Question about HP OfficeJet 6110 All-In-One InkJet Printer
Connecting my hpdeskjet 3820 to my new computer
The E1400 processor does not have a port for a printer cable. Is there a plate to take off the back to access a printer port?
    Problem Solver:
  • 12 Answers
No. you need to get a pci serial port card or go usb if the printer allows
Posted on Dec 17, 2008
HOW TO CONNECT HPDESKJET D2545 PTINTER
The D2545 is a basic USB printer. The USB 2.0 (A-B M/M) cable is not included. The installation steps are 1) plug in the power cord and turn on the printer, 2) make sure that it has paper and ink, 3) connect the USB cable to the back of the printer (the square end) and to the computer (rectangular end) with the computer on. The Windows or Apple OS will then install the basic driver software. If this step does not occur, check if your cable is fully seated. Next try a different USB cable and a different USB port. If you are using a USB hub, try a direct connection to the computer's USB port. If the driver software still doesn't work, check that the correct USB driver is installed and working. In Windows, go to the Device Manager. (Press the Windows Key + X in most versions of the OS or go through the Control Panel under Hardware. That involves left clicking the Start button for Windows 7 and lower. For Windows 8.1 and 10, right click on the Start button.) If you see a triangle with an X or an exclamation point, you have a driver problem. Check the computer manufacturer's site for updated drivers.
Go to http://support.hp.com/us-en/product/HP-Deskjet-D2500-Printer-series/3374272/model/3571289/drivers if you want the full featured software and drivers.
I hope this helps.
Aug 23, 2015 | Office Equipment & Supplies
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
Computer don't start,
If it doesn't start at all, check motherboard for a short by unplugging the processor power cable (4 pin normally), and turn the computer on. If the fans start rotating, it is probably a short. If that isn't the problem, check for cables that should be connected, and test the processor in another computer. Hope it works (it did for me)
May 27, 2014 | Powerspec G213 Desktop Computer; Intel...
My 3820 will no longer scan Follett barcodes. It makes several error beeps every time I try to scan anything
srodgers609
One of the problems I had with my scanner is that the USB port that I had the scanner in when bad. My scanner cable was a little short and it put extra pressure on the port. After time some of the connections in the port broke. To fix the problem I had to replace the USB card in the system.
So I would recommend that you tryu the scanner on another computer and/or another USB controller to see if it works properly. If it does you know that it is the USB port. If it does not then I would look at the cable of the scanner.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 25, 2011 | Honeywell 3820 Wireless Handheld Barcode...
Hello. my deskjet 3820 can't be recogonized by the
make sure the usb cable is properly connected.and you install ed the driver correctly.for solving the issue,
right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the printer driver .
Jan 25, 2010 | HP DeskJet 3820 InkJet Printer
I have an old HP deskjet 3820 printer and a new HP pavilion desk top which has only USB I/O ports, no parallel ports. Therefore I need an adapter cable to connect my printer to my new PC. Does the adapter...
You can almost buy a new printer for the cost of the adapter you are talking about buying. They have all kinds of adapters: the kind that connects to the flat end of a USB or the square end. Parallel, male or female. Go to a computer store like best buy, they should be able to hook you up.
Hope this helps.
Dec 10, 2009 | Cars & Trucks
I'm trying to get my hp deskjet 3820 driver working the computer said the new hardware is in working order but cant print anything, please help
dear uninstall driver unplug printer ........
restart system install driver
and after restart plug your printer ...
but many setup say between setup plug in printer thn plug in ok.....
enjoy it ....
Dec 06, 2009 | HP DeskJet 3820 InkJet Printer
What cable do i need to connect HPdeskjet 840c to my laptop Compaq cq71-140ea.
Your HP printer model has two interfaces, Parallel and USB.
Your Compaq laptop does not have a parallel printer port, but does have three USB ports.
USB is definitely the way to go. Obtain a USB cable (version 2.0, not 1.1) from Best Buy, Fry's Electronics, Radio Shack, Office Max/Depot. ($10 ~ $20) Try to keep the USB cable length at six feet or shorter, for best performance.
Oct 07, 2009 | Compaq Computers & Internet
Print cartridge
This may sound simple, but did you remember to remove the tape covering from the ink cartridge before installing it? If so, run a self-test and let me know the results:
1. Turn the printer ON.
2. Press and hold the POWER button.
3. Press the RESUME button FOUR times.
4. Release the POWER button.
You should get a nicely printed self-test. If it fails, there may be other troubleshooting methods we can employ.
I hope this helps!
Regards,
Char1ieJ
Sep 08, 2008 | HP DeskJet 3820 InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
