Question about Xerox WorkCentre XL2140df Laser Printer
Tonor along edge of paper on my Xerox WorkCentre XL2140df
This machine is great. I've loved it. A couple months ago it started leaving a residue of loose toner along the right edge of the paper. I tried cleaning the machine thoroughly which temporarily would make a little difference. Then I finally replaced the toner cartridge and it seemed all better. Well, it has now come back. This printer does not get a lot of use so it is not after many copies. Oh, AND Xerox no long supports this machine with service. AND I just hate to throw things into the landfill.
I also am at a loss on how to change the default paper tray. The properties at the printer window will not take the changes.
Thanks for any help you can offer.
    President:
  • 2,072 Answers
I would think you just have another bad cartridge. have you simply tried shaking it side to side? May just be built up on one side, but those cartridges are notorious for going bad. You need to vacuum the machine out well also. That toner and developer get in all those little plastic supports and can cause toner to dump.I would say the chance of a bad cartridge again is about 95 percent.
The printing problem. Have you tried downloading the driver from the Xerox.com site? Or simply reloading the driver. Sounds like its corrupted somehow. And when you change the tray, you are clicking apply?
Posted on Dec 17, 2008
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
My dishwasher suddenly started having a white residue to cover the dishes. This white residue is also along the edges at the bottom of the door and bottom front of the interior of the disherwasher and...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe the pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 29, 2011 | GE Dishwashers
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
We have a Xerox Phaser 7400. The output is dirty along the bottom 1/2 inch of the page.
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. If the issue is there at that point then it would point to loose toner residue underneath the cartridge. if not then the fuser area has to be cleaned. Wipe the area clean with a lint free cloth, do not use compressed air.....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 04, 2011 | Xerox Phaser 7400/DXF Laser Printer
Trying to change paper size from A4 to 8.5x11 on a Xerox Workcentre M123
  1. Pull out the paper tray.
  2. If necessary, slide the paper tray edge guides so that the guides are open.
    1. To adjust the side and rear guides, pinch the guide lever on each guide and slide the guides to their new position.
    2. To secure the guides in position, release the levers.
  3. Load the paper against the left-hand side of the paper tray. Paper can be loaded either short edge feed or long edge feed.
  4. If necessary, slide the paper edge guides so that they just touch the edge of the paper stack.
    NOTE: When loading standard size paper, set the edge guides onto the notches on the paper tray to match the paper size.
  5. Close the paper tray.
  6. Set the machine to detect the paper size automatically, or manually specify the required size.
    NOTE: Paper sizes detected by the machine vary depending on the Machine Administrator setting. See the Related Items below for additional information.
  7. If the type of paper has changed in the paper tray, then the paper type must be changed on the Control Panel as well. See the To modify the paper type on the Control Panel section below.
Normally just the guides need to be set correctly in the paper tray, The tray size sensing switched may be bad or the actuator on the tray may have slipped position.
Jul 22, 2010 | Xerox WorkCentre M123 Copier
The copy will print, but parts of the copy are smeared and can be wiped off with fingers leaving nothing on the copy in those areas.
Bad fusing unit. The fusing unit is the assembly that get hot and "fuses" the toner onto the paper just before the paper exits the machine. If you or someone you know is mechanically inclined you could replace the unit yourself. $150 to $180 for the fusing unit.
precisionroller.com has them. Part# R3200
Replacement consists of removing the back cover so you can unplus the wiring. The opening the right side door and removing 2 mounting screws.
Good Luck and Thank You for uning Fixya.
Jun 21, 2010 | Xerox WorkCentre XL2140df Laser Printer
HELP HELP HELP HELP NOW! We are making copys on a Xerox XL2140df and it is blinking a red squigly light..... it won't print.  Flashes E.. help us. We need the copies ASAP.
OK first don't panic, Second the Squikly line ( does it look like a lighting Bolt sort of ?
this means you have paper stuck somewhere and and it needs to be removed.,Open the cassette and remove paper then open the side door then the front door and remove paper that is stuck ( BE CAREFUL not to touch the GREEN ROLLER THING ) thats called a Drum, you do not want to scratch that ok.
Nov 18, 2008 | Xerox WorkCentre XL2140df Laser Printer
Troubleshoot xerox workcentre xl2140df we have an error code E5?
An E-5 Normally comes from the paper path actuator that detcts the second side of a copy is hanging up.
In the fuser area there are some corrigated looking parts of the fuser exit guide that the actuator is most likely hitting or hanging up on.
You may have to take a pair of diagional cutters and snip a small section of that out.E-5 is a jam on duplex copies on that machine.
Jan 12, 2008 | Xerox WorkCentre XL2140df Laser Printer
Xerox WorkCentre XL2140df Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
