Question about Goodman CKL36AR36 Air Conditioner
HI I have a 30k BTU armstrong unit, compressor runs fine , but condenser fan doesn's start, does it works with the capacitor?
  • wilfredoe Jan 08, 2009
    Thanks a lot, i tested the wires and the electrical signal was present, so i replaced the capacitor and it's working now. Thanks for your help!
    Sergeant:
    Champion:
  • 250 Answers
Many outside AC units have just one capacitor that starts the compressor and the fan. Some units however have two. Just follow the wires from the motor to the capacitor, pull it and test it. Make sure you disconnect the power from the unit by pulling the fuse block first. If the capacitor is good the motor may have siezed up or burned out.
Posted on Dec 17, 2008
I have a Armstrong air condenser unit model SCU10B30A-3 and i cant read the capcitor number to order a new one
did you ever get an answer to which capacitor to order... I'm in the same boat.
Jul 06, 2014 | Heating & Cooling
My condenser fan runs and blows cool air but isnt cooling down the house. Any help.
Check the outdoor unit (condensing unit). Keep in mind, because the condenser fan is running it's not an indication that the compressor is working. On a split system,there's a dual capacitor that serves the fan and the compressor. The capacitor has three terminals.
1. common
2. fan = fan
3. Herm = compressor
This is a common problem; The outdoor fan (condenser fan) runs, but not the compressor (you have to know the sound of a running compressor or you'll mistake it for the sound of the fan) doesn't, because the compressor side of the capacitor is too weak to give it that needed phase angle that it requires to start. If you're referring to the outdoor fan spinning, but no cooling, I can bet the compressor isn't working and needs a new capacitor. Very common problem, I see it all the time. Before you change the capacitor, make sure that you cut the power to the unit, and then use an insulated tool such as a screwdriver and short the terminals together first. A capacitor holds a charge even after being de -energized.Buy the new one with the same exact rating written on it as the old one. Do not mix up the wires when replacing. Write it down or take a picture with your phone
Aug 20, 2013 | Heating & Cooling
Armstrong concept 1200-bad start/run capacitor?
Yes, most likely the start capacitor has failed & should be replaced. You have proven this by being able to hand-start the fan. Once replaced, the compressor should kick in & work fine.
Jul 20, 2012 | Heating & Cooling
I have an amana side by side ars2364aw thet suddenly stopped cooling both sides.The compressor and compressor fan opperate, but the evaporator fan by the coils inside doesn't. I tried replacing both...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Refrigerators
Model ARB220RCC. Compressor and fan doesn't run. Suspect overload relay /run cap How do you test?
heatman101
Aug 29, 2011 | Amana Refrigerators
Refrigerator & frezzer no longer cooling. Compressor is still running , but condenser fan doesn't seem to be working correctly. Does the fan not working full time when the compressor is running...
heatman101
Jul 23, 2011 | Refrigerators
Compressor doesn't come on...defrosting...only fan and light running.
I would suggest you check the starting capacitor and start relay before you give up on your unit. If it is the compressor, that can get very expensive because it is a sealed unit with freon.
Were your condenser grill clean and free of debrie? Was there air flow over the condenser?
Jul 03, 2011 | Maytag Refrigerators
My compressor doesn't turn on. My thermostat
you probably need a start/run capacitor. on the out side condenser unit. about $100.00 to have it fixed,
Jul 03, 2010 | Heating & Cooling
Fan motor will not come on
That thing connected to the capacitor is a booster for the compressor .But if the outside fan doesn't work , the compressor will shutt off on overload because the high pressure in the condenser coil.
First try to replace the capacitor in the condensing unit (it's the only one that works for the compressor and the fan motor) ,but if the fan doesn't start, you need to replace the fan motor.
Sep 14, 2009 | Ruud UBHC Air Conditioner
Goodman CKL36AR36 Air Conditioner Logo
245 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
