Question about AOC Computers & Internet
Display is Not Full Screen
AOC monitor is attached to my laptop. I hit some buttons when moving it and now the image from my laptop is not displaying on the full screen. There is about an inch of black on the sides and an inch and a half at the top and bottom.
  • 124 Answers
SOURCE: ACER 17" black monitor
first, I would check screen cable. try replacing it with a new one, you will be surprised to know how many display problems are are caused by a defected screen cable. in case this is not the problem, it can get more complicated, but first, just in case, reinstall drivers. its a long shot, but if you get lucky it will save you alot of pain. in case it didn't help, It's probably a bad vertical output chip. if you have some familiarity with monitors and decent soldering skills you could probably fix it yourself, but I would advise looking into taking it to a shop, or at least find an experienced hobbiest if you're not yourself. It's a pretty straightforward fix for someone who knows what they're doing. good luck.
Posted on Apr 03, 2006
  • 93 Answers
SOURCE: full screen on monitor
you can use the menu and adjust the vertical size.or if did already but it doesn't work,try to open your monitor and look for a trimmer in the vertical section,then try to rotate by these you can adjust now the vertical size
Posted on Oct 18, 2007
SOURCE: acer top and bottom of screen is blank
on the monitor press the menu button in that adjust the horizontal and vertical size correctly ... you will having the option to adjust in the menu button ...
or you may be using some low resolution check the display properties set your resolution to 1024 x 768 ...
this will fix your problem ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
Posted on Aug 12, 2008
chinna_1977
  • 65 Answers
SOURCE: LG STUDIOWORKS 500g - FULL SCREEN NOT GETTING DISPLAYED
It's Loose contact Problem in Vertical section
Pl corrected dry points all over the vertical section.
Posted on Oct 10, 2008
skotkolr
  • 558 Answers
SOURCE: no showing the full screen. Top + bottom 1 and half inches dark
your system display settings are set to a wide screen setting on desk top right click then properties, right had tab display then set the screen size to a square shape like 1024 x 768.
Posted on Feb 17, 2009
Confusion installing drivers on Dell Latitude 120L laptop running XP
to run duel screens you will need a graphic board that has 2 outlets
I run a nvidia board and it has a dvi and vga outlets connected to 2 monitors
open up the control panel and go to display
that will show 2 screens and they will be identified as 1 and 2
the printing will be for one screen and it will say -make this my main screen
further down will be a dropdown box that will have extend screen
click on that
as for the screen size or pixal settings click and drag the slide button up to the top and click on apply
any way in that display section you can move and click on different settings to get what you want, always apply to fix the settings selected
it will come back with a message --do you want to retain the settings and if you are happy --click on yes
regardless of what you choose , you can always reset at a later time
Feb 26, 2017 | Aoc Monitors AOC e2752Vh Glossy Black...
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
Dec 05, 2012 | AOC 19" LED Monitor e950Swn Black
AOC i2353 has border around displayed image, not running at full 1920x1080res?
Had the same problem! Solve it: go to the AMD catalist and choose advanced look. then inside the digital display setting you'll see scalling option that will show 10% . Set it to 0%. Done!overscan.png
Oct 15, 2012 | AOC I2353PH New
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
The left side of the computer display is blank. How can that be fixed?
Please let me know what make and model of computer and computer monitor you are dealing with.
In general, without having any additional information, I can say that on computer monitors there are settings to change the picture width and height controlled by buttons on either the front, side or top of the monitor. There is generally a menu button, buttons to move the selection and then the settings.
If you are dealing with a laptop, there are some with backlights, or small light bulbs in the LCD that light up the screen.
You can also go to your device manager and look to see if your video and display devices are shown to be working correctly. A faulty video card, display module, video driver or display driver could be to blame. These have to be ruled out to find the actual problem. Can you hook up to another monitor and get a full display?
Some of my answer depends if you are seeing the full image of the windows desktop on half of the display or only seeing half of the image windows desktop on half the screen.
Please give me more detail about the problem you are experiencing and I will be able to find a more specific answer for you,
I will wait to hear from you,
Brian
Jan 16, 2011 | Husqvarna Sewing Machines
Has a blue dialog box that says out of range
Hello
It sounds like you have two separate problems.
The first one is the "out of range" issue. This means you are trying to display a screen resolution that is too high or too low and your monitor cannot display any image. Reboot your computer with another monitor or into safe boot mode and change the resolution to an industry standard (800x600 / 1024x786) and then see if your monitor will display the image. Once you can see the image on your monitor, you can make adjustments and it will automatically revert back if you cannot see the new display settings.
Update your video graphics card drivers to get the best possible resolution.
As for the buttons on the front of the monitor not working, this may be caused by the "out of range" issue above. It could also indicate that your monitor may be going bad. Try the above steps - if you get no image from the monitor, try moving the monitor to another known good computer and see if the button functionality works after it displays an image.
May 04, 2010 | AOC 193FW LCD Monitor
I have purchased an AOC 22" monitor to connect to my laptop >>>>>i have connected it but it does not display. What is wrong.
Depending on the laptop. Most have a key on the keyboard to toggle external display. Usually, you have to hold the function key [FN] then push the external display toggle.
Feb 23, 2010 | Computers & Internet
On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Aug 29, 2009 | AOC 917Sw 19" LCD Monitor
Pincushion and h size problem on aoc 17" 771s
one of the buttons on your monitor is partially shorted. trust me, ive encountered this problem many times.
Jan 03, 2009 | AOC CT720G 17" CRT Monitor
Monitor display image
press control+alt+down(arrow key)
May 14, 2008 | AOC A15X221 15 in. LCD Television
Computers & Internet Logo
338 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
