Question about Pioneer ECS P4VMM2 V3.2A P4(478)/FSB 533/VIA/SDRM+DDR/A&V&L/MATX Motherboard (MBEP4VMM22)
My system hanged up after installaion of drivers software
HI
I recently Re installed my system with windows Xp SP2. After installing the drivers when i restarted it came upto the desktop then hanged up. Somehow i reinstalled the drivers and booted up successfully but when i connected it to the domain and logged in with a new user name it gave me the same problem.After logging in with any user the system gets hanged up.
Please let me know what exactly the problem is.My system configuration is: Itel original 945 GAV MB
Pentium DualCore Processor
180 Gb HDD
1 GB RAM
  • kiran_g4e
    kiran_g4e May 11, 2010
    Domain means .....which one
    i need some clarity.....
2 Suggested Answers
map9966
  • 2351 Answers
SOURCE: Comp doesnt boot after installing USB 2 drivers
Hi rogueonline,
Disconnect the external drive from the PC. (It's possible windows registry is messed up).
It sound like your windows system is a bit confused as well. First try resetting the bios. See page 9 in your manual. (Don't forget to set it back to normal). This should allow you to get back into the bios. Go over each setting & adjust as needed.
Make sure your primary hard disk drive is listed in the boot order. Advanced Setup Page 30, in manual. If your windows operating system seem is a bit off (OS not installed correctly or driver software not installed correctly). The over-all function of the system can & will run slow. If your primary drive seem to also run slow, the FAT or MBR can be slightly corrupt which will also slow the drive down including file transfer & eventually the drive will cease to function. (The drive can be repaired by doing a full format through windows).
Do a fresh install of windows, including the full format, (Not a Quick format) on the primary drive. Even though ECS does include the USB 2.0 driver so does windows update service. If your windows was all ready updated & you re-installed ECS's (2003) USB driver, that may have been enough to screw up windows. If you have data on your current drive & need to get that data off & if you have access to another system you can pull your drive & slave it into another system & remove the data. There is no quick fix. Play it safe. Start from scratch. After windows has been installed & you install the ECS driver software, update windows until there are no updates left. I'm sure your system will regain its speed.
Link to ECS web site for P4VMM2 V3.2A .
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Driver&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
Good luck ogueonline!
Mike
Posted on Nov 03, 2008
How to get video and other drivers for gc11020m.86a.1065.2006 ?
Hi! Try this web site, it will help you a lot...
http://drp.su/download.htm
its free!, try to use USB to copy or any peripherals you can use to copy the software, it will help to install the needed driver of the Motherboard.
May 27, 2014 | Intel D102GGC2 Motherboard
No graphic after install XP SP2
Have you updated XP to SP3 as recommended? Did you  installed the latest available video driver after after that ?
May 26, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Xp recovery
You need to download all the drivers installer files from manufacturer website first, and also all the software you want to install automatically with Windows. Then you build a Windows Xp boot CD with all the software setup embedded.
See the links below:
Build an XP-SP2 Recovery Disc - Solutions by PC Magazine
Geek Repair: Create Your Own Ultimate Recovery CD :
Bart's way to create bootable CD-Roms
Slipstream a Windows XP SP2 Recovery CD
Build your own XP SP3 Recovery Disk -
Build an XP SP3 Recovery Disc
Apr 18, 2009 | Microsoft Computers & Internet
I have been using a smart business pack for quite some time now. Recently my computer crashed and I had to purchase a new one. My old operating system was windows XP. My new operating system is Windows...
is there a problem with installation or the data reading?
If its installation problem, you can try installing it in compatibility mode for windows xp sp2 (right click the setup executable and you'll find a property page for compatibility mode)
Hope this helps.
Thanks.
Mar 14, 2009 | Computers & Internet
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Problem loading windows xp
try disabling legasy USB devices in bios
Jul 09, 2008 | ASUS K8V-MX Motherboard
Need soundcard driver
i think your laptop is recommended for windows xp sp2 ...
so if you install the sp2 then the sound may work ....
if you have motherboard cd then get it installed
tell me your laptop model otherwise exactly i will get you the links to drivers to download...........
Apr 02, 2008 | Edirol UA-4FX External Sound System
USB
checked my XP via control panel: usbhub.sys usbohci.sys usbport.sys usbui.sys good luck...may be difficult to force drivers...when system asks to install software, insert the original XP cd. The driver did not change with SP2, as far as I know.
Aug 18, 2007 | Microsoft Windows XP Professional With...
XP-SP2 hangs on boot after installation
I think maybe better uninstalling driver, but leave card in and boot system and let windows find the card(hardware) first instead of wot sounds like windows looking for driver and freezing in the boot up process as it will look for a connection to internet for an update or driver. Normally any usb periferals should be connected after driver installation, but any pci or agp cards inserted first, then driver.
Nov 05, 2006 | X-Micro Technology XWL-11gCAG 802.11g/b...
Pioneer ECS P4VMM2 V3.2A P4(478)/FSB 533/VIA/SDRM+DDR/A&V&L/MATX Motherboard (MBEP4VMM22) Logo
210 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
