Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
Dell 2405FPW LCD Severe Flickring
After about 10 minutes of use my Dell 2405FPW LCD display beings to throw a "fit". The fit begins with a bunch of red pixels showing up in random places. A few minutes later the entire display goes wavy. I've replaced DVI cables and the symptoms are reproducable across a number of different computers.
Here's a video of the display acting up.
    President:
  • 2,992 Answers
The symptom you describe is typical of a thermal problem in the display. It might be in the LCD panel itself, in which case the only repair is to replace the display. It could also be in a component on the main board, and spray component cooler can be used to selectively chill parts to see if it has any effect. Even then, though, it's usually large-scale integrated circuits on these board that have go bad. Even if you can find a source for the part, changing it normally requires tools and techniques beyond almost every shop. Even the manufacturers "repair" these by simply replacing the entire board.
Sad to say, if this isn't covered by some kind of repair warranty, replacement might be your only option.
Posted on Dec 17, 2008
Repair of DELL 2405FPW
What's wrong with the monitor? Most are not worth repairing, FYI.
Dec 17, 2012 | Dell 2405FPW UltraSharp 2405FPW 24'' LCD...
On dell 2405fpw, the screen just went black. Unable to select VGA input. Unable to perform self test.
You need to power cycle your LCD moniter, and then disconnect the display cable of your LCD from your system and see if yor LCD is doing the self test, if that is passing the self test that means there is nothing wrong with your LCD you need to check your system espeacially display adaptor and the drivers, you can also cross check if you have any other monuiter at home.
If your LCD moniter does not pass the self test then it means it has crashed you need to get it repaired or get the new one.
Aug 25, 2011 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Can not select dvi input 2.
Witam
Mam wprowadzon?? blokad?? wy??wietlana jest k??ódeczka gdy przycisn?? jakikolwiek przycisk.Jak to zlikwidowa??.Potrzebny schemat zasilacza oraz inwertera.
Dzi??kuj?? za zainteresowanie
Pozdrawiam
I greet
I have introduced blockade k??ódeczka be displayed when I will press any button.How to do away this.Necessary patern of feeder as well as inverter.
I thank for interest
I greet
Aug 04, 2009 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
On the Dell 2405FPW, is the USB CABLE a special cable?
That isn't a USB cable. The cable you're talking about is an HDMI cable that is used for high quality graphics cards.
Jul 17, 2009 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell 2405FPW - No Picture.
woliphint, Did you try Dell to see if they can do a swapout? You send them your's +$40-$90 and they send you a refurbished same model with new CCF tubes+power supply/inverter? A lot of LCD/FPD displays have been subject to having their SMPS's fail due to poor quality electrolytic filter capacitors that can't endure the thermal stress inside the display. Nearly all brands are affected, not just Dell. See what you get when you search web for 'swollen caps' or 'bad caps in lcd's' or 'lcd repairs' or 'monitor re-capping' or similar type of search. You should always state age or approximate usage hours of the monitor when posting to fixya. We don't know when a 2405FPW was produced and sold. As long as you haven't cracked, shattered, or abused the LCD panel you should be able to get it swapped and or repaired. I'm louie12fix on fixya or lmistyrel@aim.com
Bye for now.
May 04, 2009 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Power Save Mode Problem
under bios menu look for ACPI function and disable it. Should help same under device manager.
Nov 26, 2007 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
LCD Display Flickers
if the replay is OK,the LCD is fine. Then check the CCD that is defective. We can supply LCD and as well as CCD.
Jun 20, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
199 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
