Question about Aiwa CSD-TD49 Cassette/CD Boombox
Remote not working
The remote control on my unit recently stopped working. The batteries are fine. Quite simply, where I used to point the remote at the Aiwa and it would control everything I wanted it to, now when I point the remote at the unit and press buttons, nothing happens. Is there any way to fix this? Can I determine if it's the remote or the boombox that's having a problem? Thanks.
  • James Snedeker Mar 24, 2007
    Dear Arpi,
    Thank you for your suggestion. I tried that and indeed I did see a spot. So the trouble is not with the remote.
    Any ideas now on why I can't get the unit to work with the remote?
    Jim
Do you still have this boom box ?
Posted on Dec 08, 2007
    Sergeant:
    Champion:
  • 326 Answers
You can use any digital camera or camcorder in order to check the remote control. Direct the remote (press any button) in direction of camera lens. If remote works you will see the bright spot on your camera screen. If you need more info please advice.
Posted on Mar 24, 2007
Cant get the controller for my fujitsu auy18asd to work with the unit theres no beeping or nothing
An easy way to check the remote is to use a digital camera. Turn the camera on and point the remote at the lens. Look at the camera screen and press a button on the remote. If it is working, you should see the transmitter flash a purple/blue colour. This is not visible with the naked eye so you have to use a digital camera to see it. A phone camera works fine. If you see the transmitter flashing, the remote is probably ok and the receiver board or controller board in the head unit is faulty.
Jun 29, 2014 | Fujitsu 18C1 Air Conditioner
Tip
How to indicate that the remote controls work fine
How to indicate that your remote control works fine?
It simply points the infra red transmitter of the remote control on any digital camera lens ( ON position), press any button of the remote control. It blinks on the screen of the camera, now you can see which button that doesn't work (no blinking)
on Apr 24, 2010 | Televison & Video
Hello, my remote for my Panasonic DMR-EZ47V DVD Recorder / VCR Combo recently stopped working, and whenever I press a button on the remote, I get a message on the display as "RC1" I'm guessing...
Actually, you are sort of correct, in a sense, RC1 means remote command mode 1 (the default mode of your combo unit). There is one way you can try to fix this:
Remove the batteries from the remote, press any button on it to clear its existing memory buffer, then re-insert them or replace them with new ones. While unit is on (no DVDs or tapes in it), point the remote at it - press and hold 1 and ENTER/OK buttons together for 10 seconds, then release.
This should (in most cases) restore full remote command operation to your combo unit - if when you press a channel button on it, and the unit's front channel changes, the remote is now functioning as it is meant to.
The good news is this will constitute any workshop repairs or costs (except perhaps new batteries for the remote if required).
I hope this helps a bit.
Apr 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
Aug 15, 2009 | Heating & Cooling
Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Receiver will not work by remote
Hi!
Here are suggested solutions for you!
Unfortuntately, you and many others have this problem. I will point you in the direction of two "fixes" I have found.
Fix 1 is from Kenwood themselves, per the following quote:
"First try replacing the batteries if you haven't already. If that doesn't help, try resetting the receiver. Simply unplug the receiver, then press and hold the power button on the receiver while you plug it back in. Turn the unit on, and the display should say 87.50 to confirm the reset. If the remote still does not work, use a digital camera as an eye, face it towards the IR of the remote control. Depress any of the remotes buttons; you should see IR flash each time a button is pressed. If not then the problem is with the remote. If the remote works fine, then the problem is with the receiver. In order to determine the cause of the problem, I suggest you take the defective unit to a Kenwood authorized service center for evaluation. You can find information for authorized service centers in your area by visiting our website at www.kenwoodusa.com."
The second fix involves some very simple soldering, and has been endorsed by many as the solution:
http://www.remotecentral.com/cgi-bin/mboard/rc-theater/thread.cgi?3016%2C3
I hope this helps. Good luck and please let me know if this solves your problem!
Bob
Aug 29, 2008 | Kenwood VR-407 Receiver
Remote control
First you have confirm what really the defects is, is it the remote control or the control board.
HOW TO CHECK THE DEFECTIVE REMOTE CONTROL:
Check if the remote control if still good, using the camera of your cellphone point remote control to the cellphone camera and press the "on" button of your remote and you can see the light emitting from your remote control transmitter. If the lights emits that means your remote control is good, if not means the remote control is defective. If the remote emits light it means that the receiver at the control board in the indoor unit is defective.
Aug 18, 2008 | Fedders AED24E7F Wall/Window Air...
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
WS-55908 remote control
Take out the batteries or simply reprogram the remote by using the manual search function on the remote. There is probably a couple of different settings in the remote for this type of TV set, Good Luck
Jul 02, 2007 | Mitsubishi WS-55908 55" Rear Projection...
Aiwa CSD-TD49 Cassette/CD Boombox Logo
375 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
