Question about Humminbird NS25 GPS Receiver
Humminbird NS25 Fish finder with no transducer
Can i use an Airmar p37 Transducer with the Humminbird NS 25 Fish Finder ?
I understand the XT-6-20 is the correct transducer for this model, it is a dual frequency of 200/83 Khs.
The P37 has 7 pins of which two are used for depth, so i can wire those 2 to a terminal to fit to the Humminbird consol, but will it work ok ?
Thanks, adrian.
jerryg50
  • 1689 Answers
SOURCE: cant see my screen on
The most common failures:
It may be the power inverter board, and or the backplane lamps, or the screen, or the screen driver board.
The unit will have to go back for factory service. They will use board substitution to service it. Once the defective board(s) are determined, they will leave the new board(s) in the unit.
Jerry G.
Posted on Jul 26, 2008
SOURCE: navman 4500 fish finder w/transom mount transducer
I finally got an email reply from Navman. If the unit is less than two years old (mine is not) they will repair it. If it is over two years old, or if you can't prove that it is less than two years old, you can ship it to them and they will repair it for the low, low price of 355 US dollars.
Pretty nice of them since it appears these units are highly problematic isn't it? I am wondering if they guarantee their fix, or just have you on the hook for another 355 dollars later.
Good Luck Everyone,
Walt
Posted on Apr 30, 2009
  • 597 Answers
SOURCE: installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Posted on Jun 02, 2009
SOURCE: Transducer not connected
my 947 c says transducer not connected
Posted on Feb 11, 2010
  • 693 Answers
SOURCE: Need to locate and print
print users manual for Humminbird Pironha Max 160 Fish go to this link http://store.humminbird.com/media/document/PiranhaMAX_150-160-170-180-190c.pdf
Posted on Aug 13, 2011
How to connect Humminbird fish finder to Motorguide trolling motor
I would use slip rings to tie existing cable to prop motor support shaft and mount transducer to motor housing. 'slip ring'--metal ring a little bigger than shaft with a nipple the size of the cable. OR call the bird at 1-800-633-1468 or www.humminbird.com/Category/Company/Contact-Us/ and use some southern/country slang when talking. Best of luck 'you all'.
Oct 03, 2016 | Humminbird Boating
Transducer leaking wax and fish finder say,s low voltage with two new battery,s
you have a bad transducer.. its a direct short if its leaking anything getting way to hot
Oct 03, 2013 | Humminbird Matrix 97 Combo Fish Finder And...
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
I just bought a used boat with a Humminbird 160 fish finder on it but, the only thing that shows up on the screen is the temperature, NO DEPTH and NO FISH, is there a setting i need to set as i am clueless...
Check to make sure the transducer is hooked up correctly, and check the actual transducer for signs of damage. Transducers are fragile, and a good whack can break the crystal inside. For more troubleshooting, here is a helpful link with the Owners Manual for your Humminbird.
Aug 29, 2011 | Boating
I get an error msg that the transducer is not connected. How can I check idf the transducer is faulty
If you can find someone with a Humminbird that has the same pin configuration on the transducer cable, switch yours out and put the transducer in a bucket of water to see if it works. Otherwise, make sure the cable at the plotter end is firmly placed in the socket, and that no pins got bent in the past. Some of these models came with a metal clip that holds the end of the cable(s) tight to the plotter and is held tight by the mounting bracket screws.
Aug 28, 2011 | Humminbird Matrix 97 Combo Fish Finder And...
Need to locate and print users manual for Humminbird Pironha Max 160 Fish finder
Aug 13, 2011 | Humminbird GPS
Hi. Just wondering how should the transducer for my humminbird 525 fish finder/sounder be installed correctly? Thanks
You can take a picture of the transom of your boat and email it to Humminbird and they will email it back to you where the transducer should be mounted at. Our email address is service@humminbird.com.
Joby @ Humminbird
Dec 27, 2010 | Sport & Outdoor - Others
Humminbird NS25 GPS Receiver Logo
292 people viewed this question
Top Humminbird GPS Experts
Jerry Greenberg
Jerry Greenberg
Steve
Steve
Marvin
Marvin
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
