Question about Numatic Vacuums
The pump not working - Numatic Vacuums
    Scholar:
  • 33 Answers
Dear Shazaar,
please Rate the Solution..
CONDITION PROBABLE CAUSE RECOMMENDED CORRECTIVE ACTION Pump will not start.
  • Power Off
Check switches and fuses
  • Belt/Pulley or coupling damaged. Pulley or coupling setscrew loose.
Check v-belt/pulley or coupling.
  • Room is too cold
Drain and refill pump w/warm fluid. Try to start w/intake open to atmosphere
  • Pump mechanism is seized
Pump to be repairedPlease rate the solution.Thank you
Posted on Dec 17, 2008
Black & Decker Steam Buster SV1000. Can't get to steam (or spray). Never used before but have had for several years. Nothing clogged. 50 water/50 vinegar in water reservoir. Vacuum works fine. Pump...
The impellar or your water pump is on its very last broken fin, time for a mew machine or the long hunt to find a replacement impellar
Nov 06, 2014 | Vacuums
My Hometek Steam Penguin wont produce steam
Hi
I opened whole thing and found that no suction to the pump or pressure from the pump. Opened the clear box which contains the pump and the el-motor. Then I opened the white pump and found it was assembled wrong way round. There are two tiny one way silicon "valves" which should produce the flow of the water to the heater. I also wiped off part of the sticky grease away. Now it works. 4 hours work, but it was interesting to learn the function :) .
Anssi
Apr 09, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
Pentax water pump 1/2 hp when pump starts works well but pump does not cut out when all taps in the house are closed
it sounds like the switch is faulty take it back to the shop and tell them ok
Mar 28, 2011 | Vacuums
Aquamate basin pump does not work. Used it 3 times, stored it for a year and pump does not work. Looks like a reliability issue. Is this product defective for everybody? I saw an ebay listing for the...
Hmmm............ looks like the impeller is already stuck from a year w/o using it!
I suggest if u could open it and spray some penetrating oil on the bushing of the pump motror and the impeller, force the motor to turn manually to set it's rotor FREE. or just POUR some penetrating( I usually use BRAKE FLUiD ) oil in the pump and let it seat for a couple of days.
If don't have a knowhow in opening and repairing such machine, u coud bring it to ur tecnician or service center to fix that up!
Hope that helps u out!
Dec 02, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Bissell 9200 upright carpet cleaner does not spray water. Could it be the pump or solenoid, or both?
It could be the pump. You can open it up and see if the pump is working by taking the pump input tube and inserting it into a bowl of water. Pull the trigger and see if water is leaving at the pump output.
However, ensure you have the simpler things covered first:
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Dec 04, 2009 | Bissell 9200 Upright Vacuum
Pump motor sounds like it is running but is not pumping
The pumps in these machines are very simple and there's almost nothing to go wrong. If the problem is actually in the pump, the most likely thing is that there's something stuck in one of the valves, but this is unlikely as long as you've got an undamaged filter on the intake tube in the clean water tank. More likely is that the diode has failed in the live wire supplying the pump. The function of the diode is to act as an electrical one-way valve, and if it fails the pump will sound like it's working but it won't shift any water. I don't know of an easy way to check the diode, but replacing the pump lead-wires should be cheap. If that doesn't solve the problem, fit a new pump (they're not expensive).
Good luck! Please remember to rate this response, thanks.
Oct 29, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Pumped several times
your pump is most likely cracked.So nothing is escaping
Sep 08, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My pump runs but won't pump
Refer to the discussion at the other thread: http://www.fixya.com/support/t3309646-pump_motor_sounds_like_running_but_not
You will need to remove the top domed lid to access the working parts. Refer to http://www.fixya.com/support/t3543424-two_top_sections_held_together
Examine the water lines to ensure they are attached to the pump. If you feel you can do so without shocking yourself on any exposed electrical connectors, try disconnecting the inlet hose. Buy a two-foot section of the same size hose from the hardware store and connect it to the pump inlet. Plug in the unit (be careful!!!) and use the pump switch to see if it draws water. Then try reconnecting the inlet and connect the outlet to the new hose to see if the pump pulls water from through its suction tube and will pump through the new hose.
Nov 16, 2008 | Bissell 1672 BIGgreen Wet/Dry Vacuum
7920 ProHeat replace red pulley on the pump
Pulley only comes with the pump. So you have to replace it, 2107181 it will cost about $30
May 03, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
George
Hi.
No the switch for the pump will work without main vacuum switched on.
Your problem could either be faulty pump switch or faulty pump,
You should be able to get spares relatively easy from any independant vacuum repair shop.
Dont try currys etc they wont have a clue what your talking about.
http://dysonmanuals.llc.nu/
Chris.
Feb 08, 2008 | Numatic GVE370 Canister Wet/Dry Vacuum
Vacuums Logo
245 people viewed this question
Top Numatic Vacuums Experts
Chris Nomland
Chris Nomland
Andrew Taylor
Andrew Taylor
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
