SOURCE: fRANCIS Francis espresso problem..just barely coming out..
Try removing the metal grille from the machine. I don't know the term, but it's held in with a single allen screw on the underside of the machine. Don't use the allen key that FrancisFrancis provide, it's made of soft metal and useless. Buy a decent one.
I did this, and found coffee 'goo' a millimetre thick on top of this sheet of metal. Once I'd cleaned it off it was fine. To clean it, I put it into a cup and soaked it with Mr Muscle oven cleaner, left it for an hour, and then scrubbed it clean. I ran a sewing needle across the back to help clear the pinholes.
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
SOURCE: I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
SOURCE: my francis and francis is leaking and the espresso
Hi
Try calling Illy at 877-469-4559. They can help you get your machine fixed.
SOURCE: Needing a Francis Francis X3 portafilter and steam head
If you have no luck finding a FF! portafilter, you can use the ones from some Ascaso models. See http://coffee-stuff.blogspot.com/2009/11/thing-of-beauty.html for more details.
