Re: 1990 lincoln town car - broken radiator drain plug
If your saying the handle broke off the plug, drill 2 holes in the plug and stick 2 nails in the holes. Turn the plug with an object between the nails.
SECTION 501-05: Interior Trim and Ornamentation
2003 Town Car Workshop Manual
REMOVAL AND INSTALLATION
Procedure revision date: 01/28/2002
Front Door Trim Panel Printable View (206 KB)Removal and Installation NOTE: LH side shown, RH side similar.
Disconnect the battery ground cable. For additional information, refer to Section 414-01.
Remove the window switch plate.
Disconnect the electrical connectors.
CAUTION: Use care not to damage the trim panel covers. Open the screw covers.
If equipped, turn the air suspension service switch to the OFF position before raising the vehicle.
Drain the cooling system.
Remove or disconnect the following:
Negative battery cable
Front seats
Carpeting
Rear airflow duct
Heater hoses
Remove the driver’s side air bag module by removing or disconnect the following:
SRS module-to-steering wheel bolts, from both sides of the steering wheel.
SRS module and disconnect the electrical connector
Horn switch electrical connector
Remove the passenger’s side SRS module by removing or disconnecting the following:
Open the glove box and disconnect the glove compartment isolator
Push inward on the 2 glove box door tabs and lower it
SRS module’s electrical connector
SRS module-to-instrument panel bolts and the module
Remove the instrument panel by removing or disconnecting the following:
Speed control servo nuts and move the servo aside
Bolt and disconnect the left side bulkhead connector
Left side bulkhead connector from the dash panel
Windshield washer fluid reservoir screw, and position the reservoir aside
Blower motor electrical connector
Air conditioning pressure cut-off switch electrical connector
In-line electrical harness connector
Electronic Automatic Temperature Control (EATC) variable blower motor controller electrical connector
Right front wheel
Right front fender splash shield bolts and move the shield away from the cowl
Wiring harness from the evaporator case
Wiring harness from the cowl
Right side instrument panel lower insulator pushpins, disconnect the power point electrical connector, remove the courtesy lamp from the socket and remove the insulator
Unseat the wiring grommet and feed the wiring harness through the cowl
Cowl side trim panels and the windshield side garnish moldings from both sides
Locking clip and the Electronic Crash Sensor (ECS) module electrical connector
Antenna connector
Ground wire bolts from the right side
EATC hose at the evaporator housing
Bolt and disconnect the bulkhead connector from the right side
Pull the door weatherstrip seals away from the instrument panel on both sides
Tunnel brace trim cover
Climate control head vacuum harness connector
Instrument panel tunnel brace nuts and the brace
Ground wire bolts from the left side
Wiring harness connectors from the left side
Parking brake switch electrical connector
Pry out the instrument panel defroster opening grille, disconnect the electrical connectors and the remove the grille.
3 upper instrument panel screws
Instrument panel cowl side nut from both sides
Instrument panel cowl side bolt. From the left side
Instrument panel
Windshield wiper mounting arm and the pivot shaft
Electrical connector and remove the upper cowl extension screw and the extension
Vacuum hoses and the wire harness connector from the evaporative emissions canister purge valve
Evaporative emissions purge valve nuts and the valve
Cowl side nut
Right side rear fender apron screws and reposition the apron
Evaporator housing nut and screw
Vacuum hoses and the wiring harness connectors
Plenum chamber’s lower flange nuts
Plenum chamber’s upper flange nut and the plenum chamber
Heater core cover-to-heater plenum chamber screws and the cover
Trace the upper radiator hose to the thermostat housing. Loosen the hose clamp on the housing with a flat-blade screwdriver. Slide the clamp back and remove the hose from the housing. Use a wrench to remove the two mounting bolts from the thermostat housing.
Slide the housing off of the intake manifold. Clean any remaining gasket pieces from the thermostat housing with a flat scraper and clean rag. Remove the old thermostat from the housing.
5
Insert the new thermostat into the housing. Position the new gasket on the outer edge of the housing and position it over the mounting area on the intake manifold. Replace the two mounting bolts and tighten them using a wrench.
6
Replace the upper radiator hose on the thermostat housing and tighten the hose clamp. Top off the radiator with a blend of equal parts antifreeze and distilled water. Replace the radiator cap.
The Stop Light Switch is located by the Brake Pedal arm, it is usually held in with a screw or nut, just unplug the electrical connector, remove the nut or screw and install the new one and tighten and plug everything back up.
There common to break off, you can pick up the replacement drain plug at NAPA and buy a stud retracter to remove the drain plug. if the plug is not leaking, Leave it alone and to drain the radiator, just disconnect the lower radiator hose on the opposite side of the radiator.
Good luck and hope this helps you on your project.
Are you sure it's not just a dirty and burn transmission fluid?? But if it is engine oil you may have a bad radiator since the transmission cooler and engine oil cooler is integrated with the radiator.
Good luck and keep me posted.
