Question about Sony VAIO VGN-BX540B Notebook
Windows Pro system restore will not restore.
I am using Windows XP Pro. When I try to run system restore I get a message telling me that system restore was unsuccessful and no files have been changed. I have set restore to use max room on drive. It should have plenty of space.
Service pack 3 is installed but I'm sure that can't be the problem as I have had the same situation since service pack 1, long time ago. I have tried to look in services to see if restore is enabled but as of yet I haven't been able to locate the place where you can look at that.
Can anyone suggest anything else I can try? I get the feeling that lots of folks have had this problem. Anyone have a solution? Thanks
  • Joyce Goldman Dec 17, 2008
    I forgot to mention in my initial post that this is NOT a Sony Vaio laptop, it is a traditional desktop. It is a generic as I built it myself.
Msvcrt.dll error message(Msvcrt.dll error message("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll")
Two possible solutions.
Roll back system with System Restore. Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 23, 2012 | Microsoft Windows XP Professional
The "scrolling bar" beside the
Hi john35809,
Welcome to FixYa! How are you doing?
You did not specify the operating system you are using, whether Windows XP, Vista or Windows 7.
1. If you are suspecting the recent Windows Updates caused the problem, you can try System Restore:
2. You can also try to reinstall the touchpad driver by downloading it from the computer manufacturer's website (example: http://support.dell.com). Don't forget to restart your computer after reinstalling the touchpad driver.
Hope that helps. Thank you for using FixYa.
May 03, 2011 | Acer Computers & Internet
Following a System Restore on my Dell Inspiron it has come up with windowsroot system 32 ntoskrnl. The computer was not supplied with the full Window's XP home edition CD, just a Dell reinstallation CD...
If you get that message every time you run system restore, that restore point is no longer any good. You need to try a different restore point on a different date. System restore is NOT meant to be a backup. You need to be running a backup of your computer if you don't want to lose your data. Hopefully you will have another restore point, possibly earlier than the one you used, which is good. If you need to reinstall windows, you will need to get a disk. You can send me a message if you need one.
Jun 13, 2010 | Dell Microsoft Windows XP Home Edition
I am running Windows XP Sp3 and System Restore will not restore to any active restore point, even the most recent date. After selecting a restore point the system reboots with the message "Your system can...
Try to restore your system in safe mode.
To start your system in safe mod, start your computer, then press F8 during system start. A list of options will be displayed, select safe mode, login to your administrator account and perform a system restore.
Jan 08, 2010 | Microsoft Windows XP Professional
How can i use the prduct key to restore my system with out cd
You can use the next tool:
http://www.nirsoft.net/utils/product_cd_key_viewer.html
You can also find a list of other tools here:
http://www.mydigitallife.info/2006/11/05/view-and-retrieve-or-change-windows-xp-vista-2003-2000-and-more-and-office-xp-2003-92-product-key-or-cd-key/
good luck
May 04, 2009 | Microsoft Windows XP Professional With...
Removing partial install of 2nd os
You should be able to do a SYSTEM RESTORE to a point before the XP Pro installation.
Start the machine and start tapping the F8 key until the boot menu is displayed. Use the arrow keys to highlight SAFE MODE and press enter. If you are given a menu to choose which Windows to boot into, choose the Home edition. Windows will load with the minimum drivers. Your screen display will be 640 X 480 and the icons will be large. You will eventually see a window advising you that you are in safe mode, click OK or NO. Click NO. That should open The System Restore function. Choose to restore the system to an earlier date. A calendar with be displayed. The BOLD dates are the ones that you can restore to. Choose a date that was before the date you tried to install XP Pro. Follow the prompts and the restore process will run and reboot your computer. Following the reboot, the installation will complete and Windows will open.
If you have installed a service packs or updates after the restore date you will need to install them again.
Good Luck! and please let me know how this works out for you.
Jan 16, 2009 | Computers & Internet
System restore disable
Open your system properties. Check to make sure the system restore feature is enabled. I had to do this on my old computer as you have to tell the restore feature how much hdd space to dedicate to restore functions. Hope this helps & please remember to rate my answer. Thanks.
Dec 30, 2008 | Microsoft Windows XP Professional With...
Will show avaliable wireless networks but won't connect
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
if the Issue presist then you need to try System restore
If Windows XP starts loadTOCNode(3, 'moreinformation'); 1. Log on to Windows as Administrator. 2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts. 3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next. 4. On the Select a Restore Point page(try the date 2 dats prior it was working or the First Bolded Date of that month), click the most recent system checkpoint in the On this list, click a restore point list, and then click Next. A System Restore message may appear that lists configuration changes that System Restore will make. Click OK. 5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer. 6. Log on to the computer as Administrator. The System Restore Restoration Complete page appears. 7. Click OK.
Aug 09, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Windows Xp on Intellistation Z Pro type 6221
A restoration disc is not a conventional Windows OS disc (and vice versa), therefore it often cannot be used as if it were a true Windows disc. The restoration disc includes the OS, but it also includes every driver and other software product that came with your system. If Windows were the only item loaded on your system, then a Windows disc could serve as a restoration disc, but these days, using a typical restoration disc is an all-or-nothing process.
A restoration disc is your ultimate troubleshooting tool. Suppose that your copy of Windows becomes damaged from a virus or key applications become corrupted. Symptoms such as instability, crashing, indecipherable error messages, and impaired performance are extremely hard to diagnose by yourself—even if you have the help of a customer support technician on the telephone. If the most common corrective steps fail, you can always use the restoration disc to recover your PC back to its known-good, factory-fresh state.
Jun 18, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
Sony VAIO VGN-BX540B Notebook Logo
42 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
