Question about Dell Dimension 4600 PC Desktop
Screwdriver for removing Dell dimension 3000 casing
I have just bought a replacement DVD drive for a Dell Dimension 3000 desktop but when I went to remove the casing the screws holding the casing looked like rivets, upon further inspection I discovered they have very small square holes in the centre,do you by any chance know which kind of screwdriver is required as I have been al round the local hardware shops with no luck and have assorted tool kits for laptops and desktops but nothing that fits this model, I would be very grateful if you could enlighten me as it's driving me crackers, cheers, Paul.
  • Paul Norton Jul 14, 2007
    Many thanks to everyone who posted replies to this problem, turned out that for this particular model there is a black plastic release catch for the outer casing which pushes down allowing the casing to be removed, no screwdrivers required! Paul.
  • Pat Haley Dec 29, 2008
    Hey, Im having the same problem, Can u help me?
    patrikhaley@hotmail.com
    Thanx, PH
  • 624 Answers
Murfsworld, You should post a new question asking for the manual. It'll keep things nice and neat and you'll get an answer sooner!
Posted on Jul 14, 2007
  • tomj23 Jul 14, 2007
    Paulpepe,
    Every Dell I have seen since 1988 (all USA of course) had Phillips head screws just like ImWireless states, however, what you describe sounds like a security screw. I?ve seen them in HPs and servers but they?re always Torx (6 sided) screws, what you describe (four sided) sounds like a security screw usually used in furniture. Whatever you have if you don?t want to go off and purchase a special screwdriver set you might be able to wedge a hex key or even a small jewelers flathead screwdriver in the hole and pull it out with that. Be real careful, if you strip out the screw holes you will have a tough time getting them out even with the correct tool. Make sure you replace the screws with conventional ones if you can.
    Scholar:
  • 113 Answers
For opening any Dell PC you would require 2 kinds of screw drivers, either a Small flat-blade screwdriver or a Phillips screwdriver. For further information you can refer the service manual. good luck
Posted on Mar 24, 2007
SOURCE:
What do I set my CD-Rom Jumpers to in a Dimension 1100
Which is it a Dell 3000 or Dell 1100 ?
The jumper settings on the rear of the DVD drive; set the jumpers to "cable select" mode (if you are uncertain how to set the jumpers, check the documentation that came with your drive or look for a diagram printed on the drive itself). Insert your DVD drive into the selected drive bay and connect the IDE and power cables. Use the screws that came packaged with the drive to secure the component to the drive bay.
Dell Dimension 3000 Service Manual
http://support.dell.com/support/edocs/systems/dim3000/en/SM/sm.EXE Dell Dimension 3000 Users Guide http://support.dell.com/support/edocs/systems/dim3000/en/OM/j6758A04.pdf
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
Need to replace cd-rom drive, how difficult? dell dimension 3000 pc desktop
It is not difficult to change cd/dvd drive.
Open cpu cabinet.
Then remove icd cable and power cable from cd/dvd drive.
Then remove screws of old cd/dvd drive.
Then you can pull it from cabinet from front side.
Then put your new cd/dvd drive into it's position then lock it with screws.
Then connect ide cable from motherboard and power cable to drive.
Then you can use it.
If you connect to drive with 1 ide cable means if you connect harddrive and cd/dvd drive with 1 cable then set harddrive as master and cd/dvd rom as slave you can set it slave with jumper settings.
It is in back side of cd/dvd drive.
There is instruction how to slave it with jumper.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 17, 2010 | Dell Dimension 3000 PC Desktop
DVD drive Read problem in my Dell Dimension 3000
Make sure you have any and all Windows 7 updates from Microsoft, along with any updates for your DVD drive for use with Windows 7. Some components work fine using Vista SP2 drivers, but some will need an update to work with Windows 7.
This Microsoft site might help verify if your DVD drive is compatible with Windows 7:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Feb 12, 2010 | Dell Dimension 3000 PC Desktop
Grinding noise from the disk drive
there a defective cd/dvd drive, try to change-it.
Jan 02, 2010 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000 CD/DVD drives not working
You can download the drivers from dell website, download.com, and many other sites. Download, then double click on them to install them. Once installed, reset pc.
Sep 13, 2009 | Dell Dimension 3000 PC Desktop
DVD drive help for Dell Dimension 3000
call DELL support and explain to them, they have send your the wrong type, what you have is IDE, they have send you the ATA. which the motherboard can connect.
Jan 09, 2009 | Dell Dimension 3000 PC Desktop
Help fitting a dvd rw to a dell dimension 3000
ok
i can try to help
i think u can remove the from panel
for that u will have some locks or screews remove that
then u can fix ur drive on the top panel
let me know how it is
if possible
Nov 18, 2008 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
DVD - RW WONT WORK -
Unfortunately optical drives do have a short life span, you can buy a replacement from newegg.com so cheaply these days its not worth messing with the old one.
I have just bought a DVD-RW dual layer OEM (so I had the burning software with it) for a new build I am doing for $28 plus delivery.
Jul 30, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 4600 PC Desktop Logo
353 people viewed this question
Clive
Clive
Alun Cox
