My emac has a bad case of screen jitters - Computers & Internet
    Novelist:
    Champion:
  • 233 Answers
You might try changing the screen resolution in > preferences> display. If this doesn't help the CRT in the computer may be going bad, in which case it may not be worth the expense of fixing.
Posted on Dec 17, 2008
LG TV has video jitter on bottom of screen
check all your hdmi cables. wiggle them, and see if it changes, or try new cables. you likely have a loose or slightly bad hdmi cable- this is the best case. worst case, a bad hdmi input jack on your tv, or bad hdmi output jack on your receiver/cable box)
Sep 25, 2016 | LG 50" 5400 Series LED HDTV - 50LN5400
Need to transfer data from old computer to new computer
You have a bad situation. Only a mac repair pro can help you in this case as it's hard to arrange some tools to solve the problem. A pro can gain access to your emac hard drive and free up some space or transfer your data using special tools and knowledge. Thank you and good luck.
Mac Repair Mississauga Apple MacBook screen repair Service MacBook pro...
Oct 17, 2014 | Apple eMac Desktop
My screen jitters
It is not something you can (Repair) Your self. End this sugestion is from a (Technician) With 35 years (Expierance) Under my belt.
Oct 25, 2012 | Sony VAIO VGN-CS220J/W Notebook
Black emac screen
Hi, this could be a number of things but the most likely cause is probably the leaking capaitor syndrome.At about the time these machines were made there was a flood of faulty capacitors throughout the electronics world and the factpriews that made the mother boards for the eMac were particularly badly hit.Did the screen exhibit any flashing or streaking or random freezing before the failure? Thses are typical precursors.
Unfortunately the only thing you can do is to take it to a (Apple) repair centre where they will be able to judge if it is repairable or not.The leaking capacitors quite often ruined the mother-board. If theyu were caught in time they were repairable but .......
If the eMac is still running, connect it to an external monitor and then clone your HD to a blank HD using Carbon Copy Cloner or SuperDuper.
Jan 08, 2012 | Apple eMac Desktop
What causes the image on the screen to jitter
Sounds like bad convergence ICs. They are complicated to replace but a good tech should be able to do it for about $100. Let me know how this works out.
hardrocko
Jan 31, 2010 | Mitsubishi VS-70705 70" Rear Projection...
Screen stays black when i turn on mac g4 desktop
Have you had any screen problems leading up to this? Things like random freezing while moving the pointer or dragging a window, or disturbances to the display like tearing or jaggy edges appearing randomly?
If so then you probably have a faulty motherboard caused by the infamous leaky capacitor problem. This was a world-wide problem but it appeared to hit the eMac particularly badly. You can check it by opening the little panel on the bottom of the eMac (small cross-point screwdriver and 1 screw) and have a look at the capacitors inside. You can see 3 or 4, they are silver cylinders. If they show signs of bulging or any gloop oozing from them then that is the problem. It is repairable but Apple will probably tell you to take it to a repair centre as they don't carry the spares anymore.
Best option is to try a TV repair man as the skills needed are more TV repairman than computer tech related. However - big problem is that given the age of the eMac, there is a good chance that the gloop will have caused corrosion on the motherboard - and that is NOT repairable.
Be prepared that you may have to buy a new Mac. Your data is safe on the HD as that will not be affected - get the TV man to take the drive out for you - the high voltages inside can kill - (better kill him than yourself) and then install it in an external case to run on your new Mac Without being with the machine it's difficult to determine any other problem that it could be.
Nov 09, 2009 | Apple eMac G4 Desktop
Network a G4 (OS 9) to a eMac (OS X)
OK - first, crossover cables let you network PCs together without a switch or router. I would strongly recommend returning the crossover cable and buying a router so that you can use both computers on the internet at the same time.
Second, the eMac monitor can not directly be used as a monitor for your G4 - it's not built that way. However, you can use Screen Sharing on OS X (if both have Leopard) or Apple Remote Desktop software (if you buy it) to remote control the G4 using the eMac.
You will DEFINITELY need a monitor on the G4 in order to set it up at all, so I hope you have that.
Keep in mind that you can buy, for less than $200, an LCD screen that is larger and better quality than the eMac, and it would leave the eMac useful as a second computer. Since the eMac is unlikely to work at all with Leopard, and you'd have to buy Apple Remote Desktop, you're going to spend less money by buying a separate screen for the G4.
Nov 22, 2008 | Apple eMac G4 Desktop
Emac G4 700MHz
Without having the unit in front of me, it sounds like the video component is bad. However, you could have a bad battery in the
computer. Try replacing it... (Cost should be <$12 US)
regards,
Feb 11, 2008 | Apple eMac G4 M9425LL/A Desktop
EMac screen resolution size is only one choice 800x600
1st start it in safe mode.install video driver from motherboard support cd.then start it in normal mode.then you may change your monitor resolution.
Feb 08, 2008 | Apple eMac G4 M9425LL/A Desktop
Constant jitter on screen
DOWLOAD SOFTWER P5VDC-TVM
Oct 19, 2007 | ASUS P5VDC-MX Motherboard
Computers & Internet Logo
David Payne
David Payne
