Question about Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook
My wifi is not working i hve lenovo y410 laptop earlier when button was switched a pink light glows but now it is not working ,however i can access net from LAN, help me or give me no. of customer care in delhi
    Problem Solver:
  • 12 Answers
Go into program and turn it on// start there
Posted on Dec 17, 2008
  • ericbranagan Dec 31, 2008
    For Wifi driver problem, you may need all of wifi driver needed except Intel PRO Wireless drivers and update your Intel Wireless driver here (for Vista) or here for Microsoft Windows XP.also hotkeys (usually fn plus another key such as f10 turn it on and off too. let me know...well get it.
I dont know to use wifi in LENOVO 3000 Y410
Hi. First things is you should have a wireless router there or you are at a certain hotspot where there is a free wireless internet access e.g Starbucks. Procedure below:
  • 1 Purchase a wireless router that fits your needs and price range.
  • 2 Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • 3 Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • 4 Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • 5 Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • 6 Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • 7 Click on "Properties."
  • 8 Select the "Wireless Networks" tab.
  • 9 Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
  • 10 Click on "Configure" when you see your network's SSID in the "Available Networks."
  • 11 Enter your network's SSID and WEP key.
  • 12 Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • Sep 05, 2010 | Lenovo 3000 Y410 Laptop
    I have lenovo g430 4152 laptop how can i find my wifi and bluetooth fn key
    go to start>run>msconfig
    select start-up tab
    tick the blutooth
    apply ok
    restart
    Oct 28, 2009 | Lenovo 3000 Y410 Notebook
    Bluetooth/wifi doesnt works
    Same problem occured at HP laptops. Unfortunate, problem comes from the board. Somewhere has got crack or broken link. Last time I have checked, I find , Top of the board and bottom of the board has got copper lines and devices soldered, but there is also middle lines that not possible to access and repair without shematic diagram. I end up changing the board that solve the problem. But Before that I install driver, restore again (seems worked forawhile) remove the wireless card check solders, setup network again. None worked. I do not want to give you bad feelings but, if it is Vista, reload the drivers and see if will work.
    Hopefully it will. Do not touch the switch much, there are P.O.S. Small spring inside the switch is loose everytime and it is not gold plated, get rusty couple of months. Goodluck
    JMC
    Aug 17, 2009 | Lenovo 3000 Y410 Notebook
    Wifi driver of Lenovo Y410
    hi
    You will need to find the model of the wi fi card, once you have that, go there website and download the drivers. Its normally intel, but check first.
    Mar 26, 2009 | Lenovo 3000 Y410 Notebook
    Bluetooth & WiFi not working
    0. Check if your wifi module is turned on by switching on a hardware switch on a border or back of your laptop.
    1. Click once on right bottom corner on icon with two monitors.
    2. Choose connect to network.
    3. Choose one of access points
    4. Enter password
    Mar 22, 2009 | Lenovo 3000 Y410 Notebook
    I want to connect wireless to my lenovo 3000
    first check that the drivers for your wifi is installed or not , in device manager, if installed then switch on the wifi button, it will search for the network in range then select connect option
    Nov 27, 2008 | Lenovo 3000 Y410 Laptop
    Lenovo 3000 Y410 Wifi Problem
    That is odd, I've never seen anything like that. I asked a few of the other top experts, and they've never heard of anything like that happening either. There are no adjustments for this type of thing. It could be too strong. How far away from your house can you get with the machine still seeing the wireless? I hate to say it, but you may just have to live with it, and, honestly, I think it's more their problem than yours. I'll look around some more on this, since you've got me curious, and if I find anything I'lllet you know.
    Aug 21, 2008 | Lenovo 3000 Y410 Notebook
    Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook Logo
    153 people viewed this question
    Top Lenovo Computers & Internet Experts
    Michael Vincent Cruz
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
