One Key Rescue requires that I use CD or DVD media. My S10 Laptop has no CD. Can I make a bootable recovery disk on a usb hard drive? There seem to be no instructions
  • 111 Answers
Yes but you need to do it from another computer with the disk unless you know which cabs to use
Posted on Dec 21, 2008
How can i get my 2go password back
There are some methods for you to reset it, just follow the info and have a try
Option 1: Use a password reset disk to reset lost password if you have created one before forgetting the password.
requirement: USB flash drive or floppy
time: a few minutes
Note: This password reset disk can be only created when you can log on with the lost windows password.
Option 2: use a freeware to crack lost windows admin password, then you can get back the password, like Ophcrack
requirement: download Ophcrack live CD,
time: more than i hour
Option 3; a high efficient and easy-to-use low affordable shareware, like Windows Password Recovery Tool, which can reset windows 7 password quickly and successfully.
Requirement: a bootable CD/DVD or USB flash drive.
Time: within a few minutes.
Steps:
Step 1: Download and install Windows Password Recovery Tool 3.0 in any available computer from http://www.windowspasswordsrecovery.com/windows-password-recovery-tool.html .
Step 2: Burn a bootable CD/DVD to remove lost Windows password. (or USB Flash drive)
Step 3: BIOS settings
Step 4: Recover forgotten Windows password with the burned CD/DVD (or USB Flash drive)
good luck
Jun 16, 2014 | HP Computers & Internet
Can I reset it back to factory setting with out a CD or DVD
If the restore partition is still on the hard disk then press Alt and F10 just before it boots. Otherwise try T8 just before it boots. If this fails try Creating a System Rescue USB drive (Note: An alternative to the spyware-laden Daemon-tools for mounting the ISO file as a virtual CD-ROM is Virtual CloneDrive). If you have trouble with the System Rescue CD, you can try some other distros.
Reboot the netbook and go into the Acer BIOS settings. Change the boot settings to check USB first. Plug in your System Rescue stick, and restart the netbook.
Run "wizard", and launch gtparted (icon towards the lower-left of the screen).
Delete partition 2, create a new one, then reformat it as NTFS
Mark partition 1 as bootable (right-click, edit flags). Remove USB drive.
Reboot into the Acer System Restore software. Choose to restore the system.
Plug the System Rescue USB drive back into the Acer netbook.
Reboot into the System Rescue CD/USB, go back into gparted, and flag the restored partition 2 as bootable.
Remove USB flash drive and reboot.
Hope that helps.
Jan 11, 2014 | Acer Aspire 7720 Notebook
Boot screen computer
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
Clean Install Windows on a Sony Vaio
Even if a Windows operating system is already installed on your Sony Vaio, it is possible to clean install the same version again or clean install an upgraded version of the Windows operating system over the current operating system.
A clean install of a Windows operating system overwrites the Sony Vaio's current operating system and cleans the hard drive by automatically deleting all of the applications, files and settings that are stored on the Vaio.
Create recovery discs for your Sony Vaio using the Vaio's built-in VAIO Recovery Wizard.
Access Vaio Recovery Wizard by going to the "Start" menu and clicking "Help and Support." Follow the screens in the VAIO Recovery Wizard to make recovery CDs for your computer.
Transfer files and programs that you want to save onto an external storage device, such as an external hard drive or a CD.
To transfer the files and programs to an external hard drive, plug the external hard drive into a USB port on the computer and drag and drop files from the computer into the external drive window.
To transfer the files and programs to CD, open a CD-burning software and choose the "Data Disc" option, upload all of the files into the program and "Burn" or "Write" them to the disc.
Place the Windows installation CD or DVD into the disc drive of your Sony Vaio.
If the computer is already on, reboot the computer.
If not, turn the computer on to boot the installation disc.
Follow the onscreen prompts to go through the installation wizard for the Windows operating system.
Enter the product key from the Windows operating system packaging, accept the terms of the operating system license and, if prompted to choose a type of partition for the Sony Vaio, select "NTFS."
Click the "Install Now" button on the last page of the installation wizard.
The operating system installs to the Sony Vaio.
Wait for the installation of the operating system to complete, which can take up to two hours on some systems.
Once the installation is finished, reboot the Sony Vaio and the computer should boot up to the operating system screen.
Aug 29, 2013 | Sony VAIO VGN-FE550G Notebook
Loveno S10-2 - No bootable device found
Make sure your hard drive has higher priority in the boot options in BIOS. If it still doesn't boot then you will need to replace your hard drive. If it shows no hard drive in BIOS then the drive is most certainly bad and needs to be replaced.
Dec 02, 2012 | Lenovo IdeaPad S10-1211U Netbook
Replaced the MK5065GSX hard drive used the recovery disks but 'no bootable drive' message displayed.
no PC stated
no OS stated
no source of recovery disks stated (HP, MS or crack.org)
or home made?DVD-R or CD-R?
the answer is all you said and more.
lots more.
bad disks wrong disks
bad CD drive
bad HDD drive.
or if laptop then main battery is bad (bigone) and overloads it.
why not boot to live linux disk (optical media)
UBUNTU, 16, FREE, BOOT IT AND HIT TRY ME.
See if PC runs ok.
then if that works run DISKtest during the above demo try me.
if that passes we we are at
bad media install disk you have (no os stated or class of media)
bad cd/dvd drive.
Jan 05, 2018 | HP Computers & Internet
Forgot password on dell laptop with windows 7?
emm, forgot Windows 7 password?
Option 1: Use a password reset disk to reset lost password if you have created one before forgtting the password.
time: a few minutes
requirement: download Ophcrack live cd,
Visit http://www.windowspasswordsrecovery.com
Step 1: Download and install Windows Password Recovery Tool in any available computer.
good luck ~
Dec 02, 2011 | Dell Inspiron N5030 Notebook PC
When i turn it on it just says-SMART HARD DISK IS ABOUT TO FAIL,BACK UP THEN PRESS F1 TO CONTINUE,MY LAP TOP WAS ALREADY PRE-INSTALLED WITH WINDOWS 7 SO I DONT HAVE INSTALLATION CD
Hard disks with S.M.A.R.T. technology have internal checks that may identify problems with your hard disk that may lead to fatal failures, warning yu in advance (it is very common when people hit or let their laptops bump against the table - hard disk drives are very sensitive to shocks and bumps...)
First of all: BACK-UP ALL FILES YOU CONSIDER IMPORTANT, SPECIALLY YOUR OWN  DOCUMENTS!
One way to solve your problem could be to download and install a 30-day trial version of Acronis True Image Home 2011 from http://www.acronis.com/homecomputing/download/  and use it to generate a full backup image of your hard disk into an external USB hard disk drive . Please, generate also the Bootable Rescue Media CD.
Then buy a replacement disk, install it in the laptop and use the Bootable Rescue CD to start Acronis True Image directly from the CD and recovery your backup, reinstalling everything back to your laptop, in just a few minutes.
Although using the trial version of Acronis True Image will help you in this emergency case, you might want to buy it as it is an exceptional tool to have for cases like this.
Another way would be to download all the drivers for the devices installed in your computer, save them in a CD or flash drive, buy and install a new hard disk, buy a Windows installation CD and reinstall your laptop from scratch, using the drivers you downloaded earlier to reinstall them to your laptop..
f you need further assistance, please, feel free to ask us here at FixYa.
Hope this info may help you.
Mar 19, 2011 | Computers & Internet
Sony Vaio VGN N320E won't start - recycles to error window have a vista repair disk - doesn't seem to work - trying to save precious photos before ordering recovery disks from Sony Would like it to start...
You can backup the data and restore it to factory settings.
Please restart the Computer, press the F10 key at startup to access the Recovery Center.
Select Rescue Data option to backup the data to an external USB Hard Drive or thumb Drive or CD/DVD Disc..
Select Custom Rescue Data option to backup the individual data.
Once the data is backed up, select Restore C Drive option to restore the Computer back to the factory settings.
Apr 18, 2010 | Sony Computers & Internet
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
