Question about Sigma EF-500 DG for TTL Flash
Under exposing, especially when bouncing & diffusing
Bought this new for my brother's EOS 400D, was mostly intermittently underexposing. I gave him my 420EX which works flawlessly, and I have now pinned down the problem on my 20D as follows.
1. Straight flash works ok, flash zooms ok.
2. When bouncing of roof, walls, ALWAYS underexposing (compared to my weaker 420EX), virtually useless results.
3. When using the built in -28mm diffuser, massive underexposure.
Dealer initially said he was willing to exchange it, now "to long time has passed".
  • Sandy Bear Dec 17, 2008
    Oh, E-TTL is active in all examples above...
SOURCE: Problem with underexposed pictures
I've got the same problem with my new ef 500 dg super and my ef 530 dg super. It occurs on all nikon camera's I could get.
D70, D80 and Fuji S5 Pro. I don't have this problem with an old (4 years) sigma ef 500 dg super.
I will try to contact Sigma for this problem.
Posted on Jan 07, 2008
ranger25
  • 72 Answers
SOURCE: Glass Diffuser 54" Ceiling Fan Cruiser
Yes, at the local Home Depot or Lowes they should have them. They're usually anywhere from 3 to 8 dollars unless they're specialty (stained glass or something like that) ones.
Posted on Jan 27, 2008
SOURCE: Flash not automatic on bounce
What kind of battery do you use?
Have heard about similiar problems when using battery on 1500 milli ampere.
Posted on May 19, 2008
SOURCE: no air coming from air diffuser assembly in fridge
through other postings on your web site I was able to determine that the return air flow vents for the refrigerator (diffuser air) was blocked due to frost. I defrosted the unit and it is working fine now.
Posted on Jan 06, 2009
PartsCenter
  • 125 Answers
SOURCE: how to install a impeller kit for my jacuzzi water pump
The lip faces away from the impeller
Posted on Feb 24, 2009
I have a Canon EOS 400D. Photographs are appearing with what looks like round marks or bubbles in the image. I've cleaned and changed the lenses but it still appears. I am wary about cleaning inside the...
There is a mode in which you can lock up the mirror and shutter blades so that the sensor is exposed. Use a appropriate cleaning kit and avoid touching the sensor.
Jan 01, 2010 | Canon EOS 400D Digital Camera
Canon xti and canon 420ex flash giving
Make sure the 420EX is set to E-TTL and set the camera to "P". If is need of more light, increase flash exposure to +1 or 1.5.
Oct 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Recently my canon speedlight 580 EX II TTL has been acting up...especially in low light situations. About on in 30 shots actually has enough light in them...the rest of the time the shots are...
that the camera/flash set-up I use ... there are many variables - iso/metering setting/shutter settings/flash settings .
If it's a flash function problem, try this to isolate it - first, with the diffuser/reflectors tucked into the flash head, and the head straight up, with the flash set in master mode, turn it on and look on the back screen. push the mode button til you see the ETTL in the upper left of the screen .. then press the set button in the center of the dial and the nuber in the center of the display should flash (+0) while the light is flashing, rotate the dial to change the setting (i usually under power by 1/3 stop. Play with the exposures a few times to get the feel for what the EV shifts do to your exposure. generally speaking, for interior low-light, i prefer to bounce off the ceiling (if low ceilinged), if there's too much direct it will give you an uneven and predominantly underexposed image.
if you prees the mode button you will come to the same options for adjusting the output in manual mode, but it will not work with the autoexposure in the camera.
Try playing with the ETTL settings
I think the problem may be that you have somehow altered the power output setting on the 580.
Sep 23, 2009 | Canon Speedlite 580EX II TTL Flash
Turning on infared on my Canon EOS 400d DSLR
To the right of the LCD there are some small buttons. Right underneath the AV button, there's one. Press it, and you get three choices. The right most choice is self timer and wireless. Choose that option. The remote needs to be pointed towards the eye on the camera. It's on the front, on the "motor grip". And if you leave it on that setting too long, it "falls asleep", and you have to wake it up again before it'll fire remotely.
Mar 28, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
EOS 400D Digital Camera Software
Hi
If you bought your camera (400D) new it would have come with RAW conversion software on a disk. You can start by installing this. To get the photos off the camera you should be able to plug it in vis the USB cable that came with it. The better way would be to buy a card reader. This is a lot quicker, save on battery wear and tear, or save you plugging in the power.
Alternative software would be to buy Adobe Photoshop Elements for the RAW processing. This is a good start for most people.
Regards
Jul 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D LCD screen problem
There is no live preview mode on this camera. I am not sure if that is what you are referring to, but you can only use LCD for review and menu, not as a viewfinder.
The new Rebel XSi is the only one in the rebel series with this new feature.
Hope this helps!
May 22, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D
The camera is working again. I took out the battery, with the the on/off switch, off. I then swtiched the On/Off switch On. I then put the battery in ,and the camera turned on.It then gave me an ERROR 99. I then switch it off and on again, and it is still working.
Apr 28, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Transfer from XTI camera to PC
Seems to be a common problem with the XTi. Some say it's designed to underexpose to avoid washing out the bright parts of scene. Personally I found it a pita. I had to PhotoShop each shot.So I sent it back to the repair facility. They re-calibrated it. Now it works fine.
Sep 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Lighter Band On top of the picture
It's a shutter problem--it's not the amount of light per se that causes it, it's the shutter speed. This issue often only shows up at a few shutter speeds. My 1dsII does it around 1/125, although not nearly as badly. Apparently the shutter is bouncing or hanging up at the end of its travel. Sorry, it's either send it to Canon or learn to live with it.
Sep 14, 2005 | Canon EOS-1Ds Digital Camera
Sigma EF-500 DG for TTL Flash Logo
46 people viewed this question
Top Sigma Cameras Experts
M_Butkus
Steve
bhargav
Are you a Sigma Camera Expert? Answer questions, earn points and help others
