Question about Zenith A56M91W 56" Rear Projection Television
PIN CUSHION PROBLEM
A REPAIR GUY SAID MY 56" PROJECTION TV HAS A PIN CUSHION PROBLEM. IS THIS SOMETHING I CAN FIX OR SHOULD I TAKE IT IN TO HIM TO REPAIR IT. MY TV SCREEN COMES IN ON SIDES AND OUT ON TOP AND BOTTOM. IS HE CORRECT AND CAN I FIX IT? THANKS
    President:
  • 3,130 Answers
If you have the proper tools and understand how the picussion circuits work then you can get a maunal and troubleshoot the TV set, but this pincussion circuit is a dangerous place to be as there is alot of high voltage in this circuit. if you do not know about these solid state circuits, play it safe and get a pro to assist you in this repair. Good Luck
Posted on Mar 25, 2007
Pin cushion vertical on a hitach projection tv 65 swx20b
Pincussion is rare on this set but convergence is common and can cause a similar looking issue.
May 03, 2012 | Hitachi Televison & Video
I have replaced a capacitor, transitor, and a diode as was described to me by repair world this is on the deflection board, now it turns on and works but it has an hour glass shape to the picture the side...
thats a pin cushion problem. I would check for more bad caps on the deflection board or open resistor. Sounds like you had an issue with the retrace cap CL031 and the HOT transformer and possibly the DL030 often if they fail bad enough the circuit board can actually burn through and that arc can travel and cause other items to fail. You may end up having to replace the deflection board to fully fix the issue of pin cushion that your experiencing now.
Aug 24, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 56" JVC AV-56WP30. It shows two pics one red and one green. what is wrong and how do i fix it
The LCDs in the tv are in 3 colors, Red, Green and Blue. They are out of alignment. Repair needed.
Aug 09, 2010 | JVC AV-56WP30 56" Rear Projection...
JVC Convergence Problem
you have some resistor open off of the ics that you replace like 1.8 ohm 1watt or 2.2 ohm or 2.7ohm
Aug 27, 2009 | JVC AV-56WP74 56" Rear Projection...
Need to know how to adjust the mirrors on model PS 50700
Hi, you don`t adjust the mirror, you have whats called a pin cushion failure and that means you need to call a tv tech, parts need to be replaced in that circuit and this isn`t something a layperson should attempt, video-tek
Feb 07, 2009 | Proscan PS50700 50" Rear Projection...
Samsung 42 inch rear projection not working
If you have no prior experience repairing TV sets, I wouldn't recommend opening it up under any circumstances. There are voltages inside that can kill, even when unplugged.
Your safest bet would be to go with a repair guy. Shop around for various prices. In the end you will have to weigh the cost of repair against a new set and decide..
Oct 26, 2008 | Televison & Video
Sound but no picture
Take it to a repair shop and let them fix the problem.. we charge around 300 to 400 fixing something like that...
Aug 31, 2008 | Philips 55PP9363 55" Rear Projection...
Pt 56tw53 picture trouble
I had the same problem with my TV, It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. $500 with service charges to get it fixed!
Nov 05, 2005 | Panasonic PT-56TW53 56" Rear Projection...
Televison & Video Logo
147 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
