Question about Magic Chef CYE4000AWW Electric Dryer
Heating unit When I turn my dryer on, the heater turns on for a couple of seconds and then shuts off. Everything else works. I have taken it apart but dont notice anything obviously wrong. What should I try?
  • bewoolard Dec 19, 2008
    I found out that the problem was with the thermostat. It caused the heater to cut off. I replaced it, and now it works great.
  • 113 Answers
First thing to check is your air flow, check the vent on the outside of the house where the exhaust enters. Should be blowing pretty hard. Any restriction will cause the heat to turn off after a couple of seconds. Hope this helps. Dave www.washermd.com
Posted on Dec 17, 2008
Heat not working - I have taken apart whole dryer and tested everything - last is control board?
You need the dryer checked with a volt meter point to point to see where you are loosing the voltage. This must be done with the power on and is dangerous for someone who has no background in this type of troubleshooting. If the unit has a circuit diagram that you can read, you need to check for voltage on the circuit board. This unit operates on 240 volts and can cause serious injury if the powered terminals are touched. If there is voltage on the circuit board that going to the heating element, the board is probably good.
I think you have done about as much as you can, and maybe it is time to call a service company.
Dec 24, 2015 | Kenmore Dryers
I can't figure out how to access the heating element to see if it's the problem. I've taken the back off but it doesn't look like any of the repair videos.
On the dryer door there is a some kind of switch or button that shut off the dryer when opened if you can push it in and turn on the dryer and you should feel the heat or see the heater coil getting hot.
Aug 20, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Intermittent No Heat
if you checked all the t-stats and they checked good the only two things left is the board and the motor,it takes 240 volts to get heat 120 comes from the board and the other 120 volts comes from the motor,first go to the block where the cord connects to the dryer and make sure you have 240 volts there,but you say you changed the thermister and you had heat?check both thermisters to see if you get the same reading on them both should be around 10k ohms,that could of been coincidental With the resistance value at room temp on the thermistor being good then this would not be a thermistor error. There are 2 components other than the thermostats which would cause the heating element not to work. First is the motor and second the Control board. The best option is to disconnect the power to the unit and access the heating element. Disconnect one wire that is going to the heating element, preferably the one on the thermostat side. Plug the unit back up and using a multimeter you will want to turn the dryer on and test for 120 vac at the terminal on the heater where the wire was disconnected. What this will do is eliminate the heater element itself and the motor. If there is 120 vac at this point then you know the heater is good and the motor is good because the other 120 vac coming through the thermostats is the control board side of the circuit. If there is not 120 vac at that point then you will want to test the other terminal on the heater and check for 120 vac. If there is not 120 vac then the motor would be bad .
Feb 01, 2018 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool dryer model LEN2000JQ0. The heating element glows red and gets really hot. You can feel the heat and smell the heat I go to turn on the dryer it makes a buzzing sound and the drum will...
I would change the control thermostat. It is mounted next to the skinny white fuse on the filter housing under the dust cover on the back side.
I worked on a dryer like this that had a heat problem and wrote about it HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 31, 2012 | Dryers
Heating element is getting too hot and shutting down dryer
Disassemble the dryer again and check the blower wheel on the motor shaft. It may be slipping.
Also,remove the rear exhaust vent and run a load. The blockage could be in the outside exhaust.
May 25, 2010 | Maytag PYE2300AY Electric Dryer
I have a estate whirlpool mod # TGDX640PQ0 and the dryer runs and there is no heat. i took it apart and i saw that there is no flame or what you would call it. but everything lese works just fine. what...
you have several things to look at, 1 - is the vent abstructed or pluged up with lint? 2- is there gas to the unit and is the valve turned to the on position? 3- is there spark when you turn the unit on and if the dryer isnt shutting off then you may have a problem with the timer or comp. board
Aug 23, 2009 | Whirlpool GGQ8831L Gas Dryer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Hotpont/Zanussi Electric dryer TC7102W no timed heat
it seems thatyour getting no heat on the permanent press and gentle cycles correct? if we know the heater is working that takes care of a number of possible causes turn the power off and remove the rear panel of the dryer. you will see a couple of thermo disks mounted on the heater box.you probably will find tons of lint on these thermostats and what happens is you turn your dryer on low heat or automatic cycle where the dryer will run until it senses the clothes have no more humidity inside the drum every time the thermostat shuts off the heater the dial moves a little closer to the off position. if there is a build up of lint around these sensers the dryer will heat up until the sensers turn the heat off. what happens now is the thermostats are nice and warm as the lint buildup iacts like an insulator preventing the thermostat from calling for more heat so it will take forever to dry a load of clothes. brush the lint off the thermostats and while you are at it vacuum the back of the dryer there should be a lot of lint there
Jan 23, 2009 | Zanussi TC7102W Electric Dryer
Electric Dryer
When you first start out with a cold dryer the dryer runs fine, then when you start a second load if wont?
It sounds like you motor is overheating, Your dryer probably needs to be cleaned, taken apart and all of the lint build up around motor removed. also so clean the venting and weather hood outside.
May 23, 2008 | Kenmore Dryers
Kenmore dryer runs then shuts off
The parts store should have never sold you the motor. They rarely if ever fail on a dryer. It sounds like a limit switch or sensor wire was damaged by the burning. Check out the wiring and if you feel comfortable jumper out one switch at a time to see which one is not working. Do only one at a time. Photograph everything before you take anything apart.
Mar 04, 2017 | Kenmore Dryers
Magic Chef CYE4000AWW Electric Dryer Logo
108 people viewed this question
Top Magic Chef Dryers Experts
Tim Whalen
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
