How do you adjust the headlight?
SOURCE: 2002 harley davidson ultra classic setting the clock
Turn the Bike on and the Radio off and then follow the buttons on the screen. Most people think you have to do it while it is running and this does not work
SOURCE: removing harley davidson ultra classic gas tank
Drain the fuel either by siphening or removing the cross over tube at the front of the tank and letting it drain that way or just block off those cross over lines and leave the fule in the tank for removal.
0) remove seat
1) drain fuel
2) undo cross over line (bottom front of gas tank.
3) shut off pet **** and remove fuel line from pet ****.
4)there should only be 2 bolts holding the tank on, one at the top front of the tank and one at the back of the tank.
All in all a pretty easy (but possibloy messy) job.
SOURCE: Where is the oil pan plug located on a 1999 Harley
No oil pan plug, it is a sump system. Just find the oil tank, drain it, change the filter.
