Question about Baby Trilogy Innovative Corner Crib
Avalon On the Go Series Playpen side rails won't stay solid
I borrowed this item and there's no instructions and I can't get the long side rails to lock into position. They keep wanting to fold.
How do you lock an Avalon on the move series playpen? Where do I get instructions?
  • These playpens have a safety feature.
  1. First thing is to make sure the center of the playpen is up in the air.
  2. First lock the short side rails. They will click into place.
  3. Now lift up and lock the long set of rails.
  4. Now you want to push the center piece (floor) down all the way.
  5. Now your playpen is set up.
  6. When you go to put it up you will pull the floor up first and then release the side rails.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 17, 2011 | Baby Gear
I purchased an Avalon play yard and it did not come with instructions. I cannot get the sides of the playpen to stay in the locked position. What am I doing wrong?
I have the same play yard and it is a funny one to figure out but I believe that you lock the sides first then push the bottom down to lock it in place hope this helps
Sep 03, 2010 | Toys
How do I set up an avalon playpen? I can't seem to get the sides to stay up. Everytime I pull them up they just drop back down.
with the bottom still collapsed, straighten the sides, then they will stay. the bottom has to be the last part of the assembly.hope this helps ;)
May 20, 2010 | Graco 9445DOH Crib
Trying to put together a Foundations playpen but sides will not
The "trick" with the collapsing the foundations playpen is to step on the middle ring while pulling up on the "quick release latch in the middle of the long sides first, then the short sides.
Works every time!
May 15, 2010 | Baby Gear
Setup/takedown instructions
ihave a Avalon on the move series playpen model AP11 and i can not get it to close for traveling
Jul 13, 2009 | Avalon Baby Gear
Putting up and taking down of Graco Avalon playpen
If you take the mattress pad out and collapse the base, you can then lock the sides. I was in the same boat as you. Very frustrating. Hope this helps.
Dec 12, 2008 | Baby Gear
Instructions for Avalon ''On the move series'' playpen
I have had this problem with one of my daughter’s playpens. What I did was take the mattress out then pull the bottom part up. After that I pushed the buttons underneath the top rails and pulled up on those as well. For some odd reason this playpen WILL NOT collapse until you pull the bottom up. Hope this helps.
Nov 15, 2008 | Baby Gear
Baby Trilogy Innovative Corner Crib Logo
386 people viewed this question
Top Baby Trilogy Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Trilogy Baby Gear Expert? Answer questions, earn points and help others
