1219 HD PVR will not capture the 480P output from my iScan Ultra. 13 seconds into recognition of the input signal, the software freezes up.
  • 1 more comment
  • friehl Dec 17, 2008
    Currently running the latest driver (1.053) for the hardware and the latest software (ArcSoft TotalMedia Extreme) version, that come with the unit.
    1219 HD PVR will not capture the 480P output from my iScan Ultra. 13 seconds into recognition of the input signal, the software freezes up.Comment posted on Dec 17, 2008
    I have no idea what this means.... What are you trying to relay here?
    "" there is a for to work out the HD transfer rate needed, res*refresh rate*colour
    i.e 1280*720*60*24bit
    convert it all to bytes and you get (1280*720*60*3)/1000000 = 165MB/s
    One hard drive you get 45MB/s average so your going to need 4 in RAID 0
    Sergeant:
  • 306 Answers
There is a for to work out the HD transfer rate needed, res*refresh rate*colour
Posted on Dec 17, 2008
  • AbdulRahiman S Dec 21, 2008
    dont forget to rate it.. good luck!!
  • 101 Answers
Welcome to Fixya.com
Your having a problem with your 1219 HD PVR not capturing the 480P
First I would try the company website for updates, but if this fails ,i would suggest to uninstall and reinstall the software.There are so many possible conflicts,but this is the most common. Hope this Fixya!
How do you connect the IKonvert SC-58 to the tv set
Reviews are bad for this unit :>(
https://www.amazon.com/Supersonic-SC58-Digital-Converter-Box/dp/B00IRL8IBM#customerReviews
You connect it to the television with a HDMI cable or RCA jacks. Coaxial cable input
Converts Over-the-Air Digital Television Signals for Use with Older Standard Definition TVs (480i)
• Receives Free Over-the-Air Digital TV Signals
• Record Live TV Via USB Connection
• Full ATSC Compliant
• Supports Full HD 1080p
• Output Display Resolution 480p/720p/1080i/1080p
• Built-in USB Input
• On-Screen Electronic Program Guide Support
• Supports Closed Caption
• Aspect Ratio: 4:3 &16:9
• Parental Lock Function
• Auto & Manual Scan Finds All Digital Broadcasts
• Signal Input: Coaxial Antenna
• AV Output: HDMI, RCA
Oct 14, 2018 | Televison & Video
The SP7205 will only show 480P. I have connected a DVD to the 7205 via composite cables however the unit only shows 480p. How can I get 720p or 1080i?
Unfortunately the highest video signal you'll receive through composite is 480p. To achieve anything higher than the said signal, you'll need to utilize either the component or DVI input of the projector. Those inputs will detect any HD signals.
Also if you've not done so already, you'll need to check the settings of your DVD player to make sure that it's outputting 720p and/or 1080i/p signal. Hope this helps you out.
Aug 09, 2011 | InFocus ScreenPlay 7205 Multimedia...
It's staying on 480i sd why not 1080i
There's only one way to get that TV to switch from 480i (which is an SD or Standard Definition signal) - that's to provide it with an ED or HD resolution signal (a 480P signal is often called ED or Enhanced Definition while 720P, 1080i and 1080P signals are called HD or High Definition).
The old standard yellow composite video cable.
You will not get ED or HD signals through the old composite RCA phono jacks (usually yellow in color), either. You'll need to use an RGB (red, green and blue) component video cable, HDMI cable, DVI, or other type supported by both your TV and the video source (CATV box, Blu Ray disc player, Satellite converter, etc.). More on this, later.
RGB cable.
An HDMI cable - this provides Digital audio signals, too.
A DVI cable.
First, you'll need a source capable of sending ED or HD signals. This can be a progressive scan DVD, Blu Ray player, HD Cable or Satellite converter, or a simple TV antenna. Not all DVD players are capable of the 480P progressive scan output - it must be labeled as such. The DVD movies are not labeled progressive scan as they all will play back at 480P if played in a DVD player capable of progressive scan, otherwise they play at 480i. A stand alone Blu Ray player or one in the Sony PlayStation 3, the older HD-DVD in the Xbox360, (it is important to note that the Nintendo Wii can output either 480i or 480P signals only when connected with their special component video cable), "set top boxes provided when you choose HD service from your local cable provider or satellite TV provider are the main sources for signals better than 480i. As mentioned above, the old standard yellow video jack is not capable of supporting signals better than 480i. You must use the HD jacks and cables between to get these signals into your TV.
The Wii 480P cable assembly - includes stereo audio, too.
Lastly, if your TV has an ATSC tuner (it is not uncommon for it to have an NTSC tuner and CATV tuners as well), you can input a UHF antenna directly into the the antenna terminals on the TV. Broadcasters in most areas have been moved into UHF bands - but some areas have one or two that operate in the VHF bands still. Check antenna web for information and help selecting antennas and broadcasters in your area. The nice thing about the antenna method is that no other cables, converter boxes, etc are needed to enjoy HD signals - plus - they're free!
Just remember you need a source capable of ED or HD signals and a way to get those signals to your TV. The yellow composite cable is from days ago and only passes 480i signals.
I hope this helps and good luck! Please take a moment to rate my reply - thanks!
Feb 16, 2011 | Polaroid TLA-04011C 40 in. LCD TV
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I have a ps3, do I need a composite cable to record my vids? Also, what programs do I need to just simply run the hauppauge cd that came with it?
For HD u need the special HDMI - Component cable, for regular quality u need the composite cable. Second, the software delivered with the PVR only works with Windows. For Mac u can purchase EyeTV or HDPVRCapture. Thank you for using FixYa, please rate this solution 4 thumbs if it was usefull. If not, please let me know.
Dec 26, 2010 | Hauppauge 1212 HD-PVR Video Capture
My new set displays only 480p SD on all my HD channels. Am I missing some settings in the menu's or is something more sinister going on? Any help would be greatful, I'm drowning watching sports!
hi,
u can enjoy full hd 1080p video through only ur tv inputs as 2 component video and 2 HDMI. the tv is seted to receive videos up to the resolution 1080p automatically (need not have any setting). just check the output of ur cable box or BD player, is it outputs full hd. if u are using the tvs internal tuner u will only get 480p.
ok
Dec 20, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Problem with HD feed from satellite receiver
I just had my HD DTV installed this weekend, you have to leave it on 480p. I too purchased my tv in 2002. Per DTV, its an older model and you have to stay with the 480p to get the best possible picture. I have to admit, don't know what the 1080i looks like, but 480p is showing me a very good picture. Best I have ever seen on my TV.
Jun 27, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Yamaha rx-v1800
I think the Yamaha will not upconvert anything below 480p through the HDMI output. You'll need to use the component out to the TV.
May 20, 2008 | Yamaha RX-V1800
Sound is not recorded
The problem would appear to be your audio settings.
You have the audio input set to Realtek HD Audio Input. That is the audio input on your soundcard, not the video capture card. You will need to change this so that you have the capture card selected. (I am not familiar with this exact model of card so I can't tell you exactly what it will be called.)
Alternatively, if you are trying to capture the audio via your soundcard (not recommended as it can cause sync problems) you will need to make sure that the 'line in' channel in enabled in the Windows mixer:
Start>Control Panel>Sounds & Audio Devices>Audio Tab>Click Volume in sound recording section>Tick Line In
Hope this helps,
Matt
Mar 06, 2008 | KWorld V-Stream Xpert VS-L883D...
Mitsubishi WT-46809 Problem getting HD from DirecTV
I have the same exact problem. Same model, etc. Is there a resolution?
Sep 16, 2006 | Mitsubishi WT-46809 46" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
