Question about Bosch HDI7282 Dual Fuel (Electric and Gas) Kitchen Range
VALLIANT VHR-C HEATER ERROR CODE F.06
Yesterday I started losing pressure on my heater. After spending a very cold night I woke up today having the F.06 error code displaying.
Can you help?
I had a cool hot bath and suddently everything started working again!
Posted on Dec 17, 2008
50 gal. kenmore elite hot water heater model#153.332640 installed 05/01/2011 in February 0f 2017 it started blowing water out of relief valve. temp at faucet 145degrees . rplcd gas contr valve/therm
If the water coming out is really hot, you probably have a faulty thermostat, which allows water to overheat. If water is warm or cold, you probably have defective temp/pressure relief valve.
Jan 12, 2018 | Water Water Heaters
Valliant vuw 282 boiler
check gas pressure and when water gets cold see if voltage to gas valve loose pressure switch wiring could also do it or unit overheating and shutting off
Dec 17, 2017 | Water Heaters
Hi I have error code 30 H1 on my Brivis heater, The problem is the fan sometime speed up itself
my power went out last night and today the heat was not working just the cooler , l turned off the main to the heater and the main power and reset the unit but is still the same
Mar 23, 2012 | Heating & Cooling
Hi fellow mechanics, Today I woke-up and my 98
this sounds like you have a battery that is not 100% charged. charge battery or replace it with a new one and this should solve your problem. ( check the age of the battery -- most car batteries are only good for 5 years max ). with a bad battery you should be able to jump start the car ( but sometimes the battery is so dead that it actually draws down the jumper battery to the point where it will not start the car ). as soon as you get a new battery - double check the alternator output to make sure that it is charging the battery.
you can pop the battery out and have it charged and tested by a local battery / auto part shop and they can tell you if in fact the battery is bad.
c...
Jan 05, 2011 | 1998 Volkswagen Beetle
Went to bed last night with heat woke up today everything house was cold, looked at thermastat it said 63degrees,, checked out furnace it starts up but doesnt ignite, sounds like its in the start up stage...
Does the hot surface igniter glow? If not, it is probably cracked. If this is
a 90% furnace, it could be that yuor intake air is causing the problem.
Dec 27, 2009 | Goodman GMS90703BXA Heater
Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Sep 23, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Cold idle is right at 2k rpm.
could be a vacume leak. check hose for cracks or lose conections.
Jun 13, 2009 | 1997 Land Rover Discovery
I am having a problem with my 2004 Honda Accord Sport 2.2 Diesel- here is my issue-- in cold conditions the heater plug light flashes continuously and the engine looses power allowing only revs up to and...
do you plug it in at night and in cold weather? Sounds like a fuel problem. Check your fuel filter and add conditioner to your fuel. Hope this helps.
Jan 07, 2009 | 2004 Honda Accord
Intertherm heater blows cold air.
do you have elec or gas heat? nat or propane?
Nov 16, 2008 | Intertherm P3RA-048K Air Conditioner
Bosch HDI7282 Dual Fuel (Electric and Gas) Kitchen Range Logo
262 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Joseph Hoffmann
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
