Question about Intel D845GVSR Motherboard
Cost of 1 gb for Intel 845GVSR drivers - Intel D845GVSR Motherboard
I have intel 946 motherboard but its disply is intermediate
Posted on Dec 17, 2008
I HAVE INTEL 845GVSR MOTHERBOARD & 2.4 GHZ PROCESSOR & 512 MB DDR 1 RAM ,I WANT EXTEND TO RAM,IS IT POSSIBLE ??
Yes, up to 2 GB as written here: http://downloadmirror.intel.com/15210/eng/D845GVSR_TechProdSpec.pdf
The type of RAM that you want to choose is written here too.
Mar 20, 2012 | Dell Motherboard 51XGM SYS BD GX110...
My mother board is intel 845gvsr,it not coming any display,before days it's working properly.but now it's not working,even bios settings also not showing.some times it's working but only 5 to 10 min only...
just a thought have you checked that its not shorting out on the case? when you installed the motherboard did you put in the spacers?
if you have then i would suspect the psu check that the fan it running when you switch it on
John
Feb 07, 2011 | Intel D845GVSR Motherboard
I have intel 845GVSR motherboard for P4 CPU and i am unable to install audio driver from Intel CD ROM So how to find & install audio driver?
Check your "BIOS" to see whether the audio device is enabled!!
For the Intel Mobo 845GVSR is a discontinued product by INTEL, and also check your CMOS CR2032 3V battery if it need to be replaced.
If you have the MOBO CD all the drivers are there but maybe the drivers are outdated.
Aug 12, 2010 | Computers & Internet
I have Intel Orginal 845GVSR MotherBoard with 2.4 GHz Processor and 256 DDR Ram. Can I increase my Ram to 1 GM with 400 fsb speed
Here's a direct link to this motherboard's technical product specification document:
Scrolling down to page 21 of this PDF docuemnt, under section "1.7 System Memory", all details related to memory specs are listed.
Based on this, the answer to your question is: Yes. You can increase your RAM to 1 GB with 400 FSB speed.
Mar 24, 2010 | Intel D845GVSR Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
Intel 845 GVSR drivers for windows vista
Hello!
Your chipset drivers are available from intel here:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1065
Please select your operating system and hit "Go!"
Feb 17, 2009 | Computers & Internet
change to Windows XP,
windows vista will not support with *********** board
it will support more then 865 chipset
May 17, 2008 | Intel 845GE Motherboard
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Apr 09, 2008 | Intel D845GVSR Motherboard
i don't know weathere you are awared of this or not...
to get the 32 bit graphic on 82845gv motherboard go to BIOS setting and change your video frame buffer size to 8 mb and agp aeperture to 256 mb and let the system boot... you will get 32 bit graphic with 1024 x 748 screen resolution... i have changed and believe me it is working
but only problem is that you will hardly play any game or use bubble screen saver..
Feb 24, 2008 | Intel D845GVSR Motherboard
Intel D845GVSR Motherboard Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
