Question about Brother MFC 240C All-In-One InkJet Printer
I replaced all cartridges and it wont print black
For some reason it wont print in black at all. i bought new cartridges nothing, i pressed clean over and over nothing, and i am so feed up i want to take it apart but dont know how? i rean test prints and every other color but black.. help me please
  • 1 more comment
  • Anonymous Dec 28, 2008
    Same problem here, it just wont print black
  • christof1 Jan 11, 2009
    Same problem here, the connection to the pc works fine, I have no error messages on the display, I replaced old cartridges with new genuine cartridges, and it recognizes that all cartridges are full, I also tried to realign and clean the cartridges several times but all I'm getting is blank pages with nothing being printed.
    Brother is really a bad brand. HP and Epson are the best, but they are all ripping you off with the price of their cartridges. They all give you a quick run around for your money and nothing after that. Bunch of crooks
  • solo_99o Apr 26, 2009
    my printer is only printing colors..no black...pls help me....solo_99o@yahoo.com
    Champion:
  • 320 Answers
IF YOU ARE USING REFILLS YOU HAVE DAMAGED THE PRINT HEAD,
Posted on Jan 12, 2009
Kodak esp 5210 wont print black
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
Apr 16, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
New black cartridge horz lines cleaned head &cartridge roller ; bought new cartridge still lines
Try to clean the print cartridge nozzles:
  1. On the printer control panel, press Menu.
  2. Press the down arrow button until you highlight Clean Cartridge. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  3. Print the document again to verify that print quality has improved.
  4. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
You can also try to align the cartridges:
  1. On the printer operator panel, press Menu.
  2. Press the down arrow button until you highlight Align Cartridge. Press Select.
Jul 28, 2011 | Lexmark P4350 All-In-One InkJet Printer
My lexmark z611 only prints blank pages with nothing on them, i bought a brand new ink cartridge that is black ink for it and it says it is low on ink for some odd reason but when i print things in color...
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
May 15, 2011 | Lexmark Z611 InkJet Photo Printer
Black wont print. Changed to new cartridge, nothing
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Office Equipment & Supplies
Can Someone Help?
If you installed new cartridges in teh color slot and it will not print from the computer in color, go into the printer setup menu, a button on the printer should take you here, and print an alignment page. If this fails to print correctly, select to perform a deep cleaning. This will use a lot of ink but will insure your nozzles are working correctly. If nothing prints or the color still isn't correct you will need to either manually clean the nozzles or have someone clean them. To be honest, depending on the cost of the printer it maybe more cost effective just to get a new printer than to have your manually cleaned. As inexpensive and printers are today I don't even replace cartridges anymore except for the black one. When the color runs out I get a new printer. The printer runs 35 to 39 dollars the color cartridge runs 35 to 37 dollars. But I don't do a lot of color printing. It is a choice the individual has to make.
Aug 28, 2009 | Dell A940 All-In-One InkJet Printer
Wont print
what are you trying to print in black? the best way to test out a black ink is to open word pad and type some thing random and print it and see if that works. if you have a all in one printer u might have 2 inks one color and one black in the printer
Jun 01, 2009 | Brother MultiFunction Center MFC-440CN...
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
I recently changed the colour cartridge and now the printer wont print colour. Black works - ish. I have troubleshooted and did everything recommended eg clean print heads, nozzles, align heads etc....
Please see the online guide at:
http://support.epson-europe.com/onlineguides/en/sc48/refg/ref_g/
and click on Replacing Ink Cartridges. To change a cartridge before it is low or empty you must press the maintenance button AND the power button at the same time, or use the print utility.
If the new cartridge also fails to produce print, come back with a new comment for further help.
Apr 13, 2009 | Epson Stylus C48 InkJet Printer
Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Brother MFC 240C All-In-One InkJet Printer Logo
291 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
