cuts power to the motor when it fails. The problem could the heating element, high-limit thermostat, thermal cut-off, or cycling thermostat. These components can be found in the blower housing and the heater housing depending on the model of the dryer. Specify the model number of the dryer for a more specific advice.
Apr 12, 2010 | Kenmore 63942 Dryer
Kenmore Clothes Dryer Model 67902790 has no heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.(Thermal cut-off)
Aug 24, 2009 | Kenmore 62882 Electric Dryer
All the electrical lights are working but the dryer will not start. We tried to clean the dust area(where you unload all the dust), after that the dryer stopped working. Does anyone have any adive?
the dryer is on a separate circuit from the lights. go to your electrical panel and locate the circuit breaker or fuse for the dryer. if it is a breaker, turn it all the way off and then back on. if it is fuses, replace with new ones of the same amperage.
get back with any questions you may have.
May 10, 2009 | Kenmore Dryers
Location of the thermal fuse on the kenmore gas dryer 80
Feb 03, 2009 | Dryers
Kenmore 63942 Dryer Logo
47 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
