Question about Fisher Paykel EcoSmart GWL15
Fisher and Paykel Ecosmart GW15 replace the water sensor?
From reading posts, It looks like I need to replace the water sensor in my clothes washer.
Description: I start the washer, it filled with water (once), and then it shuts down within about 3 minutes. Then it beeps over and over until I hit the power button to turn it off. So I do. Then, I turn the power back on, and start it again, (even making the spin cycle slow or any variation doesn't help) and it starts to spin, but not correctly I think, lid open or closed... And then it shuts off again within 3 minutes. This happened sooo many times. So, then it doesn't drain either... I took the clothes out and scooped out all of the water. 1) Is it the water sensor? 2) How do I fix this?
my warranty is up. it's probably from about 2005-ish, maybe 2004?
I appreciate this forum sooo much, thank you guru's and everyone else!
    Problem Solver:
  • 7 Answers
Replace the pump
Posted on Jan 02, 2009
Ecosmart washer won't drain it filled with water, washed and nowwon't drain the water.
you need to vacume out all the water so you make it light, then dolly out the washer to some place you can drain it. now take off the front of the washer and locate your water pump, its attached to your drain line. take off drain line to water pump and see if anything is clogged in the pump. This is most likely what is wrong if it wont drain. hope this helps.
Feb 22, 2013 | Fisher Paykel EcoSmart GWL15
Fisher paykel ecosmart washer won't fill or complete cycle
It can't get enough water so it flashers these lights
to tell you to turn your water on,
Your water valves are not fully opening to let enough water in.
You will need new water valves.
Oct 16, 2012 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
About a week ago I noticed a puddle by the front of my washer. Now it is happening with every load, any size. It seems like the water is splashing up over the bucket and running down the inside of the...
Hi
In my opinion
This would be the water level sensor as the water should not get that high were it goes over the top the sensor should cut in and shut the water off at the level you set.
The problem can create more and can be dangerous as water and electricity not good best get it looked at.
regards Craig
Feb 01, 2018 | Fisher and Paykel WA37TG1 Top Load Stacked...
Washer agitates but will not spin out the water
Hi just read your posting.Now does the machine drain the water out?Or does the machine drain the water but not spin.Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 10, 2010 | Fisher Paykel EcoSmart GWL15
My five yr old Fisher Paykel EcoSmart washer is dripping water into the tub when it is off. Is this hard to fix on this machine?
Hi just read your posting.The problem with your machine is a faulty water valve.Now there is 2 ways you can rectify this .The first and cheapest is to turn off the taps to the machine after use or the 2nd is to replace the faulty valve or valves.Hope this helps and please reply on how you got on and if you would like to change the faulty valve or valves.Looking forward to your reply.
Jul 31, 2010 | Fisher Paykel EcoSmart GWL15
I am getting grey marks on my light colored clothing. I have a Fisher & Paykel topload washer.
THE PROBLEM IS THE AMOUNT OF DETERGENT YOU ARE USING.YOU NEED TO BE USING HE OR HIGH EFFECIENT DETERGENT. THIS MACHINE USES MUCH LESS WATER THAN YOUR VERAGE TOP LOADER.
Apr 07, 2009 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washer GWL15
I have noticed this same problem and wonder if it because my FP washer wasn't draining properly and dirty water couldn't get out. See my post on "eco smart won't drain, smells hot". I found one of my husband's socks when I removed the black motor/white plastic housing on bottom of washer. tip washer back and you'll see this electric motor. My post tells how to remove it. then you can look into that small space and see if there is something plugging it.
I am waiting on my replacemt motor, and hoping all the dirty streaks are gone. the water I drained out after i removed the sock was really grimy and gritty with dirt. I'm sure the sock has been holding a lot of junk in the bottom of the tub and it would end up on clothes during spin cycle. My issue has been going on for a few weeks and then the motor finally smoked which led to the sock discovery!
Oct 02, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
May 31, 2008 | Fisher Paykel EcoSmart GWL15
Getting inside the Fisher-Paykel GWL15 washer
thats it , remove those 2 screws and the top will flip back, the new "clothes guard"( neck ring), will snap right into place, be sure to rehook the spring to hte left front susension rod!
Mar 25, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
219 people viewed this question
Top Fisher Washing Machines Experts
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
