Acer Aspire 3100 Laptop Monitor will not turn on
Laptop monitor does not turn on. Problem just occurred this evening. Computer froze up, so I did a hard re-boot. When I powered it back up, the monitor was black, though the laptop was on (green light on power button, fan).
I tried to connect the laptop to my desktop monitor. It remained black.
I also noticed that the left side of the keyboard (just below the keys) was very hot to the touch. Battery was not hot (located under right upper quadrant of keyboard).
Any help appreciated.
Battery and Ac will cause system indicator lites to come on and cpu coolant fan to operate, however HDD, screen  and the eaminder of the system fail to initailize.
  • 8088vs Jan 09, 2009
    My Aspire 69200 is doing the same thing. My fiance left it at school where she uses it to project lessons for her class. She shut it down and the next morning it would do the same thing you're describing. On boot, the fan would come on, the dvdrw responds when ejected, and the media console touchpad responds, Pressing the caps, num, and scroll lock buttons will not turn their indicator lights on.
    Sergeant:
  • 366 Answers
Try Screen switch function to switch from Internal screen to External monitor to Both.
Normally FN + F4 (on Compaq or FN + F7 on Lenovo check the Function symbols on your Keyboard: allow few seconds after command to refresh configuration.
try Safe mode also. to check if display shows in VGA format.
Posted on Dec 26, 2008
The screen on my acer aspire 3100 crack so i bought a vga cable to connect to my flatscreen but the picture switches back to my laptop when its starts up the only way that it works on my flatscreen is when...
Go into your display settings. It should show at least two different monitors. Your laptop monitor and the external one your plugged into. Click on the external one and click on the two check boxes. Click on extend the desktop into this monitor first. Then click on this is my main monitor. Reboot your computer and it should be on your external monitor.
Jun 12, 2013 | Computers & Internet
I just bought a Acer Aspire. I did set up for windows 7 and all seemed well. I tried to search the internet and it froze. I can't turn it off. How do i reboot it?
Hi
Press and hold the power button on the laptop for over 5 seconds and it should turn off... or remove the battery and charger :)
When it turns back on, it will ask you some questions, just leave it alone and it will reboot by its self.
Mike
Aug 24, 2011 | AcerView 54EL 15" CRT Monitor
Whenver I turn the computer on, the moniter says that there is no signal. The vga input/output cords are in the desktop and the power cord is intact as well. Could you please tell me what may be the...
Hi.
It is best to test your monitor on another computer. If it does not work on another then the Monitor is definitely the source of the problem. If your monitor works on another then the problem could be your video card or that your resolution is beyond the capability of your monitor. To test this, when you restart the computer if you do not see the BIOS screen or even the windows logo screen then it is the video card, but if you do and this problem occurs when you are in windows then your screen resolution is the problem. You could also try using a different monitor on your computer to check those settings.
Feb 11, 2011 | Acer Aspire X1300 (PV.SCC0X.002) PC...
Acer aspire one - its died!!!
If it was just the hard drive, I would expect the video to come on and say something like "no boot device."
However, since you went through the steps here and see absolutely no video (even none on an external monitor), I would suspect a motherboard failure.
Be sure that when you hooked up an external monitor that you pushed the Fn key and the appropriate special function key (maybe F7) that switches between the laptop and external monitor. If you have done that (pushed the combination several times to switch displays), then you can be pretty certain your video card (if a separate card) may be bad.
I'm not really sure if this machine has a separate video card. The specs say it's a ATI Radeon Xpress 1100. This leads me to believe it may be a separate card.
If it's just the card that went bad, you can replace it. Otherwise, the motherboard will have to be replaced.
Good luck. You can do that, but if you're not confident, you best take the machine to a repair shop.
Apr 26, 2009 | Acer Aspire 3100-1405 Notebook
Acer 3100 screen wont turn on.
Have you tried hooking an external monitor to the system? If that works you may have accidently switched the screen to an outside monitor. Or you could have a bad connection. Try starting in safe mode and see if it works.
Jan 19, 2009 | Computers & Internet
Acer Aspire 3100
you need to toggle the screen on by use of a key on the keyboard... do you see one that resembles a monitor...
Robert
Sep 07, 2008 | Acer Aspire 5100 Notebook
My acer screen monitor will not turn on
display card burned change it
rate me fix ya
Aug 21, 2008 | Acer Aspire 3100-1405 Notebook
1. Mainboard failed
2. Vga adapter failed
I wouldnt be suprised if the vga failed, my acer broke down on me 2 times, on the 3rd time it was too much and I sold the laptop.
Mar 23, 2008 | Acer Aspire 3100-1405 Notebook
Acer aspire 3100 laptop
Hi Mikey,
Bottom row of keys, you will see on marked Fn. It is a specific color. Hold that and look at the top row of Keys. You should see one with a laptop screen, and a monitor on it. Tap the key once.
Each time you tap it, while holding the Fn (Function) key, it changes your optons. Once it will set your display to Laptop only, again will set your display to Monitor only, and again will set your display options to both. Play with the key combonation, and you may have to reboot with each tap.
Good luck.
Jan 07, 2008 | Acer Aspire 3100-1405 Notebook
Computers & Internet Logo
929 people viewed this question
David Payne
David Payne
