Question about Gaggenau GI936-760 Dishwasher
Door handle The doorhandle on my dishwasher is loose. I need to remove the door panel to tighten the handle. There are three screws along the inside, which look like they might need to be removed to access the outer panel. However, the screw is similar to a phillips head, but it isn't. First - do I need to remove these screws to remove the front panel? Second, if so, what kind of screw is this and what kind of screwdriver is needed? Thanks Mike47
  • 1 more comment
  • Anonymous Dec 23, 2007
    towel bar on fridgidaire dishwasher model no. GPDB998JC0 is loose, how do I tighten it?
    how do I tighten loose towel bar on Fridgidaire model no. GPDB998JC0
  • Anonymous May 09, 2008
    my dishwasher leaks
    President:
  • 1,462 Answers
Removing the front panel is just meccano. the screws are probably torex - a driver is easily available from any tool shop
Posted on Mar 26, 2007
I have a loose door handle. what tools do I need to repair it and how?
Depends on the brand and type of handle. I'll give you a few general ideas. The first easy one is to look under both ends of the handle for small set screws. If you see them, a small allen wrench should tighten the set screws and the handle. The next type requires the removal of either the inner door panel or outer panel. Some dishwashers will have screws along the inner edge of the door panel. you remove the screws and either the inner panel will come loose or the outer panel will come off (depends on make and model) Once the door is apart you should be able to see the handle screws to tighten. Some doors also have a screw in both bottom corners facing upward that may need removed . Best I can do at this time.
Apr 03, 2015 | Dishwashers
GE dishwasher model GLD5868V15SS handle loose
This model comes with two types of doors. One with a single panel with integrated control on top or a two part door with control unit in front. The handle varies.
If you have a single door panel with handle bar across from right to left then you need to carefully unscrew the back panel screws and free up the front panel. the handle is screwed to the front panel from inside. Once you tighten carefully put the back door panel in and tighten. Take photos along the way to make sure you get back where you started. Also unplug dishwasher before working on it.
If you have a two part door with front control then handle and access to it is different. See diagram on this website for blow up of the panel and location of handle (part 713).
ESCUTCHEON DOOR ASSEMBLY Diagram Parts List for Model GLD5868V15SS GE...
You can magnify the image or take a full screen view for clarity.
Aug 29, 2014 | Dishwashers
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
Loose handle
Open the door and loosen the self threading screws around the sides of the inner door panel. Once this has been achieved lift the inner panel up so that you can access the door handle screws. Tighten these fasteners and reassemble the door panel.
Jan 24, 2014 | LG LDF6810ST Stainless Steel Built-in...
Door handle need to be re tightened. Do you hav...
if its just the handle itself it sounds like the fixing clips have come adrift or broken off,the handle strip will need replacing if its the whole console thats loose remove the outer door cover this will give you access to panel screws and may allow you to see more of the handle fitting inside.
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Hi,I have a Bosch dishwasher SHY 66C02 UC and the handle is loose. What do I need to remove to get access to the front panel? Thanks, Will
u have to remove the torx screws on lhs and rhs of the door and a also at the top of the door.once u remove them the front panel will come out and u can tighten the handle screws.good luck.
Aug 18, 2009 | Bosch Dishwashers
Loose door handle on ge profile dishwasher
Take the inside panel off.  The 2 screws near the latch only need to be loosened.  Once the handle is off, you will find an allen bolt inside the shaft of the handle support.  Tighten and you are done.
Dec 20, 2008 | GE Profile PDW9880NSS Stainless Steel...
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Inside door handle
Remove the two screws in the arm rest pocket. Carefully pry around the bottom edge of the upholstered panel to release nylon stud & socket fasteners. Remove triangle trim panel at forward edge of window by prying loose the same fastener in the middle of that panel...lift upwards to remove. Lift the entire panel to unhook the top edge which hooks over the sheetmetal at the bottom of the window opening. The trim around the doorhandle is held in place by three three j-hooks which must be pressed towards the center of the handle to release. The door handle assy simply slides forward about 1/2" before coming loose from the metal in the door. You can buy extra stud & socket assemblies at a chev garage for pennies
Aug 27, 2008 | 1998 Chevrolet Tahoe
Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
Jun 09, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Gaggenau GI936-760 Dishwasher Logo
356 people viewed this question
Top Gaggenau Dishwashers Experts
Mike
Marvin
Marvin
Are you a Gaggenau Dishwasher Expert? Answer questions, earn points and help others
