Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint aquarius hi im hopeing someone will be able to help me when i put washing in the drum it is finding it hard to turn but if its empty it turn's fine
    President:
  • 1,294 Answers
What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Posted on Apr 11, 2007
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Hotpoint Washing Machines
Hotpoint aquarius ctd00 tumble dryer...everything working but drum wont turn
it looks like you need to put the belt back on which is inside the machine. to do this open the lid with screws on back take lid off then you should see the belt inside the machine and where is was before on the drum of the machine. slip it back on and put lid back on and it should start turning again. hope this helps.
Sep 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wm64 loud banging noise when spinning with full load no noise when spinning empty i have found small pieces of plastic inside drum
Several possibilities here.
First and fore most is the drum support or main drum bearigs are failing., more likely to be drum support
The pieces of plastic you refer to are from inside the outer drum, because what is happening is the inner drum is catching the outer drum, and breaking the plastic inside.
You are going to have to strip it down to determine the exact cause, what I expect you will find is that the alloy 3 legged drom support has corroded away,a nd the drum has come loose.
Hope this helps you solve your problem
Nov 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hi, i have a hotpoint aquarius 6kg wma50, my
Have you checked for blockage in the pump. Or the have been some problems with a ball that sits in the hose between pump and the drum. This can block the water. Check this berfore purchase new pump.
Jul 26, 2009 | Washing Machines
Aquarius washer drum stuck
sounds as if the drum bearings have gave way was it noisey b4 this
Jun 06, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Am trying to replace the belt on a hotpoint aquarius wf240 washing machine. I have removed the 2 bolts which appear to hold the motor in place ( 1 bolt on each side). However the motor still will not
Hi. The motor is non adjustable on this washer. Tilt washer forward, get someone to hold it steady, and put belt round motor pulley first, then slip belt on drum pulley, and slowly turn drum by hand, feeding the belt on as you turn drum, be careful not to trap fingers, as it is very tight, this is normal, as the belt is a stretch type, this is the reason the motor is non adjustable. Please rate my advice. Thanks.
May 30, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius wd440g washer/dryer
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Jul 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Wd63 does it have a filter to empty for the dryer!?!
Hi there sarah
The hotpoint washer dyrer does not have a filter for fluff
100%
Need any other help dont hesitate to ask
Jan 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
105 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
