Question about Gigabyte GA-P35-DQ6 Motherboard
System temperature too high
Well my system temperature is reaching high temps and I believe when it reaches 50c it causes my computer to freeze causing me to reboot. I would like to know where abouts on the motherboard is the object that falls under the System temperature category.
    President:
  • 2,351 Answers
Do you still have your manual? If not download it from Gigabyte at this link:http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2637
Enter your bios & open manual to page 51, "PC Health Status". Here you can monitor the CPU temp, system temp & CPU fan speed. Notice the manual shows the example of system temp to be 30degs C & current CPU Temperature is at 47degs C. One would think these temps are reasonable. My CPU fan runs between 3308Rpm & 3341Rpm. CPU @ 41deg C & MB @ 31deg C. AMD 64 X2 Dual Core 4200+ 2.21 GHz.
Suggest you try this. If your running Win XP. Open system properties. Click the Advanced tab. Click the settings button under
Startup and Recovery. Remove the check mark to the left of, Automatically restart. Windows should provide an error message if & when the system freezes. This will help in finding what is causing the system to freeze. If your CPU fan is running under 3000Rpm you might consider buying a faster fan or add a case fan to the side of the case to help bring in fresh air to blow onto the CPU fan & PCI-Express card. Here is a decent lace to look for case fans: http://www.xoxide.com/casefans.html
Keep me up to date andr_zero.
Mike
Posted on Dec 17, 2008
Does my 2002 Cadillac Seville SLS have a cooling fan switch, and, if so, where is it located?
Cooling fan switch ?????? Has a engine coolant temp. sensor , That inputs info to the PCM/ECM - engine computer ! The PCM / ECM interpits the voltage signal from software programmed into it as to what temp . of the coolant is . When the engine coolant temp. reaches
The PCM commands the low-speed fans ON under the following conditions:
• The engine coolant temperature exceeds approximately 106°C (223°F).
• The transmission fluid temperature exceeds 150°C (302°F).
• The A/C pressure reaches 199 psi (1372 kPa).
The cooling fans will switch from low to OFF when the coolant temperature drops below 102°C (216°F).
The PCM commands the high-speed fans ON under the following conditions:
• The engine coolant temperature reaches 112°C (234°F).
• The transmission fluid temperature is more than 151°C (304°F).
• The A/C pressure reaches 260 psi (1792 kPa).
• Certain DTCs are set.
The cooling fans will switch from high to low, except when DTCs are set, when the coolant temperature drops below 106°C (223°F).
The PCM turns on the cooling fans by energizing three different relay's .
Watch this video
Relay Driven Dual Cooling Fan Diagnostics
May 29, 2017 | Cadillac Seville Cars & Trucks
"I have a White Rodgers 1F78-151 thermostat and for some reason the system keeps shutting off every few minutes and never reaches my desired temperature i constantly have to set it to off than back to
Is this a gas fired furnace? If so it may be going off because one of the safeties is tripped. There is a high temp safety that will shut the unit down when this temp is reached. The usual cause is low airflow. Check your filters, if these are OK you may have a blocked coil which should be professionally cleaned.
Feb 01, 2015 | Heating & Cooling
Ricoh aficio mp 2045 sc 542
Description Fusing temperature warm-up error
The fusing temperature does not reach the fusing standby temperature of 45C (113F) within 9 seconds [for the B003/B006 (35 cpm)]/14 seconds [for the B004/B007 (45 cpm)] after switching on the main power or closing the front cover, or 40 seconds after reaching 50C the fusing roller does not reach warm-up temperature. Causes • Fusing lamp defective • Poor fusing unit connector • Thermistor warped or broken • Thermostat has tripped • BICU defective • Power supply board defective
Jan 04, 2015 | Ricoh Office Equipment & Supplies
TT16DKXSQ04 refrig
Having the setting up too high, don't see that mentioned, try a lower setting. What temp is the unit reaching, if less than what it is calling for it will run forever, if warmer than normal, perhaps you struck a refrigerant line when cleaning and there is low freon and system is trying to reach a temp it can never reach due to low freon?
Otherwise the sensor is bad, making it try to reach a temp out of range of unit.
Sep 08, 2014 | Refrigerators
Caravan does't reach operating temperature
No one ever said new means good. Try another thermostat. Make sure it is the recommended temp for the vehicle. I would spend the extra money to buy a dealer thermostat. What controls temp is restriction of flow thru the system until a set temperature is reached and the thermostat opens. Has to be a thermostat.
Dec 31, 2013 | Dodge Caravan Cars & Trucks
Hard cold start for 99 intrepd w2.7l/ ok hot/set check eng lite
Check your Fuel Filter, especially if your in a cold climate that has already reached freezing temps. If you have any moisture in your fuel system and the freezing temps have arrived the filter and injectors can freeze up slightly causing this type of problem. If this was happening in warmer temperatures check the fuel system for pin hole leaks that could be allowing the air into the system.
Nov 23, 2011 | 1999 Dodge Intrepid
My Gateway laptop p-7805u Intel Duo P8400 @2.26GHz beeps sporadically. How do I know what the problem is? I have a temperature indicator and it beeps anywhere from GPU 45 to 49C, Core 0 59 to 80C and...
if the bios checks the GPU and is set to warn when it is higher than 45 you can have the problem you say. most gpus idle aroundn 50C but when used for games or lots of motion can reach 60C. adjust the monitor to above 60C if you can.
the CPU can but should not reach 80-86C this is a high level and dangerous. you will want to see why your system is not gettign sufficiant air flow. Many of the Duos have heat issues and the designs of the laptops are not enough. A cooling pad is a welcome investment
Feb 12, 2010 | Gateway CX2610 Notebook
Sir,i use p750 ingersoll rand compressor and we are experiencing over heating from the radiator upto 150 degree celcius. what are likely causes ?
A possible reason for the problem may be a plugged radiator or cooler. As oil circulates through the system, it gets hot and foams up as it foams up, it will boil out, so that oil is lost in the foam and then the oil level gets lower and lower and the foam hardens up in the orifice tube and connectiong tubes. This all can be started with dirty air filters that restrict the system. check the air filters, flush the radiator and check the cooler, change the seperator filter and use approved oil as that detergent levels in the oil cause it to boil faster and foam up. Also check the fuel pump for leaks at the base, try spraying soapy water and look for leaks, this will also cause the engine to heat up.
Feb 10, 2010 | Air Tools & Compressors
Well my system temperature is reaching heats of 50oc under load and I believe it is making my computer freeze causing me to restart. I was wondering how exactly this temperature is measured and where...
Many motherboards take two temps. Motherboard temp and CPU temp. CPU temp is the most common problem. Check there first. You might need a faster fan or a larger heat sink. Also make sure the pc isn't enclosed in anything. It needs to have air moving around it on both main sides, the front and back.
Dec 17, 2008 | Gigabyte GA-P35-DQ6 Motherboard
System temperature too hot
Its measured in Celsius. Meaning alot higher in Fahrenheit. That would be the Processor.
You are looking for something that will be Square or on a Card that is in the motherboard.
Gigabyte GA-P35-DQ6 Motherboard Logo
309 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
