Question about Gateway MX8711 Notebook
Gateway MX8711 DVD/CD drive not working
Did you figure this out? I have the same exact problem, hope to hear from you. Andrea
  • alan_e7 May 11, 2010
    are there any error messages that go along with it.. like" windows has diabled the drivers" because of your copy software?
Need service manual for GATEWAY MX8711 Notebook
You may find one on a CD from flea bay.
Oct 27, 2013 | Gateway MX8711 Notebook
Y Gateway mx8711 does not write cdr or dvd's it reads them fine but does not write.
Is the WARRANTY on the computer still valid?
Either way, take your computer to a repair shop, and get the "broken" optical drive replaced.
Nov 05, 2010 | Gateway MX8711 Notebook
DVD stuck, computer won't turn back on
If you look at the door of the CD/DVD tray/shelf, you should see a little hole. Stick a paper clip into the hole and it will pop out the CD/DVD tray/shelf and you can get your DVD back. I would call Gateway support to fix the rest of it. If it is still under warranty, they can send out a tech to fix it.
Sep 28, 2009 | Gateway MX8711 Notebook
Hardware reset button
Take a back up cd, and back your stuff up, then serch for it on your computer when you log on.
May 27, 2009 | Gateway MX8711 Notebook
MX8711 notebook, no sound
Although gateway doesn't provide free phone support for Refurbished models all of the original software can be restored individually from the restore set(assuming you made it) or downloaded for free from gateways website.
If it's simply an issue with the update causing a problem, try re-installing the sigmatel audio driver from the driver and applications DVD you made, or if you didn't make one click the link below and scroll down to the sound section. You can download a fresh copy from there.
Hope this helps FixYa,
May 14, 2009 | Gateway MX8711 Notebook
I cant play my DVD player, on gateway
your DVD drive lens needs to be cleaned by a lens cleaner CD....try it if not worked..then your lens is faulty...
Feb 19, 2009 | Gateway ML6721 Notebook
Gateway MX8711 PC Notebook
Check the following image for view of the bay (when upside down, the HDD is on the bottom left corner, just pull the screws, pull the cover and replace - powered off, of course):
Jul 13, 2008 | Gateway MX8711 Notebook
Battery Charging Gateway MX8711
How to replace the CMOS battery. In some cases this can charge the battery and resolve your issue. This often resolves CMOS battery related issues when a computer has been left off for ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Gateway MX8711 Notebook
Gateway MX8711 Notebook Logo
312 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
