My computer says the scanner is not hooked up to the computer
This is the message it gives me whenever I try to scan something into the computer. "The computer can not detect the scanner or camara. Please make sure the device is turned on and is properly connected to the computer." The computer is on and im pretty sure everything is connected. If it helps any, it's an HP Color LaserJet 2840. The last printer I had was just a simple dell printer/scanner and it worked perfectly fine. How can I get my scanner to work to where it will scan pictures into my computer?
  • mil0153 Dec 17, 2008
    My all in one printer will not scan a picture and send it to my computer. Do you understand what I mean?
  • ericbranagan May 11, 2010
    what????
    Filmmaker:
    Uploaded 5 video answers.
  • 26 Answers
Click on start, go to my computer n click the button. next look for the hardware installed eg.web cam etc and see if its located in there. if so left click the mouse n go to propertys and check its installed properly x failing that go to add and remove programes look down your list for it then uninstall it and retry install again x
Posted on Mar 14, 2013
    Problem Solver:
  • 12 Answers
9966 is right...this is exactly what i would suggest first
Posted on Dec 19, 2008
    President:
  • 2,351 Answers
Hi mil0153, go to this web site: http://welcome.hp.com/country/us/en/welcome.html#Support
Make sure your printer is connected to the computer & the printer is turned on.
In Step 1. Click the emty circle next to, "Download drivers and software (and firmware)".
In Step 2, click "Start Detection >>" button. Allow HP to install some software. HP will scan your system & find your printer. HP will install the correct updated software & or tell you what is needed for the LaserJet 2840 to function correctly. Follow all on screen instructions.
Good luck mil0153!
Thank you for using fixya
Merry xMiss!
Mike
Posted on Dec 17, 2008
Gestetner Aficio MP 1600 was connected to my System and I use it as photocopier, scanner and printer. The machine's Drum was changed of recent and it has failed to scan any of my documents. However, I...
Hello!
Changing the Drum does not affect the scanner settings.
You can print because your PC (computer) can see your machine but for scanner is the oposit. The machine must see your PC.
I think that in this machine you have an SD card with the scanner funtion. Try to take it off and then put it on again. (the SD card is on its side. In the controller box)
If you still have any doubt reply to me.
Aug 01, 2011 | Ricoh Aficio 250 Copier
My scanner won't scan. I get the message " Scanner is busy, operation can not be completed. Canon DR-2010C Driver Version 1.1.10805.18001 (-4437).
This may mean that something is using it or that something is interfering with it. Try turning everything off, your computer AND your scanner. Wait a minute or two and then turn your scanner on first and the turn your computer back on. When your computer boots back up don't open anything except the scanner. If your still getting the message then there is something else (another attached peripheral) that may be interfering with the scanner.
Oct 29, 2010 | Canon DR-2010C Flatbed Scanner
The printing function works, but whenever I try to scan something it comes out all black, and whenever I try to copy something, it comes out just gray without the text.
This is the problem with scanner. pl clean the scanner lamp and nearby mirrors. if the same problem retains pl replace the scanner lamp
Aug 09, 2009 | HP PSC 1610 All-In-One InkJet Printer
I have a similar problem. I use a windows vista and print easily.
go to help from ur printer/scanner and see if they cn help u there........
if i have the same problem uninstall prigram from add/remove and reinstall printer.....mae sure before u do this to remove all cables from ur pc to printer including the power cable....insert the disc and follow the wizard instration.....hope this will solve ur problem
Jul 03, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Can't use scanner
  • Hi there,
    • Unplug the Scanner cable from the computer.
    • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
    • restart the computer
    • try to download drivers from the website
    • after installing drivers and software it will ask you to connect the Scanner.
    • then you can connect the Scanner and and try to Scan.
    Hope this help. Please Rate My Response! Thanks!
    GF
Apr 27, 2009 | Office Equipment & Supplies
Error message while switching on the scanner
sigo con el problema del escaner s2w 6400ut bloqueado me dice que siga la guia rapida para su desbloqueo
Apr 01, 2009 | BenQ Scan to Web 6400UT Flatbed Scanner
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
ayyub_thakur@hotmail.com
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP Photosmart C4280 All-In-One Will Not Scan
hi
i had the exact same problem and i installed and un-installed
over and over again
and then it hit me !!!
why bother ??? , just download a 3rd party scanning software like "VueScan" or any other you find on google and it does the job !!
it's light, recognize the scanner (C4280) automatically and scan !!
cheers
Sep 22, 2008 | HP PhotoSmart C4280 Laser Printer
Scanner/Director problems since installing new ink cartridge
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=45391&lc=en&cc=us&dlc=&product=90764
Dec 28, 2007 | HP PSC 1210 All-In-One InkJet Printer
200 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
