Question about Whirlpool LER4634J Electric Dryer
Frigidaire dryer model number LGQ1442ES0 won't stop spinnin
Hi my Frigidaire dryer model number LGQ1442ES0 won't stop spinning, I have to unplug it to stop and the heat won't turn on. HELP!!!
  • 113 Answers
Ive seen this before. There was actually a coin that had fallen out of the drum and got stuck on one of the contacts, causing it too short. Open the dryer panel, unplug it first, and look for any signs of a coin or somthing shorting a circuit. Thats step one. Hope this helps. Dave www.washermd.com
Posted on Dec 17, 2008
I have a Frigidaire Gallery W/D set. The model number for the washer is GLWS1339CS1. I need to dryer model # and the sticker is missing. Help?
Hi Joshua, I am happy to assist you!
I understand you are seeking the model number of your Frigidaire dryer because you are in need of the replacement part number of the heating element. Each appliance has its own model number listed in the serial tag on the unit itself. If the serial tag is missing or no longer visible on the upper front as you open the door of your dryer, at this point I would recommend reaching out to the manufacturer to verify if they have any documentation or your product registration. Best regards - Z
Mar 28, 2014 | Frigidaire Washing Machines
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
The coils in back turn red hot and smells like it is burning
Here is a tip that I wrote about why an electricdryer will not stop heating sometimes.
ElectricDryer won't stop heating
heatman101
Aug 15, 2011 | Frigidaire FER311FS Electric Dryer
Hi I have a dryer model # GLEQ215ES1 The dryer will run proper if I turn the heat off, but when heat is on it only runs for about 10 minutes and shuts off and all the lights on the right side blink.. Any...
It sounds like the hi-limit thermostat. For your dryer that would be Frigidaire part number 5303281113 shown below. The part is located behind the drum. You will need to take the back off of the unit to access the part. Sears carries the part.
  1. Take the back cover off of the dryer
  2. locate the part
  3. unplug one of the two wires from the old part
  4. plug that wire into the same post on the new part
  5. unplug the remaining wire from the old part
  6. plug the other wire into the new part
  7. unfasten and remove the old thermostat (with no wires)
  8. fasten the new part (with wires) into the old parts place
  9. run the dryer to see if the fix works
  10. replace the back cover on the dryer.
Steps 3 through 6 above insures that you get the two wires installed correctly. ddmagee57.jpg
Apr 27, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Gas Dryer, won't heat to dry clothes, we have cleaned the vents , were full, now clear, why won't it heat up. Gas turns on drum turns.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 10, 2010 | Frigidaire AGQ6000ES Gas Dryer
Frigidaire dryer no longer heats...
heatman101
Jun 08, 2010 | Frigidaire GLGQ332A Gas Dryer
Frigidaire AGQB6400FS not hot
heatman101
May 30, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My frigidaire electric dryer wont heat up, only
heatman101
May 11, 2010 | Dryers
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool LER4634J Electric Dryer Logo
220 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
