Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
I dont know how to undo the top to re-insert the twine
  • Anonymous Jan 17, 2009
    only one of the two twine holes has twine out of it is this normal and how do you refill/ replace the twine when its used up? cheers
  • billrchtn May 11, 2010
    left to right, I assume is "clockwise", right?
    Do I need to push in knob before turning. When I turn clockwise it just goes around and does not engage. When I turn it counterr-clokwise it engagesd but will not turn- too tight?
Twine running over end of bale
The twine arm has to be adjusted If this can't be done maybe the twine arm is bent and needs to be re-shaped so it does not go off the end. But first check the adjustment. It should be in your operators manual
May 20, 2015 | Garden
Ford focus front strut replacement
basically remove the wheel ( after placing the vehicle on jack stands). remove the bottom ball joint connection ( bolts or ball joint with a ball joint splitter) use 2 spring compressors and close up the spring mark one bolt in the engine bay at the top of the strut so you know where the unit goes on reassembly The bolts control the wheel alignment)undo the bolts and drop the unit out the bottom. undo the nut at the top and release the spring clamps. Lift the spring and top plate of the shaft. Undo the insert nut and remove out of the tube. Insert new insert and reverse the procedure. A workshop manual ( genuine or after market will have the procedure in full with photos)
Jul 25, 2014 | 2000 Ford Focus
Welger ap 53 baler
My guess is that there is some kind of bind that the twine is in between the spool of twine and the knotter... resulting in the twine being continuously too tight for proper tying. Check for restrictions and then make double sure you've cleaned out ALL of the bunched up twine and twine ends... Are you using the correct twine??
Oct 30, 2013 | Garden
I seen to be having trouble sourcing baling twine for our b46 inter baler that isn't synthetic, is the old sisal twine still available anywhere?
Go on the web and type in sisal rope and twine in the google and see what you get. You should get manufactures of sisal /hemp rope and twine.
Oct 06, 2013 | Cars & Trucks
String tensioner and knotter on new holland baler 319
I would say first check the twine tensioners where the twine comes out of the box it's held in. They are simple spring loaded slip tensioners, make sure both have the same tension. From there check all the twine passages for rust or servos
Jul 09, 2012 | Garden
My exhaust came a part but i dont know exactly what part it is or how to fix it. its dragging the ground
get some old wire i have used my trouser belt and tie it up to cars body some where ?anything that you can find or buy at shop even twine.....good luck dirty job ...
Sep 07, 2011 | 2001 Mercury Cougar
I am getting a nice Hamilton Beach Slow cooker. I would like to make some sort of strap or thing to help keep the lid securely on the crockpot bowl while traveling with the slow cooker. Any ideas would be...
Use a bungee cord or heavy twine looped under the handles on the side and crossed over the top. If the handles are not large enough to hoid the cord use two bungee cords wrapped from the bottom of the pot over the top with one crossing over the other at a right angle. If you use heavy twine it can be tied to the handle of the top to keep it from slipping off.
Dec 15, 2009 | Tools & Hardware - Others
One of the baffles broke off the tumbler and need to replace it
correct no repair guy neede unplug the unit so you dont get electrocuted happen to me once dont let it happen to you. remove the front panel than undo two screws at top of cabinet to release the top rotate the drum so the baffel you are replacing is at the 12 oclock position insert the baffel rub the screws thru the factory holes at top of unit if the holes are stripped dont be afraid to throw a washer in with the screw and dont over tighten because they will stripp out the plastic baffel . reasemble and your done takes about ten minutes
Aug 13, 2009 | Maytag HYE3658AY Electric Dryer
I have a ryobi weed eater and the twine locks up and wont release
There is really no solution to this problem -- it is inherent in weed **** -- I have extensive experience with this phenomenon, spending many hours trying dozens of approaches. If you need a **** my suggestion would be buy a new one -- it'll get you through a season or two...
Apr 19, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
83 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
