Question about Kenwood DNX7100 Car Video Player
I open my sansa view and the strip fell out
If I try to put it back in the control will start to work again
but only if im holding it down when I let go it disconnects again can this
be fixed?
    Problem Solver:
  • 26 Answers
It can be fixed yes, but please use a reputable Kenwood dealer to carry out your repair
Posted on Jan 23, 2009
Gateway M520X Plus will not power up?
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Nov 08, 2009 | Gateway M520X Plus PC Notebook
Laptop does not turn on have tried a new charger but still nothing
Oct 24, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 5920 wont start. light in AC chrger
Oct 12, 2009 | Acer Aspire 5920-6727 Notebook
Ok i have an hp laptop that was on an update and then the power turned off of no more power. Now i cant turn it on and i dont have a Operating System disk.
These are just a few steps to take....since there is not a whole lot to go with. we'll just try it a little at a time.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like a circle with a wedge cut out, it’s the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
Oct 10, 2009 | HP Pavilion dv6000z Notebook
Hi, by accident I delete some file from my sansa and it's not working now. Even my computer can't see it. I took the battery off and put it back and then is working just for a few seconds starting to...
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the SanDisk website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Sep 30, 2009 | SanDisk Sansa e260 MP3 Player
Sandisk sansa view not working any more
what happened was it probally damaged the tan stripp (which is probally the reason it was unattached) then when you took it apart you may have damaged the battery ( those batteries are very easy to damage) good luck with your m.p.3.
Apr 13, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
ACER ASPIRE WON'T TURN ON AND RED LIGHT FLASHING
acer aspire 5315 wont turn on, but the battery led lights up when the ac adaptor is connected..pls help.
Dec 20, 2008 | Acer Aspire 5315 Notebook
"Music folder not displayed "
The folders are hidden. I had the same problem but I fixed it.
This works for Windows XP but it may as well work with vista/ any other Windows operating systems
1. Go to My Computer
2. Go to your device and open it
3. Click on tools
4. Click on Folder Options
5. Go to the View Tab
6. Under Hidden files and folders click the one that says Show hidden files and folders
7. Click apply then ok
There, your music folder should show up and you will be able to put on/take off your music
Jun 18, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk keeps skipping/freezing songs!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
Wont work
Hopefully you find an answer, because i am having the exact same problem, please post your answer
Dec 27, 2006 | SanDisk Sansa e250 MP3 Player
Kenwood DNX7100 Car Video Player Logo
85 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
