This dryer is a frigidaire electric dryer. In this video I show the belt location. It mounts around the drum. You must remove the front panel to replace it:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: frigidaire FSE446RHS2 electric dryer makes bumping
Rear bearing and drum coupler needs to be replaced
bearing kit part #WC5303281153 is available online from many parts stores. You may want to replace the belt at the same time while you have the unit apart. Also inspect the front upper drum felt if it is worn replace it. The whole repair time for me was about 45 minutes dryer now runs like new.
SOURCE: my frigidaire electric dryer wont heat up, only
Hi, If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
