Question about HP Computers & Internet
C_437.nls file is corrupted and windows cannot start, i also do not have the windows installation disc.
  • 51 Answers
Here's how to fix this problem:
1. Boot your computer from your Windows installation CD.
2. Select 'R' for the recovery console and log on as administrator.
3. At the command prompt type the following:
EXPAND -R D:\I386\c_437.nl_ C:\WINDOWS\system32\c_437.nls
(If your CD drive is different than D: or your primary hard
drive/partition is other than C:, substitute the appropriate drive
letters.)
4. Select yes when you're prompted to overwrite the existing file.
5. Reboot the computer.
Depending on the level of file corruption, you may have to repeat this
process for another file. (I've had to repeat the process for
c_1252.nls as well.)
If it says it can't find teh file,
Use this command instead: expand d:\i386\c_437.nl_ c:\windows\system32\
There is a space in front of c:\
Posted on Jan 15, 2010
  • 111 Answers
Boot in safe mode and run system restore if you cannot boot in safe mode you will have to get a disc and reinstall unless you know how to use the repair panel
Posted on Dec 21, 2008
My HP G70-258US (Vista OS) hard drive will only run the computer in Safe Mode. The drive has failed the S.M.A.R.T. I have replaced the drive. After reinstalling the HP software on the new drive and...
i would advise a different os than vista but you can put the old hard drive back in run it in safe mode and by a cheap external hard drive case and transfer the files for the operating system to the new hard drive and then switch the drives back out
Mar 25, 2011 | HP G70-250us Notebook
Error prompt: \WINDOWS\system32\c_437.nls
you have a windows system file corruption on the c_437.nls file which is a national languages file required by windows to run.
repair this problem following these instructions-
1. Boot your computer from your Windows installation CD- ie-insert the CD and restart your computer.
cd system32
then press enter
4. Then type the following:
ren c_437.nls c_437.old
then press enter
EXPAND D:\I386\c_437.nl_ C:\WINDOWS\system32\c_437.nls
then press enter
drive letters.)
process for additional files. To do this follow the instructions above substituting the file name.
//javaftper
Aug 01, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
Samsung N120 Netbook won't start Windows. stuck on black screen.
See if you can download it from Microsoft. It seems to be related to the languge translators in Windows (NLS file).
Jul 31, 2009 | Samsung NC10-14GW Notebook
After Rescue n recovery with F11, i got error messeges & all data
probably not easiest way is get a cd and do a fresh install
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Lenovo ThinkPad T61 Notebook
\WINDOWS\system32\c_1252.nls
You didn't say which operating system. But this usually happens in XP. You have a corrupt start up file.The easiest way to fix this is to boot the machine from an XP cd. When it asks you if you want to install windows click enter. Hopefully it will show that there is an existing copy of windows. Then it will tell you to hit R if you want to repair the existing copy of windows. If you have succeeded this far it is pretty much automatic after that. The repair install will ask for the product code (on the MS COA sticker) Hope this helps!
Rockman10
Jun 17, 2009 | Lenovo ThinkPad Z61t 9443-XAU PC Notebook
My computer(Compaq 5301RSH 5000 SERIES) won't start because "Windows could not start because the following file is missing or corrupt: system32hal.dll. Please re-install a copy of the above file." What can...
Alright..Not a big problem..Generally happens due to some files corrupting. Put your Windows CD in the drive, boot form the Disc and choose to repair the operating system. The problem will be solved.
Thank you!
Sabharish
Jun 04, 2009 | HP Compaq Presario S5100NX (DM172A#ABA) PC...
Turn on computer- Wont boot Please Help!!!
Borrow an XP install disk from anyone. Since you are not installing a new copy you don't need a keycode or serial number.
I am willing to bet however that you are going to need to do a re-install having lost this file to corruption. The source of the corruption is the unseen elephant in the room. Be aware that if you can get the computer running move any personal files to new new folder on the C drive. One that you create and not in 'My Documents' or any other windows created folder. When re-installing windows any/all windows folders are deleted and new, empty ones are created resulting in your loss of everything.
1. Boot the laptop;
2. press F12 to go to boot menu;
3. Selected CD/DVD-RW Drive;
4. Press any key to boot to CD; worked fine...
5. Press R to repair;
6. At the recovery console, selected 1: C:\WINDOWS and hit enter;
7. This brought me to C:\WINDOWS> prompt;
8. Typed this C:\WINDOWS> EXPAND -R D:\I386\c_437.nl_ C:\WINDOWS\system32\c_437.nls
type exit
9. And got the error message: The parameter is not valid. Try /? for help.
IF the disk is in the D drive then use this command instead: expand d:\i386\c_437.nl_ c:\windows\system32\
Oct 19, 2008 | HP Compaq Presario 6310US (DA201A#ABA) PC...
Os booting problem
Try running the repair console from the CD.. fixboot, Fixmbr, And chkdsk /p may repair the missing or corrupt file other wise you can replace/install the missing file with another good working system and put the drive in an external enclosure.
Jul 27, 2008 | Microsoft Windows XP Professional for PC
Error 437
Hi, I did a Google on your error 437 and it would seem that this problem pops up only if: 1. using SYMANTEC (Ghost); or 2. using Original Toshiba Restore Disc. where possibly: a. the restoration procedure needs to write a log file somewhere (A:?) which does not exist and therefore waits; b. the restore disc is probably corrupted; and/or c. the Ghost image is corrupted. A few things you can try: * On another computer, check the integrity of your recovery disc; * Get hold of another Windows installer and do a complete, clean, fresh install (you will have to use your original Win numbers @ the bottom of your laptop). You will only need the recovery disc for your hardware drivers; or * Call Toshiba Support and get assistance. I was made to understand that they provide replacement Recovery Disc (>50USD). Hope this be of some help/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Aug 27, 2007 | Toshiba Qosmio F25-AV205 Notebook
Computers & Internet Logo
896 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
