I just installed a security update on my ma and now it wont re-start. The apple cones on the screen and the small circle under it is revolving but the computer wont start up
  • cnichol Dec 17, 2008
    yep...thats all I did.... then clicked on restart when prompted and now ....nothing
  • cnichol Dec 19, 2008
    Back up and running... about 2 hours with the Apple support people.... had to use the OSX disks the computer came with... ended up loosin some apps like Office 2004 .... logitech etc.
    Problem Solver:
  • 12 Answers
Call apple. if it is therir security update they already know and can help you fix it. r u sure you did nothing else??doesn't sound right.
Posted on Dec 17, 2008
  • ericbranagan Dec 19, 2008
    Any hardware changes, such as additional memory or any other upgrades made recently to the PowerBook? No?
    Is the computer plugged into a known-good wall outlet? Try another outlet? A known-good power cord?
    Give the computer enough time to apply the security update? This may take several minutes depending on several things...
    The Apple logo screen with the spinning gear indicates that the computer has located the startup file that it needs...
    I would give it a little time before resetting the Power Manager (PMU). Make sure it's plugged in and receiving a charge.
    Try unplugging any other hardware, such as iPods and external hard drives .. nothing in the FireWire (IEEE1394) or USB slots...
    Is it the 867 MHz PowerBook? Interested in selling this unit?
    No? OK
    Give the computer enough time to apply the security update...?...
    There are stages involved in loading the OS...
    Apply Firmware Update 4.2.9 for compatibility with the security update?
    Run Disk Utility from the installation CD and "Verify" the Volume....
    In Disk Utility from the installation CD, "Verify" and "Repair" Permissions on the Volume...
    Use a Disk Utility like Micromat's TechTool Pro...Alsoft's Disk Warrior...or Drive Genius...
    Repairing Permissions just might fix this issue...
    Contact Apple Technical Support...if none of the above works...-1-800-275-2273..
PLEASE HELP my iPad 4 wont re-boot. after the apple emblem it shows a small circle with itunes in it and what looks like a cord you use to charge a iPad if you touch it or try sliding it nothing happe
Seems that your iPad has been reset to factory. You will have to plug it into your computer and launch iTunes. From there you should be able to restore from your previous sync. It helps if you use the computer you originally set up the iPad with.
Jul 03, 2014 | Apple iPad 32 GB WiFi Tablet PC
I havew an Apple laptop 2004 computer and everytime I try to use Yahoo mail a colored circle appears and revolves around the whole screen.How do I solve this from happening?
Hi
hope you have fixed the problem by now.
Try clearing your browser history and also all cookies. Since I do not know which browser you use you must find this at the developers homepage.
Hope this helps
Sep 20, 2013 | Apple MacBook Laptop Computer Mac...
Every time I try to use Yahool e-mail a revolving colored circle appears and stops the computer from working.How do I resolve this?
The Famous SPINNING BEACHBALL. It should stop after a few seconds, if not BackUp and then Reformat your HD and start over.
Wont start up completly
there is the single user start-up, which you were thinking of. There is also a safe-boot for macs.
To start up into Safe Mode (to Safe Boot), do this:
1. Be sure the computer is shut down.
2. Press the power button.
3. Immediately after you hear the startup tone, hold the Shift key. The Shift key should be held as soon as possible after the startup tone but not before.
4. Release the Shift key when you see the gray Apple icon and the progress indicator (looks like a spinning gear).
During startup in Mac OS X 10.4 or later, you will see "Safe Boot" on the login window, which appears even if you normally log in automatically.
During startup in Mac OS X 10.2 through 10.3.9, you will see "Safe Boot" on the Mac OS X startup screen.
To leave Safe Mode in any version of Mac OS X, restart the computer normally, without holding any keys during startup.
Jun 24, 2009 | Apple iMac G5 Desktop
Macbook Startup Never ending Apple Logo and Circle
try holding down the alt(option) key when starting up it should give you a list of startup options, it sounds like you dont have a astartup disk (an operating system) installed.
Dec 12, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Just can't get it to start
Hi there Emimely
Unfortunately you will not be able to get passed that. Itis quite a fundamental error.
Do you still have your original installation disk?
You need to boot your make up from that disk and see if you can make some repairs from the apple utility. Failing that you will have to re-install the OS. If you can see the drive from the install disk and you have a external drive available you might want to back up important files now and do a clean install. Or archive the previous system.
Sep 08, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My Mac laptop won't start
1. try single-user mode (hold down Cmd-S during startup tone and sequence). this should take you to a command-line screen where you can run the suggested fsck command: /sbin/fsck -fy (at the command prompt).
2. go here to see complete startup procedure in situations like this: http://support.apple.com/kb/TS1417.
3. if that doesn't work, it sometimes helps to start the computer in target mode while attached to another computer via Firewire (hold down the "T" key while starting up). then you can navigate through your ~/Library/Preferences and find the most recently modified ones and pull those into a test folder on your hard drive somewhere (just create a new folder to hold them temporarily). then restart as normal. sometimes just yanking the most recently modified preference files (.plist files) works.
Sep 07, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook start-up
http://www.retrodata.co.uk/notice_apple_seagate_drives.php
May 11, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Setting a Password
Under the extreme left of the tool bar, find the blue apple.
Under that, choose "System Preferences"
Choose "Security"
Click in the circle that says "require password to wake..."
When you installed OSX, you will have created a Username and Password. That will be the password you will use to get past the screensaver, if set, or a blank screen if not.
Stan
Dec 15, 2007 | Apple iBook Mac Notebook
Computers & Internet Logo
David Payne
David Payne
