Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Envision 17inch lcd Monitor problem
I have the above monitor that i can see the text on screen but its very dark and the brightness is on max. i tried plugging it in to a different cpu but it still the same way.
    President:
  • 814 Answers
This problem is a failing of the backlight circuits. the lamp is either failing or the power circuit is failing, causing the lamp to dim down it power output. Return to dealer for service. Hope this helps you.
Posted on Apr 14, 2009
My moniter screen go's dark with a bright horizontal white line in center ..it flickers
the driver board is bad in the monitor. Has it been in a place that is super hot like in a car? If the verticle driver chip disconnects from the matrix driver array, it will all squish into a single line in the middle of the screen like you are describing.. might try opening and blowing where the driver board connects to the LCD matrix (bunch of connectors on a plastic flat cable/bus connecting to the end of the LCD panel.. heating them could allow them to reconnect.. Its worth a try, right? It has worked for me about 60% time.
Feb 03, 2014 | Envision Computers & Internet
Compaq TFT5010 Dark Screen problem
Are you sure about power supply section? no bad caps with bulging tops at all, some bad cap may have flat tops but have high ESR.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Send me pictures if you are not sure, budmrtn@aol.com
May 22, 2010 | Compaq TFT5010 (Opal) 15.1" LCD Monitor
I have a Envision EN-7100e monitor. Downloaded
catamount309, This is only a guess, but unit may have internal "switch-mode-power-supply"/"CCFL inverter" board problem. When screen goes BLACK, is it also BLANK? If you can see WIN-desktop with aid of bright flashlight 1 inch from screen, then SMPS is in partial shutdown mode. If you see nothing, then SMPS is in full shutdown. In either case, Technician will need to repair the SMPS/CCFL inverter board. If KNOWN GOOD monitor works with PC, then you know 7100e is bad. Do you know and understand how the new energy efficient screw-in curlie-Q light bulbs work? If the "electronic ballast circuit" not working, then it can't light-up the CCFL tubes on the reverse side of LCD panel then you see black. Do more reading in my fixya profile for more options open to you. Do your research first!! Hey, reading is free!!!
Will you fix or trade for new? 12fixlouie
Mar 07, 2010 | Envision EN-7100e 17" Flat Panel LCD...
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Monitor ENVISION EN985e with Vertical failure
If you are looking to take the monitor in to get it fixed, you can try Best Buy. They have an in-house repair team called Geek Squad. For a store in your location just go to www.bestbuy.com
Mar 24, 2009 | MPC Computers Envision EN 985e (Dark...
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Help
If the monitor was dropped, most likely you damaged the internal components that provide the picture, whether LCD or CRT. Try connecting it to another computer. If this doesn't work, check the monitor's display settings or operating system display settings for contrast or brightness. NEVER open up the monitor, because there is a high voltage capacitor that stores voltage even when the monitor is off and could kill you if it discharges.
Jun 11, 2007 | Envision EN-7220 17" Flat Panel LCD...
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
149 people viewed this question
Top Envision Computers & Internet Experts
Steve
Dimitar Todorov
Paul Bade
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
