Your
Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that
Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s
battery is low when it’s actually fully charged.
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the
Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a
run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the
Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the
Action Replay DS will be erased.
- With your console powered off insert the Action Replay DS
- Hold down buttons A+B
- Turn your console on
- With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
- Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
- If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
source codejunkies
THANKS SO DAMN MUCH
Question does it erase everything when you reeset it or just the action reaplay
I had the same Problem, i had the ActionReplay for maybe an hour and when i turned my DS back on and when the AR loaded ALL of the games where gone.
I tryed the ""connect the usb to the pc.when you power up the ds lite with action replay in palce. press the select,start,A and B button at the same time, this will format your areplay. now update the action replay via internet and it will update all the games on your action replay"" you have to make sure you press them all at the same time, other people have been say press A+B then when it starts up hold start+select.. its wrong.. hold them all right when you turn on your DS. it woked 100% for me
Thank you
