Question about KEF Audio PSW 2150 Speaker
Hooking the sub to receiver and how to set crossover freq. etc.
I don't have a manual for my PSW 2150 so I need to know where to plug in the single cable from my receiver (as you know there are four places where it can be plugged in). I also am not very tech savy so I would like to know the criteria for setting things like crossover freq., phase adjustment, what is the difference in performance for music vs cinema setting, and what slope means and what slope setting may be optimum. I would like to know how to obtain a manual for this sub,
  • katieo03 Feb 09, 2009
    the Sub outlet on my receiver.
    Sergeant:
    Champion:
  • 271 Answers
Single cable from where?
Posted on Dec 17, 2008
  • Roshan Vithanage
    Roshan Vithanage Feb 12, 2009
    what kind of jack is that?...if you see any area in the reciever wich you can plug that cable, look for the output "audio" labeled one, Then plug it in
Problems with JBL PSW D110
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
Mar 06, 2012 | Audio Players & Recorders
Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Jul 05, 2010 | Cerwin Vega AVS-5.1 System
I have linertec LA-8 olx Amp
IF ITS A POWERED SUB,,JUST USE RCA JACKS TO THE SUB TO THE RECIEVER VIA THE PLUG THAT SAYS SUB
May 14, 2009 | Yamaha HTR-5850 Receiver
I dont know how to connect a JBL PSW-D115 into my receiver
Connect the receiver's Subwoofer Line Out to the Sub's Line In with a single RCA cable.
Not knowing your specific receiver I can only advise that you get into its setup and 1) tell it you have a subwoofer; 2) set the other speaker types you have regarding Large vs Small (meaning can they handle REAL bass); 3) go through all the channel level setup; 4) Rock On.
Apr 26, 2009 | JBL PSW D115 Speaker
No Signal on sub preout on my Onkyo TX-SR703 AVR
Well the next step would be to make sure that all the settings are set to subwoofer yes, and set your crossover as well.  The amp usually has a crossover which tells the microprocessor which frequencys to send to the sub.
Jan 06, 2009 | Onkyo TX-SR703 Receiver
Marantz sr6200 problem
I think it may be related to set up of crossover frequencies within 'menu'. There's a menu where speaker sizes are set, as far as I remember the lowest setting suggested crossower freq for sub somewhere at 80hz as default which may be too high of you have sub.
Mar 04, 2008 | Marantz SR-6200 Receiver
Open Questions:
See all KEF Audio PSW 2150 Speaker Questions
KEF Audio PSW 2150 Speaker Logo
523 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Greg Cann
Greg Cann
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
