Question about Kenmore 22313 Bagged Canister Vacuum
Replacing the hose
I'm attempting to replace to hose on a Kenmore vacuum. What's the secret to getting the collars off either end of the hose?
  • 944 Answers
Usually these hoses are glued into the collar, and the only real way to re-use them is to carve the hose/glue out of the collar by hand with a chisel. some will screw out with enough force, but dont break the collars trying. If there is glue it is probably a long shot but you could try some acetone (dont get it on your skin - it is very nasty and absorbs through) - try a little on the plastic first and wait overnight to check that the plastic itself will not be affected, then see if the glue will dissolve out of the join - probably not with the type of glue probably used. Another possibility is that the whole hose and collar are moulded as one piece - if so take it to a workshop with a lathe and get them to try and lathe holes in the collar part for a hose. Sears have proven to be next to useless when it comes to spares, so i would suggest try and find a vacuum repair shop locally and just see if they have a hose that fits hanging about. Hope this helps - please post again if not with a photo - might make it clearer?
Posted on Mar 24, 2007
How do I get the collars off at each end of the hose to repair, on a older model 6500 canister vacume.
hoses crew into the ends in anticlockwise direction (LH thread ) the robs are the thread and many from the factory use an adhesive to retain them in position
when replacing the worn out hose , it may be necessary to deform the hose to break that adhesion before the hose can be unscrewed out
Nov 28, 2017 | Vacuums
I have a S3765 Hoover Wind Tunnel with a crack in the hose close to the cannister. I know wires run through the hose and that there are wire connections on either end of the hose. The replacement hose...
If the vacuum has been maintained properly and runs well it may be worth repairing. The hose is pricey but less than a new vacuum. Many new vacuums today, especially lower priced ones are very poor quality and don't last much longer than a year. It appears by the schematics of your model you can replace just the hose section or the entire hose assembly. Replacing the hose only would require removing the ends of your old hose and installing them on the new hose.
Sep 28, 2017 | Hoover S3670 Bagged Canister Vacuum
I'm trying to use the blower part to blow up a air matresss and i cant find my manual need to know hwo to get it to blow...
hi
study how the bag attaches to the machine. usually you turn that bag collar a quarter turn counterclockwise to get that collar off. get ready because dirt will get all over.. then hook the larger end of the hose to where you just took that off. one of those smaller attachments that came with it goes on the other end of the hose to attach it to the mattress or use a small funnel or a straw and duct tape..
jm
Apr 30, 2011 | Kirby Shampooer Shampoo Hose G3 Ultimate...
New carpet has clogged the vacume hose. How do I clear it out
The easiest way I've found is to disconnect the hose at both ends, and GENTLY push a broom handle through it while removing the stuff from the other end. Unhooking it allows you to lay the hose straight. Adjust your head height to where you just hear it hitting the carpet, then raise it one notch. The brush is designed to (and this is a secret the salesmen won't tell you) just touch the top of the carpeting to get it moving so the dirt becomes loose, the suction does the rest. Too low and it just forces the carpet to lay over and traps most of the dirt.
Nov 02, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
Replaced the motor but didn,t take notice where the pieces of foam go back in around the motor
The foam collar wraps around the outside of the fan end of the motor. It's a anti-vibration piece.
Aug 03, 2010 | Kenmore 23313 Whispertone Bagged Canister...
I have a Kenmore Canister Vac. I need to replace
Try forcing a flathead screwdriver between the flange (tab) on the hose collar and the tab on the swivel assembly itself, taking care not to gouge the wires. Saw one solution where they used 2 screwdrivers simultaneously; couldn't do that, but did loosen one side at a time.
Sep 24, 2009 | Kenmore Vacuums
Need replacement collar with 3 pegs connecting
Have been in touch with Rowenta spares agent and am
told no parts available for model RB02, so will have to
improvise
Sep 02, 2009 | Rowenta Vacuums
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister hose
The part number for the hose is 4370993, you can go to sears.com, put int he part number and order it. You will only get just the hose, you have to take the ends off of the old one and put them on the new hose.
Mar 11, 2008 | Kenmore 22822 Canister Vacuum
Replace Kenmore Vacuum Hose
check out this solution http://www.howtomendit.com/answers.php?id=25754
Jun 07, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 22313 Bagged Canister Vacuum Logo
85 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
