Question about Sony Playstation 3 (PS3) Console
How do I get my PS3 Online?
Hi I have the 60GB PS3 but I cant get it online. I am using an Wi-Fi USB key to connect and my pc and PS3 reconise each others presence but it is not connecting to the internet. It does show my IP adress but it wont connect.
  • 21 more comments
  • the wrestler Nov 23, 2007
    hey happy holidays.I have a wireless internet connection in my apartment and my my notebook works just find.however I can't get my PS3 online.it keeps telling me that my IP adress timed out.what do I do,is it my internet connection or is it my 60GB PS3?
    okay,I entered all the the adress 3#'s,now it says obtain IP adress"succeeded",but the internet connection failed.at the bottom of the screen it says "An error occured during communication with the server.This is a DNS error.(80710102) what does this mean and how can I connect online with my system?
  • hkfgrny Dec 29, 2007
    my IP adress keeps saying time out
  • Anonymous Feb 21, 2008
    I.m following the same procedure as mentioned but the connection error code i m getting is 8013013E
  • coogie Mar 12, 2008
    i have a 80gb ps3 and my internet has been working fine until 4 days ago. every since thin my ip address has ben timing out on the test
  • Chewbakka Mar 16, 2008
  • Anonymous May 11, 2008
    how do i get my ps3 online
  • realplayaz May 28, 2008
    when i go to sign on it keeps going time out on my ip address
  • bagnell Jun 24, 2008
    how do i get my ssid code
  • pete1884 Jun 26, 2008
    i have already set everything up and my internet was working for my ps3 then we switched modems so i put everything in again and now my wireless does not work how do i fix it?
  • Anonymous Jul 02, 2008
    The attempts to obtain an IP address time out
    MY PS 3 IS RECOGNIZING IT ALSO BUT WON'T CONNECT TO INTERNET
  • Anonymous Jul 06, 2008
    wont find ip adress, when enterd manually wont find internet connection
  • Anonymous Sep 09, 2008
    I have a problem because everytime I check my internet connection there's always an error with my my DNS server what can I do?
  • walker_j9 Nov 02, 2008
    when wired or wireless can obtain ip address but keep getting dns server error 80710102 please help it is the only reason i bought the ps3
  • Anonymous Nov 14, 2008
    i think that the 60gb version has got a bug or something
    my ps3 recognises the internet but it can't find the ip address
  • Anonymous Dec 06, 2008
    I fail to obtain an IP address when i am hooked wired to a D-Link Ethernet broadband router
  • Nick102 Dec 28, 2008
    I can't get internet on my 80GB playstation 3 it keeps on saying to obtain IP address on wired connection can somebody please tell me how to obtain an IP adress.
  • Anonymous Dec 29, 2008
    Every time I try to hook up the internet it says the connection failed to pick up an IP Address it timed out or something. What do i do?
  • addison2485 Jan 02, 2009
    My ps3 says that it is finding an internet connection but fails to obtain IP address. What do i do?
  • bishface94 Feb 04, 2009
    i have the same problem, i cannot obtain an ip address cos it times out on the connection test. Does anyone have a solution cos i really need one???!!
  • Anonymous Mar 13, 2009
    I HAVE A NETGEAR WIRELESS ROUTER When i connect it to my pc it will not connect to the internet but my PS3 can recognize the router.
  • rhino33 Mar 28, 2009
    i plug my internet modem directly to my PS3 and it worked fine untill recently, now it is saying that my ip adress timed out, what should i do
Right fist of go on settings on the ps3 menu then go to network setting then click onsettings and connection status list take a note of all the ip addresses and servers then go to internet connection on the same menu and click on scan then click on your router name and then lick onenter ur wep key if u av 1m but if u dnt then cck on none then press right then go o custom on the address setting then manual on ip adress settings type in all ip address and servers and stuff then click on auto on the mtu dont use proxy server enable unpn click right then press x to save ur settings then test connection thn hopefully this works for u m8 cheers arsenal_07
Posted on Mar 25, 2007
My son is trying to get online again with his ps3 and he keeps getting the error message
8013030F. We have tried everything. It used to work fine, but stopped a couple of days ago.
Posted on Nov 26, 2008
I was having problem connecting my PS3 to the internet as well until I tried the power cycle suggested by the manual. With the PS3 on, I unplugged my modem and router and turned back on after 2 minutes, so that the router can recognize the PS3, then when I scan for the SSID, the PS3 picked it up right away, and from there it was easy! After I connected to the Internet I found the signal was getting dropped. I found that if I pulled the PS3 out of my AV console drawer I get better signal. Now I am browsing the internet and can't be happier!!
Posted on Dec 22, 2007
When i first got my Ps3, i tryed to update it and it automaticlly signed in using wi-fi from another internet source. Now it doesnt work...is that because the signal is weak, or because im technically stealing the net?
Posted on Jan 30, 2010
Uh my ps3 is trying to obtain my ip adress but before it does it times out
Posted on Nov 23, 2009
    New Friend:
I got battlefield 3 preiuum edition on ebay tried to use the code it said it was alreday used that makes me really mad what do i do
Posted on Apr 19, 2013
I pluged it directly into the router with an cable after five tries tries to go wifi. Got Nat Type 2 now and it's working great.
Posted on Feb 16, 2008
Hi i have a ps3 and i dont now how to get it online
Posted on Jan 16, 2008
Is it possible to get a wireless connection to the vaio PCV-RX221
Vaio PCV-RX221 does not have Wi-Fi capabilities. If you wish to connect it to Wi-fi, you can use a USB Wi-fi LAN Card, which can be connected to any USB port of the PC and can be used to recieve wi-fi signals/ data. Note that PCI Wi-fi LAN Cards are also available, which are internal and added to PCI Port of the PC.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Sony VAIO PCV-RZ221 PC Desktop
Sitting in a Starbucks trying to connect to Internet. Get error code 052211-1. Unable to connect settings and access points
The reason this is happening is because Starbucks makes you login to an account before you are able to access the internet. Unfortunately the DSi is unable to use this login page as the DSi does not have a web browser. However there is still a way for you to get online.
You will need
  • A laptop
  • USB Wi-Fi connector for the DS
Then just follow these steps
  1. Turn on your laptop and access the Starbucks Wi-Fi
  2. Plug the USB Wi-Fi connector into your laptop.
  3. You should now be able to easily play your DS online
Jun 13, 2011 | Nintendo DSi Black Console
How do i find out what my wep security key is to get my ps3 online
Your WEP security key is actually the password used to login your home internet Wi-Fi. You can ask the person who set up your home Wi-Fi for the key.
Apr 03, 2011 | Video Game Consoles & Games
I have a ps3. I want to know if i have to hook the ps3 directly to my wifi box or will it connect like a laptop
hi, the answer is yes it has wifi go to the Network Settings and then set "Wireless" on the Internet Connection Settings section.
40GB, 60GB, and 80GB all have Wi-Fi. Only the 20GB doesn't
Dec 14, 2010 | Sony Playstation 3 (PS3) Console
Can you hook the ps3 up to the internet wirelessly
Yes you can connect wirelessly to the internet with your ps3.
Minimum Requirements
  • PlayStation®3 computer entertainment system
    Note: PlayStation 3 40GB / 60GB / 80GB / 160GB models ONLY (20GB model does not have built-in Wi-Fi connectivity)
  • SIXAXIS™ wireless controller (and USB cable)
  • AC power cord
  • A high-speed Internet account (cable or DSL) with an Internet Service Provider (ISP)
  • Router
    • Wireless router compatible with 802.11b or 802.11g Wi-Fi standards
    • Or an Ethernet (wired) router with a Wireless Access Point (WAP)
      You may need to open firewall port numberson your router to connect to the Internet.
      The PlayStation 3 will not connect to the Internet through the USB ports.
  • Updated system software installed on your PlayStation 3
    Visit PlayStation 3 System Software Update to download and install the most recent version.
  • Your Wireless Network Settings
    • SSID
      You will need to know the Service Set Identifier (SSID) of your wireless network. Also make sure the WAP or wireless router is set to broadcast the SSID; otherwise, the SSID will NOT appear on the PlayStation 3 scan results.
      If you do not know this information, speak to the person who configured your home network (i.e., wireless router) settings.
    • WEP or WPA Security Key
      If your wireless network access is security-enabled (encrypted) from open access, you will need to know your WEP (Wired Equivalent Privacy) and WPA (Wi-Fi Protected Access) security key or password
      If you do not know this information, speak to the person who configured your home network settings.
    • MAC address
      You may need to enter the Media Access Control address (MAC address) of your PlayStation 3 into your WAP if it is required by your network settings.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Cant connect wii to internet
The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
i hope this helps
Nov 05, 2009 | Nintendo Wii Console
My mario kart wi-fi connection disconnects halfway through a race why?
It might be your connection. I've found that if someone else is using the internet/pc etc while I am playing, it will obviously interfere with my game. So to be safe, I pretty much make sure I am the only one accessing the internet/online when I play an online game like Mario Kart.
May 03, 2009 | Nintendo Mario Kart (Wii) for Wii
Update
im sorry but you might have to be a bit more specific. I dont think u can update a ds game. and u cant connect it to the computer. the possible putcome i gathered from that is that he wants to play his game online and trade pokemon etc. meaning u need to connect the ds to your computer wirelessly using a
-nintendo wi-fi usb connector-( a usb drive u basically plug into ur computer and gives off internet for nintendo products) or a -wireless router or modem- ( the black box that the cables go through for internet).
When your grandson plays the game and wants to go online, (i will explain how to use this using directions in the game)
1. turn on the ds and load the game
2. watch the introduction movie (shiny pokemon)
3. on the main screen where you decide to either continue, new game, or -NINTENDO WFC SETTINGS-, go to nintendo wfc settings
4.tap the blue box labelled nintendo wi-fi connection settings
5.if ur using a Wi-fi usb tap connect to wifi usb or if using wireless internet tap a blank connection square
6. follow the prompts for the wifi usb and u will be connected to the internet
7. for wireless internet, tap search for an access point
8. when it has found the wireless internet tap O.K/connect/next etc and follow the prompts
9.when thats connected return to pokemon Diamond main screen then tap new game/continue to play
10. walk to the pokemon centre and go downstairs to battle online - or go into a house in
(Jublife city?) to trade pokemon online
WOAH!! that was a lot of writing!
hope i helped plz make a comment or something if u need my help again
Sep 13, 2008 | Nintendo DS Console
PS3 INTERNET
wi-fi comes built in 2 the ps3, but i dont have one so im not sure how to set the connection up
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Sony ps3 online
First off do you have wireless internet you trying to get it connected to or are you using a cord straight to your computer/internet plug in, if its connected to a wi-fi try getting the ps3 closer to the wireless box on you computer, if its connected by a cord try using a different cord as the current one you are using may be faulty
Jan 09, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
5,570 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
David
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
