Question about Mitsubishi Diamond Pro 700 Monitor
Screen fades or goes magenta fog upon mouse click to new page
My 17" Mitsubishi Diamond Pro 710 has suddenly started to go from normal Window XP colors to a soft magenta hue, sort of a faded magenta fog, when clicking the mouse to go to a new screen. It occasionally goes black too. If I turn the monitor off for a few seconds and power back up, the screen returns to its normal strong colors and picture. I've been using a Matrox G450 video board plugged into a Tyan S1590S Trinity MB. Any ideas? Solutions?
jomaru
  • 337 Answers
SOURCE: picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Posted on Oct 11, 2006
  • 1153 Answers
SOURCE: Mitsubishi WS-48613 No Video
If you have no video and audio then IC9c25 on Sig. Bd.
Posted on Jan 14, 2008
  • 395 Answers
SOURCE: 60" Mitsubishi Problems
1. NO VIDEO, BUT HAS VIDEO WITH PIP ON. CHECK C763 (1UF 50V) ON THE BASE OF Q715, LOCATED ON THE UCOM-PCB. 2. NO MAIN VIDEO, THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB. THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PART # 181P504090. (CHECK ALL 'SMD' ELECTROLYTICS AND TRACES ON PIP) 3. NO MAIN OR PIP VIDEO, CHECK C7014, 47 UFD 16V ON THE PIP PCB. PART # 181P502060 4. CHECK FOR 7.2V DC ON THE BASE OF Q7003, IF LOW OR MISSING. CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PART # 103P401050 5. SUSPECT R2045/R2048 (6.8 OHM 3W) FOR OPEN/RAISED VALUE. LOCATED ON PCB-SIGNAL AT 5V REGULATOR IC2003 PIN 5.
Posted on Jan 21, 2008
Slinteriors
  • 8617 Answers
SOURCE: TV PICTURE ON THE HD 1080 MITSUBISHI
Your color wheel may be cracked or broken.
Posted on Jun 04, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi VS-5075
Your standby power supplies are most likely at fault you should check the low voltage regulators and see if they are functioning they may be defective.
Posted on Jun 16, 2008
Y compaq pressario v2000 goes from black screen to intermittent normal screen. The black screen is on the computer 80% of the time and then the pics fade in and out
The screen on your laptop goes black after every few seconds.
It resumes after a mouse-click or after a key-press.
Solution
Click on Start --> In search bar, type power options and press Enter.
"Select a power plan" window will be opened.
Click on "Change plan settings" next to "Balanced (recommended)".
In "Turn off the display", select "Never" from the drop-down menu under both the options "On battery" and "Plugged in".
Now click on "Save changes" button.
hope this helps
Nov 20, 2012 | Computers & Internet
How to fix how much the wheel scrolls
If you are a windows user then follow the below steps:
Click on Start Menu
then select Control Panel
in the control panel select the Mouse option
and when you double click on Mouse a new window will pop up
on that window click on WHEELS
and there you can set the desired scrolling with mouse wheel.
Thank You
Aug 28, 2012 | E-Machines Computers & Internet
I want download driver for Mitsubishi Diamond Pro87TXM monitor.
After a google search i found these drivers, http://www.nodevice.com/driver/company/Mitsubishi/page2.html
Hope it helps
Steven Cumming
Please leave positive feedback :-)
Jun 05, 2011 | Mitsubishi Diamond Pro 87TXM 17" CRT...
Arc mouse - click a window, everything fades to the back
my arc mouse just quit working, Try putting it in the freezer with the USB. Leave it in for a while. when you take it out, it should work. it did for me
Jul 11, 2010 | Microsoft ARC Mouse
Screen fades to white, everything freezes, then returns to normal
My first thought is a video inverter.
Install an external monitor and see if the problem persists.
If it doesn't then it is the LCD on the laptop.
Good luck
God Bless
-Carlos:
Jun 19, 2009 | Compaq Computers & Internet
E-yama monitor "out of range"
The fix was pretty easy in the end.
Instructions are based upon Windows XP Pro OS.
Re-boot computer but inerrupt start-up by pressing F8 (option will vary between computers)
Select SAFE mode but with VGA option in order that the screen will actually display.
Once fully loaded click:
Start
Control Panel
Appearance and Themes
Display
Settings
Using the mouse cursor adjust Screen Resolution sliding scale until the ratio matches your monitor e.g. 1280 x 1084
Then click Apply and OK (important to do it in this order otherwise changes will not be saved)
Reboot as normal and the monitor should now display correctly.
May 11, 2009 | Yamaha iiyama 17NE1-S e-yama 17" LCD...
Monitor picture fades out.
I thought my problem was originally monitor related. However since I posted, the picture disappeared altogether, and my PC wouldn't even start to bootup. Fearing my mobo may have died I removed the hardware components, cleaned then re-assembled them. After all that, it turned out that my graphics card has a tendency to become slightly unseated. Once I was aware of this problem booting up resumed normally. It seems that the problem of the fading monitor picture seems to still occur, but soon after I use the machine after 'hibernation' state, and even then it doesn't always occur if I do use hibernation. I haven't used hibernation for a little while and so far the problem has not returned
Mar 28, 2009 | NEC Mitsubishi Diamond Pro 920 19" CRT...
Dell latitude C840
try using the usb mouse then go into control panel>system>hardware>device manager. Click on the +sign next to touch pad or pointing devices and right click on touchpad, then click on uninstall. Reboot the computer, unplug the usb mouse and the touchpad should be picked up as new hardware and be re-installed.
Dec 08, 2008 | Dell Latitude C840 Notebook
Seems like down or pgdn key is stuck,
Follow these instructions exactly to correct your problem.
Right click the shortcut icon for IE next to the Start button, choose Properties, change it from 'normal' to 'maximized'.
Now open it.
Now right click any link on the page, choose Open In New Window....don't maximize it....instead, use the mouse to resize it to what you want it to be.
Now close the FIRST window you opened, and then close the new one you just resized.
Reopen IE from the shortcut icon again, and all windows from now on will be the size you chose and created.
Please vote if you found this information helpful.
Thank You
Apr 20, 2008 | Toshiba Satellite A135-S4527 Notebook
Screen blinks - sometimes shrinks & disappears and then re-appears
just do this, resolder the whole circuit board and crt board.
Mar 12, 2008 | Computers & Internet
Mitsubishi Diamond Pro 700 Monitor Logo
65 people viewed this question
Top Mitsubishi Computers & Internet Experts
Alun Cox
Argospete
Argospete
john h
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
