Question about Panasonic KX-FLB751 Plain Paper Laser Fax
Cover open message
Panasonic printer is showing cover open even when it is closed
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Just check may bi cover is not locked properly .and also check there will bi a sensor having some bad sector .just clean it properly.or replace it MIA AKHLAQ
Posted on Jan 03, 2009
My printer is giving message that you rear cover is open for that what to do?
SAMSUNG SCX 4521 PRINTER BACK SIDE COVER IS OPPEN SO PLEASE CLOSE THE BACK REAR COVER & CHECK THE PAPPER JAM IN REAR COVER & AFTER CLOSE THE REARE COVER THEN AFTER SEE THE ERROR YOU CHECK THE BACK COVER SENCER & SENCER PCB
May 01, 2014 | Samsung SCX 4521F All-In-One Laser Printer
It shows "remove any obstruction
Open the printer cover and access the cartridge area. Remove both cartridges. While the cover is open, check for any obstructions in the cartridge carrier's path. Check for any loose transparent strip (encoder strip). If cartridge area clear from these, Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, open the printer cover and reinsert the cartridges. Close the cover and try to print again.
May 27, 2011 | Lexmark X4650 InkJet Printer
Its showing "close ink cover"
Hi there!
The message "Close Ink Cover" means that the cartridge door is not closed securely.
-please open the ink cartridge cover and make sure all cartridges are installed correctly and then close the cartridge cover. That should clear the message on the screen.
Hope this helps!
May 08, 2011 | Brother DCP 165C Compact Color Inkjet...
Cover open samsung scx-4521f
There is probably a broken sensor on your printer. Try to open and close the cover some times it works. If not you need to bring it to samsung technician for fixing it.
Apr 21, 2011 | Samsung SCX 4521F All-In-One Laser Printer
When lid is up, cartridge carrier is not showing.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Apr 20, 2011 | Lexmark X4650 InkJet Printer
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
Panasonic DP 2500 photocopy machine from you a few months ago. I cleared a few paper jams and have not had a problem until now. The message on the machine says to ?close the ADF cover?. I do not know what...
the top cover that opens to the left normally has a small piece of plastic that slots into a sensor toward the back of the adf. this small piece has broken off so the machine thinks the adf is open. an engineer would need to replace the door for you.
Jul 22, 2010 | Panasonic Workio DP-2500E Copier
Machine shows "cover open"
No error code ## 343, but will not print now. How can I change from English to Finish languages in printer?
Jul 08, 2010 | Canon SmartBase MP360 All-In-One InkJet...
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Panasonic KX-FLB751 Plain Paper Laser Fax Logo
136 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
