Question about E-Machines eMachines Desktop PC
Connecting a printer
There is no port on the tower for my printer
  • better-swiss May 11, 2010
    tlsouth,
    does the printer need a USB connection or a parallel one ? What brand is it ?
    President:
  • 1,179 Answers
Most newer printers connect using a usb cable. Try connecting this way & see if it solves your problem.
Posted on Dec 20, 2008
Vga port not working
Before you conclude finally, swap both the monitor and/or the tower with another system you see is working (both consoles please; monitor and tower interchangeably).
That way, you'd confirm which is faulty/defective: VGA port on tower or monitor cable
Oct 11, 2017 | Computers & Internet
Hook up to home pc
Today's laptops and desktop computers are more user-friendly. As more people start use computers, operating systems, software and hardware accessories are coming with better instruction manuals and streamlined interfaces. Here are a few basic steps to hook up your computer no matter which brand you bought.
Connect the power cable to the back of the computer tower. The male end of this plug is often on the computer, but it is recessed into the casing. Once this power plug is connected, you don't want to plug it into an outlet until the entire computer is set up. Attach the monitor cables to the back of the monitor and then to the back of the computer tower. This cable will probably be the VGA type, which has a wide set of prongs in the middle and two screws on the outside. Be sure to twist the screws in to ensure the cable has a solid connection. Secure the monitor's power cable to the back of the monitor and then plug it into an outlet or power strip. Attach the mouse to the USB port on the back of your keyboard. The keyboard then plugs into another USB port on the back of the computer tower. Turn on the computer and the monitor.
If the computer powers up but the monitor doesn't display anything, make sure the VGA monitor cable is secured. If the status light on your monitor doesn't turn on, check the power cable connection. Check that the mouse and keyboard work once the computer turns on. Now you can hook up other devices, such as a printer or a web cam. A printer often can connect to a USB port and also may have its own power cable; a web cam usually just plugs into a USB or firewire port.
b>
Jan 21, 2013 | Acer Aspire 5535-5050 Notebook
Printer
There is no way- if the computer has NO available USB ports, buy s USB hub ( a multi outlet USB expander/extender cable). If the computer has no USB ports (outlets) AT ALL- it is ancient, but you might be able to install a USB expansion card into the computer and get external ports.
Aug 29, 2012 | Epson Stylus CX6600 All-In-One InkJet...
Were does my chords go
The category of computer determines the wiring setup requirements. For example, setting up desktop computers is achievable differently than laptop computers. First, laptop computer has built-in ports only accepting cable connections from alternative devices mentioble as printers, faxes only mentionable examples. Peripheral device connections to laptop computer would usually be made possible with USB cables as the most versatile media link. Perform an observation on the ports area of the laptop computer to ascertain type of wiring usually indicated by design logo next to the port connection areas. Alternately, desktop computers have wiring complexities because of the several components that comprise an entire personal computer as also known PC. Desktop computers have a station unit where every device has to be connected to derive functionality. The unit also known as tower station or flat station depending on conditions that the remaining components lay along side or are piled on top of each other provides the name versions of PC units. Usually every components of desktop computer has to be connected to the unit taking peculiar attention to place the appropriate connection cables in the most suitable ports provided. For example, desktop computers require monitors as the computer display unit. The monitor is required to be connected to the tower unit or flat unit from where the processing instructions are acquirable. Prior to any connections, observe keenly the ports areas that have been provided demarcation logos determining which links placements are appropriate. Usually desktop PCs require monitor, keyboard, mouse connection acquire user experiences. The PC tower would have separate ports for each peripheral device requiring linkage. Observe keenly the ports provide located usually at rear view of the tower station prior to connection establishments. The computer user manual provides diagrammatic displays of the connectivity requirements of each component. However, computer connections area achievable by trial by error where the appropriate connection yet to be attained with practice.
Jan 25, 2011 | Computers & Internet
Mp 350 printer shows off line, no led's,tried diff pwr outlets,
The printer is not getting detected by the computer.
Instead of reseating power cord try to connect the usb cable to another port at the back of the computer tower.
Turn off the printer and then restart after 1 minute.
Jul 28, 2009 | Canon Office Equipment & Supplies
Cannot find the proper connection on the back of tower for a 7660 hp printer cable?
You should have a usb port you can hook the printer cable.All computers have more than one.Make sure you have the right printer cable.
Nov 26, 2008 | Office Equipment & Supplies
COM PORT problems
Most of china mobiles are connected to computer using COM Port(Scanner port or Printer port) but not to USB port using any USB cable(as in the case of Nokia, Samsung,LG,....)
you will find some special cables in the market which connect your china mobile to COM port(which is on the backside of your computer tower- red colored ......
here the Cable will make the difference.....
Thanking you
M. Sridhar
Jul 25, 2008 | Dual Electronics CECT P168 Cellular Phone
Memory Stick
dcp 130c cant transfer plain data. Its a pic bridge (digital camera standard) connection only.
You have to use your PC USB.
Jan 10, 2008 | Brother DCP 130C All-In-One InkJet Printer
PRINTER PORT FOR HP A6230N
I am sure it came with USB ports, most design nowadays expect you to buy USB enabled printers.
So I advise you buy a USB - CENTRONICS or USB - SERIAL cable depending on the type of printer you have.
You will connect the USB end to your computer and the other end to your printer.
If your printer is fairly recent, you might even have a USB port on it, so check.
HTH.
Dec 05, 2007 | HP PAVILION A6230N DESKTOP PC
E-Machines eMachines Desktop PC Logo
55 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
