Question about Goodman CKL36AR36 Air Conditioner
OUTSIDE UNIT TURNS ON ,BUT FAN WILL NOT RUN.
MY OUTSIDE UNIT TURNS ON, BUT THE FAN WILL NOT RUN.
  • 2 more comments
  • Anonymous May 18, 2009
    my fan will not turn on outside in my air conditioning unit outside. everything seems to work inside my house but all i hear is a buzzing noise coming from my air conditioning unit outside.what' s the problem...
  • verronfew May 11, 2010
    clarification outide unit just replace compressor thinking the person hook up wiring wrong
  • Dennis Boxerman May 11, 2010
    Have the capacitor checked. They usually go bad before the fan motor does. Some units have "Dual" capacitors. That is, one capacitor with 3 terminals usually marked "C" or "Common", "Fan", and "Comp" for compressor. It is possible for one side to fail and not the other.
  • Stephen Evans May 11, 2010
    Which fan does not run? The one in the furnace or the one in the outdoor unit
    Sergeant:
  • 340 Answers
Bad motor? faulty thermostat? turn fan switch to on still no motor you'll need a volt meter to figure out what is wrong or hire somebody with a meter who can fix it hvac contractor.
Posted on Jun 19, 2009
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
My rheem a/c unit turns on but the outside fan does not ? is there a reset button on the fan? we had an electrical storm
You need A new run capacitor that is found in the outside unit it is silver in color and tells you on the cap what micro farad it is for example 45+ 5.
Sep 07, 2014 | Heating & Cooling
I have a 901650 intertherm and the fan outside turns on but the air conditioner inside does not work. What could it be?
!st off, do you mean the indoor unit does nothing period as wont run? or wont cool?if it wont run, the checking breakers/fuses etc is a waste of time, as the transformers clearly providing the 24 volts to operate the contactor outside.If you switch your fan to "on" does the fan run?if not, check fan relay, or board or motor/cap etc.If the fan does run with the fan switch set to on, but not in cool mode, the auto function that sends power to green /fan via yellow?cool terminal in the tstat is open and not allowing the 24v to energize the fan relay.
Feb 24, 2012 | Heating & Cooling
My ac unit outside runs when the tempeture gets above what it is set on, but the fan blower keeps going on and off. I switched the theromstat fan to on from auto and it does the same thing, on and off in...
the fan control is not for the fan on the top of your outdoor unit. that is for the blower, you have 2 fans. Im guessing you have a split system, 1 unit inside and 1 outside?? Does the outdoor fan continually run??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Feb 06, 2018 | Ingram GMS90904CXA Heater
Inside fan turns on when outside unit is in defrost mode when heat is selected. This causes it to blow cold air for about 10 to 15 minutes prior to the outside fan starting.
The inside fan will run while the unit is in defrost. The electric heat strips should kick on to help prevent you from feeling this cold air. When the unit is in defrost it is essentially running in the A/C mode. You should make sure the electric heat elements are working then go from there.
Dec 11, 2010 | Goodman PHKJ048-1 Air Conditioner
Fan motor will not run.
Make sure the fan turns freely by hand. It is possible it is overheating and turning off.
May 02, 2010 | Goodman CLJ36AR42 Air Conditioner
How do I know if compressor of my house air conditioner is turning on when I start my air conditioner? When I start my air conditioner the fan outside the house turns on, the air is blowing from the vents...
if the compressor is starting there will be a very small dimming in the house lights,if you go outside to the unit and start it from the outside disconnect when the compressor starts you will hear a whine type noise coming from the outside condenser unit that is the hermetic compressor motor operating,no cold air can be a number of issues,low on refrigerant(not likely on the new sealed systems) a bad motor start/run capacitor(quite likely) a bad contactor on the outside unit that supplies power to the compressor,one leg of the 240volts that supplies the compressor power,the fan will run on 120 volts,but the compressor needs 240 volts check the fuses.breaker in the power panel
Apr 02, 2010 | Heating & Cooling
Can i run the fan on my inside unit if the outside unit is not working
You should be able to run the fan on the inside unit if the outside one isn't working. If you're worried, turn off the circuit breaker for the outside unit. If you don't know why the outside unit isn't working, check the circuit breaker at the breaker panel, check the breaker inside the box that electrically connects to the outside unit, and check the outside unit for a reset button.
Oct 15, 2009 | Heating & Cooling
Motor outside is humming like it on but the fan isn't turning
Sounds like the run capacitor is bad or the bearings or siezing up. Turn the power off to the unit, then spin the fan blade to see if it spins freely, if it does then it's probably the capacitor.
Jun 22, 2009 | Heating & Cooling
Goodman CKL36AR36 Air Conditioner Logo
2,407 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
