Question about Canon PIXMA iP5000 InkJet Photo Printer
White pages Mine is Pixma iP 5000. I've replaced a black ink cartridge . When I clicked on print, printer gives two or more while pages. Kindly advise me. This the first problem I ever met since I bought it.
  • Canon Master
  • 2,386 Answers
Most probably solutions are:-
before replacing cartridge you must remove the seal strip from cartridge.
place the cartridge at proper place.
after replacement you must alligne cartrige.
hope it will fix your problem.
Posted on Dec 17, 2008
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
Low ink warning
In short, yes. The way printers often track ink levels is by counting the number of pages printed so you have to reset this when you put in a new cartridge. As canon uses a number of cartridges be sure to do this only for the one replaced. You will get more functionality when this is done via the computer software for printing but as you don't say which O/S you are using I cannot give details.
Dec 01, 2011 | Canon Office Equipment & Supplies
Put new black canon 3-e ink in canon Pixma ip 5000 black line of print have a white horizontal stripe through center. I don't seem to have a repair utility t o clean heads and align. Mac OS 10.4.11
The clean heads option should be in the Preferences/Maintenance tab where you go to do other things, e.g. alignment, ink counter reset, etc. If you cannot see this, you mmay need to reinstall the driver for the printer. You could also ask Canon. Finally, if the catridge is a refill or compatible, try a genuine Canon black cartridge.
Apr 25, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Why I can't print in black and white.
It may want the cartridge in to protect the heads. Put an old empty on in. Make sure to go to Start, Settings, Printers. Select the Pixma and go to Printing Preferences. Once here set the COLOR OPTIONS to Grayscale, print black ink only.
Hope this workds for you.
good luck
Feb 19, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Replaced cartridges
keep cleaning untill it starts to print clearly, you may reuse the same paper for that purpose, if you don't see any progress after 10 cleans, consider getting lasser printers, they are immune to print head drying and save alot of money on ink replacements. go with brother color or black and white series. I switched and don't have problems anymore
May 20, 2009 | Canon i450 - Printer - color - ink-jet -...
The ink cartons are full. Printing is not taking place
Hi I think I had a similar problem, I let the black and cyan run down really low. then it took a week to replace the cartridges. The result was no black and cyan. I put in new cartridges and of course no colour.
Solution: Take out the cartridge holder and take a cotton bud and soak all the ink pads in alcohol (no not beer)
I used clear alcolhol from the chemist, the reason for this is it dries out very well after the clean process with no contamination. Give the ink pads a good soak and rinse out in very hot but not boiling water and allow to dry. Then go through the deep clean process in 'printer maintenance'
You may have to do that several time but be patient and it should clear out and start to print again.
MCL
Mar 30, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Dell 720 printer won't print
Our Dell AIO A940 stopped printing black ink. Tried so many things, and finally (a year later) got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
It's worth a try! Good luck!
Oct 23, 2007 | Dell Inkjet 720 Printer
Canon PIXMA iP5000 InkJet Photo Printer Logo
57 people viewed this question
old marine
old marine
